查看: 1535|回復(fù): 1
單片機(jī)流水燈開啟慢到快,關(guān)閉快到慢,可切換模式,程序飛了 麻煩大佬指導(dǎo)下
ID:1002664 發(fā)表于 2022-1-25 14:19 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
試著大佬之前幫我的快慢流水程序讓它開時(shí)流水慢到快固定,關(guān)時(shí)快到慢關(guān)閉。加了切換模式和長(zhǎng)按開短按切換,程序keil沒報(bào)錯(cuò),仿真測(cè)試開始是慢到快,關(guān)沒有效果直接關(guān)閉,再開還是快的流水。。。應(yīng)該在哪里清零?保存鍵值是程序關(guān)在哪個(gè)模式開在哪個(gè)模式,怎么關(guān)的時(shí)候沒有快到慢在關(guān)。。。。我是不是哪里搞錯(cuò)了。。
#include <reg51.h>
sbit key1=P3^0;
typedef unsigned char u8;MODE;slow;
typedef unsigned int u16;count;
typedef unsigned long u32;
unsigned char dat1[4]={0xf1,0xf2,0xf4,0xf8};
unsigned char dat2[4]={0xfc,0xf9,0xf3,0xf6};
unsigned char dat3[4]={0xfe,0xfd,0xfb,0xf7};
bit Power_On = 1;
bit sign;
u16 TMR_XX_ACC;
u16 TMR_XX_PRE = 500;
u8 index = 0;
void mode1(void);
void mode2(void);
void mode3(void);
void key_Proc();
void Delay_XD(unsigned int x);
void key_Proc()
      if(key1==0)
         if(count<501)count++;
             if(count==500)//長(zhǎng)按
            sign=~sign;
            if(sign)
                     slow=MODE;//保存鍵值
                      MODE = 0;//關(guān)閉流水
                                        else MODE=slow; //還原鍵值
                                        if(count>20 && count<500)//短按
                                                ++MODE;
                                                if(MODE>3)
                                                        MODE=1;
                                  count = 0;
    while (1)
           key_Proc();
                            switch(MODE)
                         case 0: P0=0xFF;break;
                        case 1: mode1();break;
                        case 2: mode2();break;
                        case 3: mode3();break;
    Delay_XD(1);
      unsigned int i,j;
        for(i=0;i<x;i++)
               for(j=0;j<120;j++);//12T
void mode1(void)
   if(++TMR_XX_ACC >= TMR_XX_PRE)
                         TMR_XX_ACC=0;
       if(TMR_XX_PRE != 500)
          P0=dat1[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
              if(TMR_XX_PRE>20)//固定到快
                 TMR_XX_PRE -=10;
            if(TMR_XX_PRE<500)//固定到慢
            TMR_XX_PRE +=20;
void mode2(void)
                         TMR_XX_ACC=0;
          P0=dat2[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
                 TMR_XX_PRE -=10;
            TMR_XX_PRE +=20;
void mode3(void)
                         TMR_XX_ACC=0;
          P0=dat3[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
                 TMR_XX_PRE -=10;
            TMR_XX_PRE +=20;
ID:161164 發(fā)表于 2022-1-25 19:56 來自手機(jī) | 只看該作者
把sign轉(zhuǎn)做Power_On
