查看: 1857|回復(fù): 0
基于STC89C52單片機(jī)LCD1602顯示字符及數(shù)字
ID:1007866 發(fā)表于 2022-3-2 22:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
內(nèi)容是基于STC89C52單片機(jī)LCD1602顯示字符及數(shù)字
#include<reg52.h>
uchar num;
uint i,j;
sbit rs=P3^5;
sbit wr=P3^6;
sbit lcden=P3^4;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table1[]="XXX";
uchar code table2[]="156824624";
void delay(uint x)
    for(i=x;i>0;i--)
    for(j=120;j>0;j--);
void write_com(uchar com)
    rs=0;
    wr=0;
    lcden=0;
    P0=com;
    lcden=1;
    delay(5);
    lcden=0;
void write_data(uchar dat)
    rs=1;
    wr=0;
    lcden=0;
    P0=dat;
    lcden=1;
    delay(5);
    lcden=0;
void init()
    write_com(0x38);
    write_com(0x08);
    write_com(0x01);
    write_com(0x06);
    write_com(0x0f);
    P0=0;
    dula=0;
    wela=0;
    init();
    for(num=0;num<3 ;num++)
        write_data(table1[num]);
        delay(300);
    write_com(0x80+0x40);
    for(num=0;num<10 ;num++)
        write_data(table2[num]);
        delay(300);
    while(1);
