查看: 1408|回復(fù): 2
51單片機(jī)12864仿真,如何讓我的這行文字圖形從右向左移動(dòng),求指導(dǎo)
ID:992696 發(fā)表于 2021-12-21 20:26 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg51.h>
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add     0xb8//???
#define LCDCol_Add     0x40//???
#define Start_Line     0xC0//???
#define data_ora P0 /*??????*/
sbit LCDMcs=P2^4 ;    /*??1*/
sbit LCDScs=P2^3 ;    /*??2*/
sbit LCDDi=P2^2 ;     /*??/?? ??*/
sbit LCDRW=P2^1 ;     /*?/? ??*/
sbit LCDEnable=P2^0 ;     /*?/? ??*/
unsigned char code Bmp1[]=
  ?×?(??): 128×16
  ????/?? : ????????,????,????/256??
/*--  ???????:C:\Users\dhd\Desktop\1111111.bmp  --*/
/*--  ??x??=128x16  --*/
      0x10,0x88,0xC4,0xA3,0xBC,0xA0,0xBF,0xA0,
      0xBC,0x20,0xD8,0x17,0x90,0x78,0x10,0x00,
      0x10,0x10,0xD0,0xFF,0x90,0x10,0x00,0xFC,
      0x04,0x04,0x04,0xFE,0x04,0x00,0x00,0x00,
      0x00,0x00,0xFE,0x02,0xE2,0xA2,0xB2,0xAE,
      0xA2,0xA2,0xA2,0xA2,0xF3,0x22,0x00,0x00,
      0x44,0x44,0xFC,0x46,0x44,0x00,0xFE,0x92,
      0x92,0xFE,0x92,0x92,0xFF,0x02,0x00,0x00,
      0x00,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,
      0x42,0x72,0x4E,0x42,0xC0,0x00,0x00,0x00,
      0x00,0x00,0xFC,0x04,0x24,0xC4,0x04,0x15,
      0x66,0x84,0x04,0x04,0x84,0x76,0x04,0x00,
      0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,
      0x22,0x22,0x22,0x22,0xFF,0x02,0x00,0x00,
      0x40,0x42,0xCC,0x00,0x00,0x00,0xFE,0x92,
      0x01,0x00,0xFF,0x40,0x3E,0x02,0x02,0x3E,
      0x90,0x48,0x33,0x0C,0x33,0xC0,0x40,0x00,
      0x04,0x03,0x00,0xFF,0x80,0x41,0x20,0x1F,
      0x00,0x00,0x00,0x3F,0x40,0x40,0x70,0x00,
      0x40,0x30,0x0F,0x40,0x23,0x1A,0x42,0x82,
      0x7E,0x02,0x02,0x0A,0x13,0x60,0x00,0x00,
      0x10,0x30,0x1F,0x08,0x48,0x48,0x44,0x44,
      0x44,0x7F,0x44,0x46,0x44,0x60,0x40,0x00,
      0x40,0x20,0x18,0x07,0x80,0x41,0x22,0x14,
      0x08,0x14,0x22,0x21,0x40,0xC0,0x40,0x00,
      0x40,0x30,0x0F,0x40,0x40,0x40,0x4F,0x40,
      0x40,0x63,0x50,0x4C,0x43,0x60,0x40,0x00,
      0x80,0x60,0x1F,0x02,0x02,0x02,0x02,0x7F,
      0x02,0x02,0x42,0x82,0x7F,0x00,0x00,0x00,
      0x00,0x00,0x3F,0x10,0x4A,0x22,0x12,0x0A,
      0x06,0xFF,0x06,0x0A,0x32,0x62,0x22,0x00,
unsigned char code Bmp2[]=
  ?×?(??): 128×16
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x24,0x24,0xA4,0xFE,0xA3,0x22,0x20,0x7E,
      0x42,0x42,0x42,0x42,0x42,0x7F,0x02,0x00,
      0x40,0x40,0x42,0xCC,0x00,0x40,0xA0,0x9F,
      0x81,0x81,0x81,0x9F,0xA0,0x20,0x20,0x00,
      0x40,0x40,0x42,0xCC,0x00,0x40,0x40,0x40,
      0x40,0xFF,0x40,0x40,0x40,0x60,0x40,0x00,
      0x08,0x06,0x01,0xFF,0x00,0x43,0x41,0x49,
      0x49,0x49,0x7F,0x49,0x4D,0x69,0x41,0x00,
      0x00,0x00,0x00,0x7F,0xA0,0x90,0x40,0x43,
      0x2C,0x10,0x28,0x26,0x41,0xC0,0x40,0x00,
      0x00,0x00,0x00,0x7F,0x20,0x10,0x08,0x00,
      0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp3[]=
  ?×?(??): 128×16
unsigned char code Bmp4[]=
   ?×?(??): 128×16
????:LCD????
????:t
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
????,LCD???
void CheckState()
   unsigned char dat,DATA;//????(?????)
   LCDDi=0; // ??\????,D/I(RS)="L" ,?? DB7?DB0 ???????
   LCDRW=1; //R/W="H" ,E="H"?????DB7?DB0
   do
      DATA=0x00;
      LCDEnable=1;        //EN???
          LCDdelay(2);//??
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat; //???7??0?????(??busy??)
    while(!(dat==0x00));
????:????LCD??,RS(DI)=L,RW=L,EN=H,?????????
????:cmdcode
void write_com(unsigned char cmdcode)
    CheckState();//??LCD???
        LCDDi=0;
        LCDRW=0;
        P1=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
????:LCD?????
void init_lcd()
        LCDdelay(100);
        LCDMcs=1;//???????
        LCDScs=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);         //??????
        write_com(Page_Add+0);
        write_com(Start_Line+0);
        write_com(LCDCol_Add+0);
        write_com(LCDLCDDisp_On);
????:????LCD??,RS(DI)=H,RW=L,EN=H,?????????
????:LCDDispdata
void write_data(unsigned char LCDDispdata)
        LCDDi=1;
        LCDRW=0;
        P1=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
????:??LCD????
????:pag,col,hzk
void Clr_Scr()
        unsigned char j,k;
        LCDMcs=0; //????????
        LCDScs=0;
         for(k=0;k<8;k++)//????0-7,?8?
                write_com(Page_Add+k); //???????
                  for(j=0;j<64;j++)  //??????32??????64?ASCII??
                      write_com(LCDCol_Add+j);
                        write_data(0x00);//????0-63,?64?,????,??????1
????:page,column,hzk
void Bmp_Left_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<64;i++)
                        write_data(Bmp[128*j+i]);
void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        for(j=0;j<2;j++)
                for(i=64;i<128;i++)
        init_lcd();
        Clr_Scr();
        LCDMcs=0; //?????
        LCDScs=1;
          Bmp_Left_Disp(0,0,Bmp4);
    Bmp_Left_Disp(2,0,Bmp3);
    Bmp_Left_Disp(4,0,Bmp2);
    Bmp_Left_Disp(6,0,Bmp4);
        LCDMcs=1; //?????
        LCDScs=0;
    Bmp_Right_Disp(0,0,Bmp4);
    Bmp_Right_Disp(2,0,Bmp3);
    Bmp_Right_Disp(4,0,Bmp2);
    Bmp_Right_Disp(6,0,Bmp4);
ID:277550 發(fā)表于 2021-12-22 09:31 | 只看該作者
列不斷改變
ID:992696 發(fā)表于 2021-12-23 12:13 | 只看該作者
devcang 發(fā)表于 2021-12-22 09:31
列不斷改變
加在哪里呀,有具體的程序嗎
