main。c
#include <msp430.h>
#include "NRF24L01.h"
#include "delay.h"
#define _EINT() __bis_SR_register(GIE)
#define _DINT() __bic_SR_register(GIE)
MSP430內(nèi)部看門狗初始化
void WDT_Init()
WDTCTL = WDTPW + WDTHOLD; //關(guān)閉看門狗
MSP430鎖相環(huán)初始化
void CLK_Init()
UCSCTL3 = SELREF_2; // Set DCO FLL reference = REFO
UCSCTL4 |= SELA_2; // Set ACLK = REFO
UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
// Loop until XT1,XT2 & DCO stabilizes - In this case only DCO has to stabilize
do
UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG);
// Clear XT2,XT1,DCO fault flags
SFRIFG1 &= ~OFIFG; // Clear fault flags
}while (SFRIFG1&OFIFG); // Test oscillator fault flag
__bis_SR_register(SCG0); // Disable the FLL control loop
UCSCTL1 = DCORSEL_5; // Select DCO range 16MHz operation
UCSCTL2 |= 121; // Set DCO Multiplier for 8MHz
// (N + 1) * FLLRef = Fdco
// (249 + 1) * 32768 = 8MHz
__bic_SR_register(SCG0); // Enable the FLL control loop
// Worst-case settling time for the DCO when the DCO range bits have been
// changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
// UG for optimization.
// 32 x 32 x 8 MHz / 32,768 Hz = 250000 = MCLK cycles for DCO to settle
__delay_cycles(250000);
void main(void)
WDT_Init();
CLK_Init(); //MCLK = SMCLK = 4M
NRF_Init(); //初始化NRF24L01
while(NRF_Check()) //檢查NRF24L01是否在位.
LED_L; //LED
LED_H;
RX_Mode();
_EINT();
NRF_RxPacket(rx_buf);
delay_ms(10);
Nrf2401.c
uchar TX_Address[5]={0x34,0x34,0x10,0x10,0x01};//設(shè)置發(fā)送端的地址
uchar RX_Address[5]={0x34,0x34,0x10,0x10,0x01};//設(shè)置接收端的地址
uchar tx_buf[TX_PLOAD_WIDTH]={0x00};
uchar rx_buf[RX_PLOAD_WIDTH]={0x00};
/****************************STM32程序***************************************/
//初始化24L01的IO口
void NRF_Init(void)
P4SEL=0;
P4DIR |= CSN + MOSI + SCK + CE; //SOMI , IRQ INPUT
P4OUT&=~(CSN + MOSI + SCK + CE);
CSN_H;
//P4IES |= IRQ; //下降沿置標(biāo)志位
//P4IE |= IRQ;
P1DIR |= BIT0; //LED
P1OUT |= BIT0; //LED
void RX_Mode(void)
CE_L;
//設(shè)置端址
//SPI_Write_Buf(WRITE_REG_NRF + TX_ADDR, TX_Address, TX_ADR_WIDTH);
SPI_Write_Buf(WRITE_REG_NRF + RX_ADDR_P0, TX_Address, TX_ADR_WIDTH);
//初始化配置字
SPI_WR_Reg(WRITE_REG_NRF + EN_AA, 0x01); // Enable Auto.Ack:Pipe0
SPI_WR_Reg(WRITE_REG_NRF + EN_RXADDR, 0x01); // Enable Pipe0
SPI_WR_Reg(WRITE_REG_NRF + SETUP_AW,0x03);
SPI_WR_Reg(WRITE_REG_NRF + SETUP_RETR,0x1a);
SPI_WR_Reg(WRITE_REG_NRF + RF_CH, 40);
SPI_WR_Reg(WRITE_REG_NRF + RX_PW_P0, TX_PLOAD_WIDTH);
SPI_WR_Reg(WRITE_REG_NRF + RF_SETUP, 0x0f);
//PWR_UP、TX_DS、IRQ、EN CRC、rX
SPI_WR_Reg(WRITE_REG_NRF + CONFIG, 0x0f); // Set PWR_UP bit, enable CRC(2 bytes)& Prim:RX. RX_DR enabled..
//清除標(biāo)志位
uchar sta=SPI_RD_Reg(STATUS); //讀取狀態(tài)寄存器的值
SPI_WR_Reg(WRITE_REG_NRF+STATUS,sta); //清除TX_DS,RX_DR或MAX_RT中斷標(biāo)志
//CE_H; // Set CE pin high to enable RX device
void TX_Mode(void)
CE_L;
//設(shè)置發(fā)送端的地址
SPI_Write_Buf(WRITE_REG_NRF+TX_ADDR,TX_Address,TX_ADR_WIDTH);//寫TX節(jié)點地址
SPI_Write_Buf(WRITE_REG_NRF+RX_ADDR_P0, RX_Address,RX_ADR_WIDTH); //設(shè)置TX節(jié)點地址,主要為了使能ACK
//初始化配置字
SPI_WR_Reg(WRITE_REG_NRF + EN_AA, 0x01); // Enable Auto.Ack:Pipe0//
SPI_WR_Reg(WRITE_REG_NRF + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
SPI_WR_Reg(WRITE_REG_NRF + RF_CH, 40); // Select RF channel 2.45G
SPI_WR_Reg(WRITE_REG_NRF + RF_SETUP, 0x0f); // TX_PWR:0dBm, Datarate:2Mbps,LNA:HCURR
SPI_WR_Reg(WRITE_REG_NRF + CONFIG, 0x0e); // Set PWR_UP bit, enable CRC(2 bytes)& Prim:TX. MAX_RT & TX_DS enabled..//
//清除TX_DS標(biāo)志位
SPI_WR_Reg(WRITE_REG_NRF+STATUS,sta); //清除TX_DS或MAX_RT中斷標(biāo)志
//CE_H;
//檢測24L01是否存在
//返回值:0,成功;1,失敗
uchar NRF_Check(void)
uchar buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
uchar i;
SPI_Write_Buf(WRITE_REG_NRF+TX_ADDR,buf,5);//寫入5個字節(jié)的地址.
SPI_Read_Buf(TX_ADDR,buf,5); //讀出寫入的地址
for(i=0;i<5;i++)if(buf[i]!=0XA5)break;
if(i!=5)return 1;//檢測24L01錯誤
return 0; //檢測到24L01
uchar NRF_TxPacket(uchar *txbuf)
uchar sta;
CE_L;
SPI_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數(shù)據(jù)到TX BUF 32個字節(jié)
CE_H;//啟動發(fā)送
delay_us(10);
while((P2IN&IRQ)!=0);//等待發(fā)送完成
if(sta&MAX_TX!=0)//達(dá)到最大重發(fā)次數(shù)
SPI_WR_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
return MAX_TX;
if(sta&TX_OK)//發(fā)送完成
LED_J;
return TX_OK;
return 0xff;//其他原因發(fā)送失敗
uchar NRF_RxPacket(uchar *rxbuf)
uchar sta;
CE_H; //CE 高電平>=130us,接收模式
delay_us(130);
if(sta&RX_OK)
CE_L;
LED_J;
SPI_Read_Buf(RD_RX_PLOAD,rx_buf,RX_PLOAD_WIDTH);//讀取數(shù)據(jù)
SPI_WR_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
return 0;
else return 1;
/***************************spi程序**************************/
uchar SPI_RW(uchar data)
uchar bit;
for(bit=0;bit<8;bit++)
{ //先高位,后低位
if(data & BIT7) MOSI_H;
else MOSI_L;
delay_us(2); //數(shù)據(jù)建立時間 1us
SCK_H;
delay_us(2);
data <<= 1; //一條指令的時間
if(SPI_IN) data |= BIT0; // capture current MISO bit
else data &=~BIT0;
SCK_L;
delay_us(1);
delay_us(1);
return(data); // return read data
uchar SPI_WR_Reg(uchar reg, uchar value)
uchar status;
CSN_L; // CSN low, init SPI transaction
status = SPI_RW(reg); // select register
SPI_RW(value); // ..and write value to it..
CSN_H; // CSN high again
return(status); // return nRF24L01 status byte
uchar SPI_RD_Reg(uchar reg)
uchar reg_val;
CSN_L; // CSN low, initialize SPI communication
SPI_RW(reg); // Select register to read from..
reg_val = SPI_RW(0); // ..then read registervalue
CSN_H; // CSN high, terminate SPI communication
return(reg_val); // return register value
/*接收緩沖區(qū)訪問函數(shù):主要用來在接收時讀取FIFO 緩沖區(qū)中的值。
基本思路就是通過READ_REG 命令把數(shù)據(jù)從接收FIFO(RD_RX_PLOAD)中讀出并存到數(shù)組里面去。*/
uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bytes)
uchar status,byte_ctr;
CSN_L; // Set CSN low, init SPI tranaction
status = SPI_RW(reg); // Select register to write to and read status byte
for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
pBuf[byte_ctr] = SPI_RW(0); // Perform SPI_RW to read byte from nRF24L01
CSN_H; // Set CSN high again
/*發(fā)射緩沖區(qū)訪問函數(shù):主要用來把數(shù)組里的數(shù)放到發(fā)射FIFO 緩沖區(qū)中。
基本思路就是通過WRITE_REG 命令把數(shù)據(jù)存到發(fā)射FIFO(WR_TX_PLOAD)中去。*/
uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes)
delay_us(1);
for(byte_ctr=0; byte_ctr<bytes; byte_ctr++) // then write all byte in buffer(*pBuf)
SPI_RW(*pBuf++);
/***************************中斷程序**************************/
#pragma vector=PORT2_VECTOR
__interrupt void p2(void)
LED_J; //LED
P2IFG =0;
NRF2401。h
#ifndef NRF24L01_H
#define NRF24L01_H
#include "msp430f5529.h"
#include "delay.h"
//POW_UP通過配置子寫入
#define CSN BIT2 //每次SPI前一個下降沿,SPI后上升沿
#define MOSI BIT0
#define MISO BIT1
#define SCK BIT2
#define CE BIT4
#define IRQ BIT5
#define CSN_H P2OUT |= CSN
#define CSN_L P2OUT &=~CSN
#define CE_H P3OUT |= CE
#define CE_L P3OUT &=~CE
#define SCK_H P3OUT |= SCK
#define SCK_L P3OUT &=~SCK
#define MOSI_H P3OUT |= MOSI
#define MOSI_L P3OUT &=~MOSI
#define SPI_IN P3IN&MISO
//SPI(NRF24L01)寄存器地址
#define CONFIG 0x00 //配置寄存器地址;bit0:1接收模式,0發(fā)射模式;bit1:電選擇;bit2:CRC模式;bit3:CRC使能;
//bit4:中斷MAX_RT(達(dá)到最大重發(fā)次數(shù)中斷)使能;bit5:中斷TX_DS使能;bit6:中斷RX_DR使能
#define EN_AA 0x01 //使能自動應(yīng)答功能 bit0~5,對應(yīng)通道0~5
#define EN_RXADDR 0x02 //接收地址允許,bit0~5,對應(yīng)通道0~5
#define SETUP_AW 0x03 //設(shè)置地址寬度(所有數(shù)據(jù)通道):bit1,0:00,3字節(jié);01,4字節(jié);02,5字節(jié);
#define SETUP_RETR 0x04 //建立自動重發(fā);bit3:0,自動重發(fā)計數(shù)器;bit7:4,自動重發(fā)延時 250*x+86us
#define RF_CH 0x05 //RF通道,bit6:0,工作通道頻率;
#define RF_SETUP 0x06 //RF寄存器;bit3:傳輸速率(0:1Mbps,1:2Mbps);bit2:1,發(fā)射功率;bit0:低噪聲放大器增益
#define STATUS 0x07 //狀態(tài)寄存器;bit0:TX FIFO滿標(biāo)志;bit3:1,接收數(shù)據(jù)通道號(最大:6);bit4,達(dá)到最多次重發(fā)
//bit5:數(shù)據(jù)發(fā)送完成中斷;bit6:接收數(shù)據(jù)中斷;
#define OBSERVE_TX 0x08 //發(fā)送檢測寄存器,bit7:4,數(shù)據(jù)包丟失計數(shù)器;bit3:0,重發(fā)計數(shù)器
#define CD 0x09 //載波檢測寄存器,bit0,載波檢測;
#define RX_ADDR_P0 0x0A //數(shù)據(jù)通道0接收地址,最大長度5個字節(jié),低字節(jié)在前
#define RX_ADDR_P1 0x0B //數(shù)據(jù)通道1接收地址,最大長度5個字節(jié),低字節(jié)在前
#define RX_ADDR_P2 0x0C //數(shù)據(jù)通道2接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
#define RX_ADDR_P3 0x0D //數(shù)據(jù)通道3接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
#define RX_ADDR_P4 0x0E //數(shù)據(jù)通道4接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
#define RX_ADDR_P5 0x0F //數(shù)據(jù)通道5接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
#define TX_ADDR 0x10 //發(fā)送地址(低字節(jié)在前),ShockBurstTM模式下,RX_ADDR_P0與此地址相等
#define RX_PW_P0 0x11 //接收數(shù)據(jù)通道0有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
#define RX_PW_P1 0x12 //接收數(shù)據(jù)通道1有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
#define RX_PW_P2 0x13 //接收數(shù)據(jù)通道2有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
#define RX_PW_P3 0x14 //接收數(shù)據(jù)通道3有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
#define RX_PW_P4 0x15 //接收數(shù)據(jù)通道4有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
#define RX_PW_P5 0x16 //接收數(shù)據(jù)通道5有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
#define NRF_FIFO_STATUS 0x17 //FIFO狀態(tài)寄存器;bit0,RX FIFO寄存器空標(biāo)志;bit1,RX FIFO滿標(biāo)志;bit2,3,保留
//bit4,TX FIFO空標(biāo)志;bit5,TX FIFO滿標(biāo)志;bit6,1,循環(huán)發(fā)送上一數(shù)據(jù)包.0,不循環(huán);
//24L01發(fā)送接收數(shù)據(jù)寬度定義
#define TX_ADR_WIDTH 5 //5字節(jié)的地址寬度
#define RX_ADR_WIDTH 5 //5字節(jié)的地址寬度
#define TX_PLOAD_WIDTH 32 //32字節(jié)的用戶數(shù)據(jù)寬度
#define RX_PLOAD_WIDTH 32 //32字節(jié)的用戶數(shù)據(jù)寬度
//NRF24L01寄存器操作命令
#define READ_REG_NRF 0x00 //讀配置寄存器,低5位為寄存器地址
#define WRITE_REG_NRF 0x20 //寫配置寄存器,低5位為寄存器地址
#define RD_RX_PLOAD 0x61 //讀RX有效數(shù)據(jù),1~32字節(jié)
#define WR_TX_PLOAD 0xA0 //寫TX有效數(shù)據(jù),1~32字節(jié)
#define FLUSH_TX 0xE1 //清除TX FIFO寄存器.發(fā)射模式下用
#define FLUSH_RX 0xE2 //清除RX FIFO寄存器.接收模式下用
#define REUSE_TX_PL 0xE3 //重新使用上一包數(shù)據(jù),CE為高,數(shù)據(jù)包被不斷發(fā)送.
#define NOP 0xFF //空操作,可以用來讀狀態(tài)寄存器
#define MAX_TX 0x10 //達(dá)到最大發(fā)送次數(shù)中斷
#define TX_OK 0x20 //TX發(fā)送完成中斷
#define RX_OK 0x40 //接收到數(shù)據(jù)中斷
extern uchar tx_buf[TX_PLOAD_WIDTH];
extern uchar rx_buf[RX_PLOAD_WIDTH];
void TX_Mode(void);
void RX_Mode(void);
uchar SPI_RW(uchar data);
uchar SPI_WR_Reg(uchar reg, uchar value);
uchar SPI_RD_Reg(uchar reg);
uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bytes);
uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes);
void NRF_Init(void);
uchar NRF_Check(void);
uchar NRF_TxPacket(uchar *txbuf);
uchar NRF_RxPacket(uchar *rxbuf);
/****************LED指示燈*********************/
#define LED_J P1OUT ^= BIT0
#define LED_H P1OUT |= BIT0
#define LED_L P1OUT &=~BIT0
#endif
