#include <REGX52.H>
//引腳配置:
sbit LCD_RS=P2^6;
sbit LCD_RW=P2^5;
sbit LCD_EN=P2^7;
sbit LCD1602_BUSY=P0^7; //檢測(cè)狀態(tài)引腳P0.7
#define LCD_DataPort P0
//函數(shù)定義:
* @brief LCD1602延時(shí)函數(shù),12MHz調(diào)用可延時(shí)1ms
* @param 無(wú)
* @retval 無(wú)
void LCD_Delay()
unsigned char i, j;
i = 9;
j = 244;
do
while (--j);
} while (--i);
void lcd1602_check_busy()//判忙
P0=0xff;
do
LCD_RS=0;
LCD_RW=1;
LCD_EN=0;
LCD_EN=1;
} while(LCD1602_BUSY==1);
LCD_EN=0;
* @brief LCD1602寫命令
* @param Command 要寫入的命令
* @retval 無(wú)
void LCD_WriteCommand(unsigned char Command)
LCD_RS=0;
LCD_RW=0;
LCD_DataPort=Command;
LCD_Delay();
LCD_EN=1;
LCD_Delay();
LCD_EN=0;
LCD_Delay();
* @brief LCD1602寫數(shù)據(jù)
* @param Data 要寫入的數(shù)據(jù)
* @retval 無(wú)
void LCD_WriteData(unsigned char Data)
LCD_RS=1;
LCD_RW=0;
LCD_DataPort=Data;
LCD_Delay();
LCD_EN=1;
LCD_Delay();
LCD_EN=0;
LCD_Delay();
* @brief LCD1602設(shè)置光標(biāo)位置
* @param Line 行位置,范圍:1~2
* @param Column 列位置,范圍:1~16
* @retval 無(wú)
void LCD_SetCursor(unsigned char Line,unsigned char Column)
if(Line==1)
LCD_WriteCommand(0x80|(Column-1));
else if(Line==2)
LCD_WriteCommand(0x80|(Column-1+0x40));
* @brief LCD1602初始化函數(shù)
* @param 無(wú)
* @retval 無(wú)
void LCD_Init()
{ LCD_Delay();
LCD_WriteCommand(0x38);//八位數(shù)據(jù)接口,兩行顯示,5*7點(diǎn)陣
LCD_WriteCommand(0x0c);//顯示開,光標(biāo)關(guān),閃爍關(guān)
LCD_WriteCommand(0x06);//數(shù)據(jù)讀寫操作后,光標(biāo)自動(dòng)加一,畫面不動(dòng)
LCD_WriteCommand(0x01);//光標(biāo)復(fù)位,清屏
* @brief 在LCD1602指定位置上顯示一個(gè)字符
* @param Char 要顯示的字符
* @retval 無(wú)
void LCD_ShowChar(unsigned char Line,unsigned char Column,char Char)
LCD_SetCursor(Line,Column);
LCD_WriteData(Char);
* @brief 在LCD1602指定位置開始顯示所給字符串
* @param Line 起始行位置,范圍:1~2
* @param Column 起始列位置,范圍:1~16
* @param String 要顯示的字符串
* @retval 無(wú)
void LCD_ShowString(unsigned char Line,unsigned char Column,char *String)
unsigned char i;
for(i=0;String[i]!='\0';i++)
LCD_WriteData(String[i]);
* @brief 返回值=X的Y次方
int LCD_Pow(int X,int Y)
unsigned char i;
int Result=1;
for(i=0;i<Y;i++)
Result*=X;
return Result;
* @brief 在LCD1602指定位置開始顯示所給數(shù)字
* @param Number 要顯示的數(shù)字,范圍:0~65535
* @param Length 要顯示數(shù)字的長(zhǎng)度,范圍:1~5
* @retval 無(wú)
void LCD_ShowNum(unsigned char Line,unsigned char Column,unsigned int Number,unsigned char Length)
unsigned char i;
for(i=Length;i>0;i--)
LCD_WriteData(Number/LCD_Pow(10,i-1)%10+'0');
能幫忙看下有啥問題不 |
