查看: 2199|回復(fù): 0
基于STM32的HDC1080傳感器程序
ID:958854 發(fā)表于 2021-12-14 12:29 | 顯示全部樓層 |閱讀模式
TI公司的傳感器芯片 使用IIC通訊
  1. /*
  2. * HDC1080.c:
  3. */
  4. #include "hdc1080.h"
  5. #include <stdlib.h>
  6. #include <stdio.h>
  7. #define HDC1080_I2CADDR         0x40
  8. #define HDC1080_TEMPERATURE     0x00
  9. #define HDC1080_HUMIDITY        0x01
  10. #define HDC1080_CONFIG          0x02
  11. #define HDC1080_CONFIG_RST      (1 << 15)
  12. #define HDC1080_CONFIG_HEAT     (1 << 13)
  13. #define HDC1080_CONFIG_MODE     (1 << 12)
  14. #define HDC1080_CONFIG_BATT     (1 << 11)
  15. #define HDC1080_CONFIG_TRES_14  0
  16. #define HDC1080_CONFIG_TRES_11  (1 << 10)
  17. #define HDC1080_CONFIG_HRES_14  0
  18. #define HDC1080_CONFIG_HRES_11  (1 << 8)
  19. #define HDC1080_CONFIG_HRES_8   (1 << 9)
  20. #define HDC1080_SERIAL_ID_FIRST 0xFB
  21. #define HDC1080_SERIAL_ID_MID   0xFC
  22. #define HDC1080_SERIAL_ID_LAST  0xFD
  23. #define HDC1080_MANUFID         0xFE
  24. #define HDC1080_DEVICEID        0xFF
  25. bool HDC1080_Init(void)
  26. {
  27.     uint16_t data;
  28.     uint8_t buf[2];
  29.     uint16_t config = HDC1080_CONFIG_RST | HDC1080_CONFIG_MODE | HDC1080_CONFIG_TRES_14 | HDC1080_CONFIG_HRES_14;
  30.     //soft reset
  31.     IIC_WriteReg(HDC1080_I2CADDR, HDC1080_CONFIG, (config>>8)&0x00FF);
  32.     DELAY_MS(15);
  33.
  34.     IIC_ReadData(HDC1080_I2CADDR, HDC1080_MANUFID, buf, 2);
  35.     data = (buf[0]<<8)+buf[1];
  36.     if(data!=0x5449)
  37.         return false;
  38.
  39.     IIC_ReadData(HDC1080_I2CADDR, HDC1080_DEVICEID, buf, 2);
  40.     data = (buf[0]<<8)+buf[1];
  41.     if(data!=0x1050)
  42.         return false;
  43.
  44.     Usart1_Send("HDC1080 initialize register finished.\r\n");
  45.     return true;
  46. }
  47. float HDC1080_Temperature(void)
  48. {
  49.     float data;
  50.     uint8_t buf[2];
  51.     IIC_ReadData(HDC1080_I2CADDR, HDC1080_TEMPERATURE, buf, 2);
  52.     data=(buf[0]<<8)+buf[1];
  53.
  54.     data /= 65536;
  55.     data *= 165;
  56.     data -= 40;
  57.     return data;
  58. }
  59. float HDC1080_Humidity(void)
  60. {
  61.     float data;
  62.     uint8_t buf[2];
  63.     IIC_ReadData(HDC1080_I2CADDR, HDC1080_HUMIDITY, buf, 2);
  64.     data=(buf[0]<<8)+buf[1];
  65.
  66.     data /= 65536;
  67.     data *= 100;
  68.     return data;
  69. }
Keil代碼下載:
HDC1080.7z (183.2 KB, 下載次數(shù): 44)
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 共享資料的黑幣獎(jiǎng)勵(lì)!
