查看: 3275|回復(fù): 3
單片機(jī)16x16分屏顯示文字報(bào)錯(cuò)error C242: 'scalar': too many initializers
ID:990261 發(fā)表于 2021-12-14 20:29 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#define saomiao P1
sbit DS=P3^0;
sbit CLK=P3^1;
sbit ST=P3^2;
sbit OE=P3^3;
delay(int);
void WR_74HC595(unsigned char);
void OUT_74HC595(void);
int repeat=30;
char code seg[]={
{0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x03,0xE0,0x7F,0xFF,0x7F,0xFF,0x00,0x80,0x7F,0xFF,
0x7F,0xFF,0x77,0xFF,0x77,0xE0,0x77,0xFF,0x77,0xFF,0x6B,0xFF,0x1D,0x80,0xFE,0xFF},
{0xFF,0xF6,0xFB,0xF6,0xF7,0xF6,0x37,0xC0,0xFF,0xF6,0xFF,0xF6,0xF0,0xF6,0x17,0x80,
0xF7,0xF6,0xF7,0xF6,0x77,0xF7,0x77,0xF7,0xB7,0xF7,0xEB,0xFF,0x1D,0x80,0xFF,0xFF},
{0xFB,0xFF,0x7B,0xC0,0xFB,0xEF,0xC0,0xF7,0xFD,0xF3,0xF5,0xED,0xF6,0xDE,0x00,0xBF,
0xF7,0xFF,0x77,0xC0,0xC7,0xFB,0xF0,0xFB,0xF5,0xFB,0xF7,0xFB,0x37,0x80,0xF7,0xFF},
{0xFF,0xFF,0xFF,0xFF,0x01,0xC0,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,
0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x00,0x80,0xFF,0xFF,0xFF,0xFF},
{0xFF,0xFF,0xFB,0xFF,0x17,0x80,0xF7,0xFE,0xFF,0xFE,0xFF,0xC0,0xF0,0xDE,0xF7,0xDE,
0xF7,0xDE,0x77,0xDF,0x77,0xDF,0xB7,0xEB,0xD7,0xF7,0xEB,0xFF,0x1D,0x80,0xFF,0xFF},
{0xBF,0xFF,0xDF,0xFF,0xEF,0xFF,0x01,0xC0,0xFD,0xDF,0xFD,0xDF,0x1D,0xDC,0xDD,0xDD,
0xDD,0xDD,0xDD,0xDD,0xDD,0xDD,0x1D,0xDC,0xDD,0xDD,0xFD,0xDF,0xFD,0xD7,0xFD,0xEF},
{0xFF,0xF5,0xFF,0xED,0xFF,0xFD,0x03,0x80,0xFB,0xFD,0xFB,0xFD,0xFB,0xDD,0x83,0xDD,
0xBB,0xDD,0xBB,0xEB,0xBB,0xEB,0xBB,0xB7,0xAB,0xB3,0xDD,0xAD,0xFD,0x9E,0x7E,0xBF},
{0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0x80,0xFD,0x77,0xC0,0xF7,0xDD,0xF7,0xDD,0xF7,0xDD,0xF7,
0xDD,0xF7,0xDE,0xF7,0xDE,0x87,0xDE,0x70,0xDF,0x7D,0xDF,0xBF,0xEB,0xDF,0xF7}
        main()
        int i;
        int m;
        int j;
        OE=0;
                for(m=0;m<repeat;m++)
                {for(i=0;i<16;i++)
                        {saomiao=i;
                         WR_595(seg[2*i+1+32*j]);
                         WR_595(seg[2*i+32*j]);
                                OUT_595();
                                delay(2);
                                WR_595(0xff);
                                WR_595(0xff);
                                OUT_595();
                j++;
                if(j==8)j=0;
delay(int x)
        int i,j;
        for(i=0;i<x;i++)
        for(j=0;j<120;j++);
void WR_74HC595(unsigned char a)
{unsigned char b,da;
        for(b=0;b<8;b++)
{da=a&0x80;
        if(da==0) DS=0;
        if(da!=0) DS=1;
        a<<=1;
        CLK=0;
        _nop_();
        _nop_();
        _nop_();
        CLK=1;
void OUT_74HC595()
{ST=0;
        _nop_();
        _nop_();
        _nop_();
        ST=1;
ID:990261 發(fā)表于 2021-12-14 20:30 | 只看該作者
c(13): error C242: 'scalar': too many initializers 怎么修改
ID:979299 發(fā)表于 2021-12-14 22:19 | 只看該作者
宏定義名稱(chēng)和代入名稱(chēng)不同,數(shù)組里面多出很多大括號(hào),延時(shí)函數(shù)下面缺少返回值
參與人數(shù) 1黑幣 +20 收起 理由
ID:981034 發(fā)表于 2022-1-4 14:16 | 只看該作者
數(shù)組為何要這么多大括號(hào)?
