查看: 2707|回復(fù): 4
51單片機(jī)怎樣能簡(jiǎn)單實(shí)現(xiàn)流水燈慢速到快速并固定住快速流水
ID:1002664 發(fā)表于 2022-1-24 16:48 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
30黑幣
如題,開機(jī)流水速度慢到快,關(guān)機(jī)流水速度快到慢結(jié)束
最佳答案
查看完整內(nèi)容
#include typedef unsigned char u8; //0 to 255 typedef unsigned int u16; //0 to 65535 typedef unsigned long u32; //0 to 4294967295 sbit key1=P3^0; bit Power_On = 1; u16 TMR_XX_ACC; u16 TMR_XX_PRE = 9950; u8 index = 0; void key_Proc() { static u16 Delay_XD=0; if(!key1) { if(Delay_XD= TMR_XX_PRE) { TMR_XX_ACC=0; ...
ID:161164 發(fā)表于 2022-1-24 16:48 | 只看該作者
#include <reg52.h>
sbit key1=P3^0;
bit Power_On = 1;
u16 TMR_XX_ACC;
u8 index = 0;
void key_Proc()
        if(!key1)
                if(Delay_XD<0xFFFF)Delay_XD++;
                if(Delay_XD==250)
                        Power_On ^= 1;
                        if(Power_On){
                                TMR_XX_PRE = 9950;
                                index = 0;
                Delay_XD = 0;
    while (1)
                                key_Proc();
        if(++TMR_XX_ACC >= TMR_XX_PRE)
        {   TMR_XX_ACC=0;
                                        if(TMR_XX_PRE != 10000){
            P0 = ~(0x01 << index);
            index = ++index %8;
                                        }else{
                                                P0 = 0xFF;
                                                        if(Power_On){
                if(TMR_XX_PRE>1000)//固定到快
                    TMR_XX_PRE -=50;
                                                        else{
        if(TMR_XX_PRE<10000)//固定到慢
        TMR_XX_PRE +=50;
ID:1002664 發(fā)表于 2022-1-25 08:52 | 只看該作者
lkc8210 發(fā)表于 2022-1-24 22:04
#include
大佬能給個(gè)注釋嘛,學(xué)習(xí)不懂
ID:161164 發(fā)表于 2022-1-25 11:47 | 只看該作者
菜鳥一個(gè)622 發(fā)表于 2022-1-25 08:52
哪句不懂?
ID:1002664 發(fā)表于 2022-1-25 14:08 | 只看該作者
大佬試著您的程序,多打啦幾次代碼大概意識(shí)懂了,添加了幾個(gè)模式想讓它開時(shí)還是流水慢到快固定,關(guān)時(shí)快到慢關(guān)閉,切換后也是慢到快。程序keil沒報(bào)錯(cuò),仿真測(cè)試開始是慢到快,關(guān)沒有效果直接關(guān)閉,再開還是快的流水。。。能幫我看看嘛
#include <reg51.h>
sbit key1=P3^0;
typedef unsigned char u8;MODE;slow;
typedef unsigned int u16;count;
unsigned char dat1[4]={0xf1,0xf2,0xf4,0xf8};
unsigned char dat2[4]={0xfc,0xf9,0xf3,0xf6};
unsigned char dat3[4]={0xfe,0xfd,0xfb,0xf7};
bit Power_On = 1;
bit sign;
u16 TMR_XX_ACC;
u16 TMR_XX_PRE = 500;
u8 index = 0;
void mode1(void);
void mode2(void);
void mode3(void);
void key_Proc();
void Delay_XD(unsigned int x);
void key_Proc()
      if(key1==0)
         if(count<501)count++;
             if(count==500)//長(zhǎng)按
            sign=~sign;
            if(sign)
                     slow=MODE;//保存鍵值下次開啟還是在哪個(gè)模式
                      MODE = 0;//關(guān)閉流水
                                        else MODE=slow; //還原鍵值
                                        if(count>20 && count<500)//短按
                                                ++MODE;
                                                if(MODE>3)
                                                        MODE=1;
                                  count = 0;
    while (1)
           key_Proc();
                            switch(MODE)
                                                case 0: P0=0xFF;break;
                        case 1: mode1();break;
                        case 2: mode2();break;
                        case 3: mode3();break;
    Delay_XD(1);
      unsigned int i,j;
        for(i=0;i<x;i++)
               for(j=0;j<120;j++);//12T
void mode1(void)
                         TMR_XX_ACC=0;
       if(TMR_XX_PRE != 500)
          P0=dat1[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
              if(TMR_XX_PRE>20)//固定到快
                 TMR_XX_PRE -=10;
            if(TMR_XX_PRE<500)//固定到慢
            TMR_XX_PRE +=20;
void mode2(void)
                         TMR_XX_ACC=0;
          P0=dat2[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
                 TMR_XX_PRE -=10;
            TMR_XX_PRE +=20;
void mode3(void)
                         TMR_XX_ACC=0;
          P0=dat3[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
                 TMR_XX_PRE -=10;
            TMR_XX_PRE +=20;
