經(jīng)過驗(yàn)證是可行的
#include<reg51.h>
#include<intrins.h>
sbit K1=P1^0;
sbit LED=P0;
uchar a=0;
uchar mode=0;
void Key_block()
static uint KeyTime=0;
if(K1==0)
if(++KeyTime<=0)
--KeyTime;
if(KeyTime==5000
mode=1;
if(20<=KeyTime && KeyTime<3000
mode=2;
KeyTime=0;
void Led_Flow()
uint speed=6000;
static uint temp;
if(++temp>=speed)
temp=0;
switch (mode)
case 1:
P0=~(0xFE<<a);
a=++a%8;
break;
case 2:
P0=~(0xFE>>a);
a=++a%8;
break;
while (1)
Key_block();
Led_Flow();
