查看: 2472|回復(fù): 2
STM32G030K6T6單片機(jī)ADC DMA多通道采樣數(shù)據(jù)不正確
ID:955654 發(fā)表于 2022-1-13 10:06 | 顯示全部樓層 |閱讀模式
ADC DMA多通道  進(jìn)行采樣時,獲取到得數(shù)據(jù)與實(shí)際不一致,單通道時是對的
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.LowPowerAutoPowerOff = DISABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.NbrOfConversion = 12;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = ENABLE;
  hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_39CYCLES_5;
  hadc1.Init.SamplingTimeCommon2 = ADC_SAMPLETIME_39CYCLES_5;
  hadc1.Init.OversamplingMode = DISABLE;
  hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = 0;
  sConfig.SamplingTime = ADC_SAMPLETIME_39CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = 1;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = 2;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_3;
  sConfig.Rank = 3;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_4;
  sConfig.Rank = 4;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_5;
  sConfig.Rank = 5;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_6;
  sConfig.Rank = 6;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_7;
  sConfig.Rank = 7;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_8;
  sConfig.Rank = 8;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = 9;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_10;
  sConfig.Rank = 10;
    Error_Handler();
        sConfig.Channel = ADC_CHANNEL_11;
  sConfig.Rank = 11;
    Error_Handler();
void adc_Dma_start(void)
        HAL_ADCEx_Calibration_Start(&hadc1);
        HAL_ADC_Start_DMA(&hadc1,(uint32_t *)&adcBuff,12);
ID:607298 發(fā)表于 2022-1-13 14:21 | 顯示全部樓層
這邊掃描模式應(yīng)該要使能吧,hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
另外adcBuff感覺有點(diǎn)小,才能存一次結(jié)果。一般我都設(shè)置至少存?zhèn)10次的結(jié)果。
ID:955654 發(fā)表于 2022-1-13 14:35 | 顯示全部樓層
lightday 發(fā)表于 2022-1-13 14:21
另外adcBuff感覺有點(diǎn)小,才能存 ...
問題 已經(jīng)解決了,adc 通道配置成 不完全配置序列模式 既 ScanConvMode = ADC_SCAN_SEQ_FIXED
還有個  Rank = ADC_RANK_CHANNEL_NUMBER
