void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart)
/* Prevent unused argument(s) compilation warning */
UNUSED(huart);
/* NOTE: This function should not be modified, when the callback is needed,
the HAL_UART_TxHalfCpltCallback could be implemented in the user file
if(huart->Instance==USART1){
HAL_UART_Receive_DMA(&huart1,(uint8_t *)&aRxBuffer1,1);
if(huart->Instance==USART3){
HAL_UART_Receive_DMA(&huart3,(uint8_t *)&aRxBuffer3,1);
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
char buf[255],enter[32];
int i=1,temp=0;
uint8_t data[30]={"\n I have received:OK"};
char *map;
char key[25];
char value[4];
int year,mon,day,hour,min,sec;
char *ssid;
char *passwd;
UNUSED(huart);
Uart1_RxBuffer[Uart1_Rx_Cnt++]=aRxBuffer1;
if((Uart1_RxBuffer[Uart1_Rx_Cnt-1]==0x0A)&&(Uart1_RxBuffer[Uart1_Rx_Cnt-2]==0x0D))
HAL_UART_Transmit_DMA(&huart1,(uint8_t *)Uart1_RxBuffer, strlen(Uart1_RxBuffer));
if(strstr(Uart1_RxBuffer,"passwd")!=NULL)
strtok(Uart1_RxBuffer,":");
ssid=strtok(NULL,"_");
strtok(NULL,":");
passwd=strtok(NULL,"_");
strcat(AT_CWJAP,ssid);
strcat(AT_CWJAP,"\",\"");
strcat(AT_CWJAP,passwd);
strcat(AT_CWJAP,"\"\r\n");
my_printf("%s",AT_CWJAP);
strcpy(AT_CWJAP,"AT+CWJAP=\"");
Uart1_Rx_Cnt=0;
// strcpy(Uart1_RxBuffer,"");
Uart3_RxBuffer[Uart3_Rx_Cnt++]=aRxBuffer3;
if((Uart3_RxBuffer[Uart3_Rx_Cnt-1]==0x0A)&&(Uart3_RxBuffer[Uart3_Rx_Cnt-2]==0x0D))
osMailPut(myQueue06Handle,Uart3_RxBuffer);
//HAL_UART_Transmit_DMA(huart, data, strlen((char*)data));
if(strstr(Uart3_RxBuffer, "led") != NULL)//在a中查找b,如果存在,
osMessagePut(wifi_flagHandle,1,osWaitForever);
osMessagePut(wifi_flagHandle,0,osWaitForever);
if(strstr(Uart3_RxBuffer, "led_breath") != NULL)//在a中查找b,如果存在,
led=1;
if(strstr(Uart3_RxBuffer, "led_off") != NULL)//在a中查找b,如果存在,
led=0;
if(strstr(Uart3_RxBuffer, "led_on") != NULL)//在a中查找b,如果存在,
led=2;
if(strstr(Uart3_RxBuffer, "date") != NULL)//在a中查找b,如果存在,
strtok(Uart3_RxBuffer,"_");
year=atoi(strtok(NULL,"-"));
mon=atoi(strtok(NULL,"-"));
day=atoi(strtok(NULL,"_"));
hour=atoi(strtok(NULL,":"));
min=atoi(strtok(NULL,":"));
sec=atoi(strtok(NULL,":"));
strtok(NULL,"_");
ds1302_wirte_rig(0x8e,0x00);//關(guān)閉寫保護(hù)
ds1302_wirte_rig(0x80,dtoh(sec));//seconds10秒
ds1302_wirte_rig(0x82,dtoh(min));//minutes10分
ds1302_wirte_rig(0x84,dtoh(hour));//hours10時
ds1302_wirte_rig(0x86,dtoh(day));//date12日
ds1302_wirte_rig(0x88,dtoh(mon));//months5月
// ds1302_wirte_rig(0x8a,dtoh(week));//days星期三
ds1302_wirte_rig(0x8c,dtoh(year));//year2021年
ds1302_wirte_rig(0x8e,0x80);//關(guān)閉寫保護(hù)
// HAL_UART_Transmit_DMA(huart, (uint8_t*)value, strlen((char*)value));
if(strstr(Uart3_RxBuffer, "valid") != NULL)//在a中查找b,如果存在,
HAL_UART_Transmit_DMA(&huart3, AT_CIPSTART, strlen((char*) AT_CIPSTART));
Uart3_Rx_Cnt=0;
// memset(Uart3_RxBuffer,0,sizeof(Uart3_RxBuffer));
