查看: 1288|回復(fù): 0
open mv二維碼識別有時候識別不出來什么原因
ID:836780 發(fā)表于 2021-12-22 19:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
import sensor, image,time,lcd, math
from pyb import UART,Timer,LED
threshold_index = 0 # 0 for red, 1 for green, 2 for blue
thresholds1 = [(65, 94, -63, -29, -14, 27)] # 黑色閾值
thresholds = [(8, 66, 21, 79, 3, 62), # 紅色
              (30, 100, -64, -8, -32, 32), #
              (96, 100, -15, -3, -14, 43)] #
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.skip_frames(time = 2000)
sensor.set_auto_gain(False)
sensor.set_auto_whitebal(False)
clock = time.clock()
data = []
uart = UART(3,115200,8,None,1)       #創(chuàng)建串口對象
while(True):
  img = sensor.snapshot()     #保持一張照片
  for blob1 in img.find_blobs(thresholds1,roi= [0,0,318,145], pixels_threshold=300, area_threshold=200):
     b=blob1.x()-150
     d=blob1.x()+70
     e=blob1.y()+50
     print(d)
     print(e) #通過坐標得到一塊識別區(qū)域
  if(uart.any()): #判斷是否有串口信息過來
     data = uart.read(8)  #讀8位數(shù)據(jù)
     if((data[0] == 0x55)&(data[1] == 0x02)&(data[7] == 0xBB)):
       print("4")
       if(data[2] == 0x92 and data[3] == 0x01 ):  #紅綠燈
          for blob in img.find_blobs(thresholds,roi= [0,0,d,e], pixels_threshold=300, area_threshold=200):
                print( blob.code())
                if blob.code()==1 or blob.code()==4:   #因為紅色與黃色總是識別成一樣的所以用坐標判斷
                  print("5")
                  if blob.x()<b:  #紅色
                    uart.writechar(0x55)
                    uart.writechar(0x02)
                    uart.writechar(0x92)
                    uart.writechar(0x01)
                    uart.writechar(0x00)
                    uart.writechar(0xBB)
                    print("紅色")
                  if blob.x()>b: #黃色
                    # qr_Tab = code.payload()
                     uart.writechar(0x03)
                     print("黃色")
                if blob.code()!=1 or blob.code()!=4:#綠色
                    print("綠色")
        if(data[2] == 0x92 and data[3] == 0x02 ):  #二維碼
                  print("二維碼")
                  for code in img.find_qrcodes():  #這是一個二維碼功能函數(shù)     uart.writechar是串口發(fā)送數(shù)據(jù)的
                      time.sleep(100)
                      uart.writechar(0x89)
                      uart.writechar(len(qr_Tab))
                      for qrdata in qr_Tab:
                           uart.writechar(ord(qrdata))
                      print("6")
