查看: 1431|回復(fù): 2
stm8003單片機驅(qū)動lcd1602 四線驅(qū)動出現(xiàn)問題 求大神幫忙
ID:543220 發(fā)表于 2021-12-25 09:59 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
現(xiàn)在發(fā)現(xiàn)驅(qū)動出現(xiàn)亂碼 以及 不顯示 ,功能很不正常
下面附上代碼以及 原理圖
#ifndef __LCD1602_H
#define __LCD1602_H
/***********LCD1602 四線驅(qū)動***********/
#include "system.h"
#include "delay.h"
/***********Definition***********/
#define LINE0   0x80
#define LINE1   0xC0
#define Rx_PORT (GPIOD)//RS= PD6  RW=PD5 EN=PD4
#define RS_PIN (GPIO_PIN_6) /* PD6 */
//#define RW_PIN (GPIO_PIN_5) /* PD5 */ /* NOT USE(RW接地) */
#define EN_PIN (GPIO_PIN_4) /* PD4 */
#define Rx_FOUR_PINS (RS_PIN | EN_PIN)
//#define Rx_ALL_PINS (RS_PIN | RW_PIN | EN_PIN) /* NOT USE */
#define Dx_PORT (GPIOC)
//#define D0_PIN (GPIO_PIN_0) /* PC0 */ /* NOT USE */
//#define D1_PIN (GPIO_PIN_1) /* PC1 */ /* NOT USE */
//#define D2_PIN (GPIO_PIN_2) /* PC2 */ /* NOT USE */
//#define D3_PIN (GPIO_PIN_3) /* PC3 */ /* NOT USE */
#define D4_PIN (GPIO_PIN_4) /* PC4 */
#define D5_PIN (GPIO_PIN_5) /* PC5 */
#define D6_PIN (GPIO_PIN_6) /* PC6 */
#define D7_PIN (GPIO_PIN_7) /* PC7 */
#define Dx_FOUR_PINS (D4_PIN | D5_PIN | D6_PIN | D7_PIN)
//#define Dx_ALL_PINS (D0_PIN | D1_PIN | D2_PIN | D3_PIN | D4_PIN | \
                     D5_PIN | D6_PIN | D7_PIN) /* NOT USE */
#define RS_LOW  GPIO_WriteLow (Rx_PORT, RS_PIN)
#define RS_HIGH GPIO_WriteHigh(Rx_PORT, RS_PIN)
#define EN_LOW  GPIO_WriteLow (Rx_PORT, EN_PIN)
#define EN_HIGH GPIO_WriteHigh(Rx_PORT, EN_PIN)
#define Dx_CLR  GPIO_Write(Dx_PORT, 0x00)
/***********Function***********/
void LCD1602_Cmd(uint8_t cmd);
void LCD1602_Data(uint8_t data);
void LCD1602_Init(void);
void LCD1602_SetCursor(uint8_t x, uint8_t y);
void LCD1602_PrintStr(uint8_t x, uint8_t y, uint8_t *str);
#endif /* __LCD1602_H */
#include "lcd1602.h"
/******發(fā)送命令******/
  delay_ms(2000);
  EN_LOW;
  RS_LOW; /* RS=0,寫入命令 */
  delay_us(10);
  GPIO_Write(Dx_PORT, (cmd&0xf0));     /* 接收高四位命令 */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
  GPIO_Write(Dx_PORT, (cmd&0xf0)<<4); /* 接收低四位命令 */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
/******發(fā)送數(shù)據(jù)******/
  delay_ms(200);
  EN_LOW;
  RS_HIGH; /* RS=1,寫入數(shù)據(jù) */
  delay_us(10);
  GPIO_Write(Dx_PORT, (data&0xf0));     /* 接收高四位數(shù)據(jù) */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
  delay_us(10);
  GPIO_Write(Dx_PORT, (data&0xf0)<<4); /* 接收低四位數(shù)據(jù) */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
/******LCD初始化******/
    delay_ms(200);
//  LCD1602_Cmd(0x20);
//  LCD1602_Cmd(0x32);
//  delay_ms(5);
//  LCD1602_Cmd(0x28);  // 最后發(fā)0x28,進入4線模式,設(shè)置16*2顯示,115*7點陣,4位數(shù)據(jù)接口
//  delay_ms(5);
//  delay_ms(5);
//  EN_HIGH;
//  EN_LOW;
  LCD1602_Cmd(0x30);
  delay_ms(5);
  LCD1602_Cmd(0x30);
  delay_ms(5);
  LCD1602_Cmd(0x30);
  delay_ms(5);
  LCD1602_Cmd(0x28);
  LCD1602_Cmd(0x08);
  LCD1602_Cmd(0x01); /* 清屏 */
  LCD1602_Cmd(0x06);
  LCD1602_Cmd(0x0f);
  delay_ms(2);
  //LCD1602_Cmd(0x06); /* 寫入數(shù)據(jù)光標右移,寫入新數(shù)據(jù)顯示屏不移動 */
  //LCD1602_Cmd(0x0C); /* 開顯示,有光標,光標閃爍 */
/* 0x80和0xC0分別是兩行的開始地址,將字符的序號加上行的地
   址作為命令發(fā)送給LCD1602會讓下一個字符輸出在指定的位置  */
/******發(fā)送地址******/
void LCD1602_SetCursor(uint8_t x, uint8_t y) // x:列坐標 y:行坐標
  LCD1602_Cmd(x + (y ? LINE1:LINE0));
/******連續(xù)發(fā)送數(shù)據(jù)******/
  LCD1602_SetCursor(x, y);
  while(*str != '\0')
    LCD1602_Data(*str++);
ID:517951 發(fā)表于 2022-1-3 13:24 | 只看該作者
發(fā)下亂碼顯示照片, 注意一下上電復(fù)位時序,還有發(fā)送數(shù)據(jù)的速度。lcd1602是慢速器件,不能太快。
另外論壇里有PCF8574驅(qū)動LCD1602的例程,你可以參照他們的程序來,也是采用4線驅(qū)動方式做的。
ID:543220 發(fā)表于 2022-1-5 14:27 | 只看該作者
rayin 發(fā)表于 2022-1-3 13:24
另外論壇 ...
感謝  , 已經(jīng)解決與了 ,由于用的是ST_LINK仿真, 雖然程序初始化  有顯示清空的程序, 但還是不行, 需要重新上電。  所以 不重新上電會導(dǎo)致亂碼  , 還是得感謝你
