本帖最后由 菜鳥(niǎo)一個(gè)622 于 2022-1-22 10:26 編輯
想添加開(kāi)時(shí)慢到快暗到亮然后一直正常亮度,關(guān)時(shí)快到慢亮到暗關(guān)閉,腦子有點(diǎn)寫(xiě)蒙了。。。。一直運(yùn)行不對(duì),我知道bug肯定多,只是看教學(xué)視頻有些貫不通,麻煩大佬教下
#include <reg51.h> // <reg51.h>程序電腦實(shí)驗(yàn) <STC8G.h>實(shí)際
sbit key1=P3^0;
sbit PWM_out_pin=P0;
unsigned char dat1[4]={0xf1,0xf2,0xf4,0xf8};
unsigned char dat2[4]={0xfc,0xf9,0xf3,0xf6};
unsigned char dat3[4]={0xfe,0xfd,0xfb,0xf7};
//unsigned char duty_cut;
unsigned char MODE;
unsigned int count;
unsigned char slow;
unsigned int cnt;
unsigned char sec,min,hour,PWM_duty=50;
bit sign;
void delay (unsigned int x);
void mode1(void);
void mode2(void);
void mode3(void);
void keyscan(void);
void Init_T0(void);
void T0_IRQ(void);
void Init_T0(void)
TMOD &=0Xf0;
TMOD |=0x02;
TR0=1;
TL0=56;
TH0=56;
TF0=0;
ET0=1;
EA=1;
PT0=1;
void T0_IRQ(void) interrupt 1
cnt++;
if(cnt==0)
cnt=0;
// P0=0xff;
if(cnt<PWM_duty)
PWM_out_pin=1;
PWM_out_pin=0;
void main(void)
keyscan();
switch(MODE)
case 0: P0=0xff;break;
case 1: mode1();break;
case 2: mode2();break;
case 3: mode3();break;
delay(1);
Init_T0();
PWM_duty=0;
P0=0xff;
while(2)
for(PWM_duty=0;PWM_duty<100;PWM_duty++)//暗到亮
delay(100);
for(PWM_duty=100;PWM_duty>0;PWM_duty--)//亮到暗
delay(100);
void delay(unsigned int x)
unsigned int i,j;
for(i=0;i<x;i++)
for(j=0;j<120;j++);//12T
// for(j=0;j<1200;j++);//1T STC8G
void mode1(void)
static unsigned char i;
static unsigned int j;
P0=dat1;
for(j=500;j>50;j--) //慢到快到快固定不知道對(duì)不對(duì)
if(++j>=50)
j=0
i=++i%4;
void mode2(void)
P0=dat2;
if(++j>=50)
j=0;
i=++i%4;
void mode3(void)
P0=dat3;
if(++j>=50)
j=0;
i=++i%4;
void keyscan(void)
if(key1==0)
if(count<501)count++;
if(count==500)//??
sign=~sign;
if(sign)
slow=MODE;
MODE=0;
else MODE=slow;
if(count>20 && count<500
++MODE;
if(MODE>3)
MODE=1;
count=0;
