查看: 2413|回復(fù): 11
神奇的事情,用STC15W204S單片機(jī)做的程序,按加速鍵200多次程序才能正常 請(qǐng)高人指點(diǎn)迷津
ID:879080 發(fā)表于 2022-3-3 16:46 | 顯示全部樓層 |閱讀模式
#include <REG51.H>
#include <intrins.h>
//#define  led P1
sfr     IAP_DATA    =   0xC2;
sfr     IAP_ADDRH   =   0xC3;
sfr     IAP_ADDRL   =   0xC4;
sfr     IAP_CMD     =   0xC5;
sfr     IAP_TRIG    =   0xC6;
sfr     IAP_CONTR   =   0xC7;
unsigned char RunMode;
void  cc(uint addr);
void  xcx(uint addr,uchar dat);
uchar dcx(uint addr);
void  Q0();
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
函數(shù):擦除某一扇區(qū)(每個(gè)扇區(qū)512字節(jié))
入口:addr = 某一扇區(qū)首地址
void cc(uint addr)// 0x83(晶振<5M)   0x82(晶振<10M)   0x81(晶振<20M)   0x80(晶振<40M)
    IAP_CONTR = 0x81;
    //IAP_TPS = 12;
    IAP_CMD   = 3;
    IAP_ADDRL = addr;
    IAP_ADDRH = addr>>8;
        EA =0;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    _nop_();
    Q0();
函數(shù):寫(xiě)一字節(jié)
入口:addr = 扇區(qū)單元地址 , dat = 待寫(xiě)入數(shù)據(jù)
    IAP_CONTR = 0x81;
  //IAP_TPS = 12;
    IAP_CMD   = 2;
    IAP_ADDRL = addr;
    IAP_DATA  = dat;
    EA = 0;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    _nop_();
    Q0();         // 關(guān)閉ISP/IAP
函數(shù):讀一字節(jié)
出口:dat  = 讀出的數(shù)據(jù)
    uchar dat;
        IAP_CONTR = 0x81;
  //IAP_TPS = 12;
    IAP_CMD   = 1;         // 用戶可以對(duì)"Data Flash/EEPROM區(qū)"進(jìn)行字節(jié)讀
    IAP_ADDRL = addr;
    EA = 0;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    _nop_();
    dat = IAP_DATA;         // 取出數(shù)據(jù)
        return dat;
函數(shù):關(guān)閉ISP/IAP操作
void Q0()
    IAP_CONTR = 0;            // 關(guān)閉IAP功能
    IAP_CMD   = 0;            // 待機(jī)模式,無(wú)ISP操作
    IAP_TRIG  = 0;
        IAP_ADDRH=0x80;
        IAP_ADDRL=0;
        EA =1;            // 關(guān)閉IAP功能, 清與ISP有關(guān)的特殊功能寄存器
void  Delay1ms(unsigned int count)
        unsigned int i,j;
        for(i=0;i<count;i++)
                for(j=0;j<120;j++);
uchar code led0[]={0xd6,0xd5,0xd3,0xce,0xcd,0xcb,
uchar code led1[]={0xf8,0xff,0xf8,0xff,0xf8,0xff,0xf8,0xff,0xf8,0xff,0xf8,0xff,
                                   0xc7,0xff,0xc7,0xff,0xc7,0xff,0xc7,0xff,0xc7,0xff,0xc7,0xff,
uchar code led2[8]={0xde,0xdd,0xdb,0xd7,0xee,0xed,0xeb,0xe7};
uchar code led3[28]={0xde,0xdc,0xe8,0xe0,0xd0,0xd0,0xe0,0xe0,0xdf,0xdf,0xee,0xec,
                                        0xd8,0xd0,0xe0,0xe0,0xd0,0xdf,0xef,0xee,0xdc,0xd8,0xe0,0xe0,
                                        0xd0,0xd0,0xef,0xef,
uchar code led4[90]={0xce,0xcd,0xcb,0xf6,0xf5,0xf3,0xce,0xcd,0xcb,0xf6,0xf5,0xf3,
                                   0xce,0xcd,0xcb,0xf6,0xf5,0xf3,0xcb,0xcd,0xce,0xf3,0xf5,0xf6,
                                        0xcb,0xcd,0xce,0xf3,0xf5,0xf6,0xcb,0xcd,0xce,0xf3,0xf5,0xf6,
                                        0xcf,0xcf,0xcf,0xf0,0xf0,0xf0,0xcf,0xcf,0xcf,0xf0,0xf0,0xf0,
uchar code led5[10]={0xfe,0xfd,0xfb,0xf7,0xef,0xde,0xdd,0xdb,0xd7,0xcf
uchar code led6[12]={0xde,0xdc,0xd8,0xf0,0xe0,0xe0,0xc0,0xc0,0xc0,0xe0,0xff,0xff};
uchar code led7[6]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
uchar code led8[12]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff};
uchar code led9[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xef,0xf7,0xfb,0xfd,
                                        0xc1,0xc2,0xc4,0xc8,0xd0,0xe0,0xd0,0xc8,0xc4,0xc2,
                                        0xff,0xff,0xff,0x00,0x00,0x00,0xff,0xff,0xff,0x00,0x00,0x00,
unsigned char GetKey(void)
        unsigned char KeyTemp,CheckValue,Key = 0x00;
        CheckValue = P3&0x4c;
        if(CheckValue==0x4c)
                return 0x00;
        Delay1ms(10);
        KeyTemp = P3&0x4c;
        if(KeyTemp==CheckValue)
                return 0x00;
        if(!(CheckValue&0x04))
                Key|=0x01;
        if(!(CheckValue&0x08))
                Key|=0x02;
        if(!(CheckValue&0x40))
                Key|=0x04;
        return Key;
unsigned int TimerCount,SystemSpeed,SystemSpeedIndex;
void InitialTimer0(void)
    TMOD=0x01;
        TH0=(65536-3000)/256;
        TL0=(65536-3000)%256;
        ET0=1;
        TR0=1;
    EA = 1;
unsigned int code SpeedCode[]={5,   8,  10,  14,  17,  20,  30,
                               40,  50,  60,  70,  80,  90, 100, 120, 140, 160,
                              180, 200,300,400,500,600,700,800,900,1000};//27
void SetSpeed(unsigned char Speed)
         SystemSpeed =SpeedCode[Speed];
void LEDShow(unsigned int LEDStatus)
        P1 = LEDStatus;
void InitialCPU(void)
        RunMode = dcx(0x0000);
        TimerCount = 0;
        SystemSpeedIndex = dcx(0x0200);
                 // SystemSpeedIndex = 10;
        P3 = 0xff;
        Delay1ms(500);
        //P1 = 0xff;
        P3 = 0xFF;
       SetSpeed( SystemSpeedIndex);
//Mode 0
unsigned int num0,num1,num2,num3,num4,num5,num6,num7,num8,num9,LEDIndex = 0;
bit LEDDirection=1 ,LEDFlag=1 ;
void Mode_0(void)
        LEDShow(LEDIndex=led0[num0]);
        num0++;
                if(num0==6)
                num0=0;
//Mode 1
void Mode_1(void)
        LEDShow(LEDIndex=led1[num1]);
                num1++;
         if(num1==48)
        num1=0;
//Mode 2
void Mode_2(void)
        LEDShow(LEDIndex=led2[num2]);
                num2++;
         if(num2==8)
        num2=0;
//Mode 3
void Mode_3(void)
        LEDShow(LEDIndex=led3[num3]);
                num3++;
         if(num3==28)
        num3=0;
void Mode_4(void)
        LEDShow(LEDIndex=led4[num4]);
                num4++;
         if(num4==90)
                num4=0;
void Mode_5(void)
  LEDShow(LEDIndex=led5[num5]);
                num5++;
         if(num5==10)
                num5=0;
void Mode_6(void)
                LEDShow(LEDIndex=led6[num6]);
                num6++;
         if(num6==12)
                num6=0;
void Mode_7(void)
                LEDShow(LEDIndex=led7[num7]);
                num7++;
         if(num7==6)
                num7=0;
void Mode_8(void)
                LEDShow(LEDIndex=led8[num8]);
                num8++;
         if(num8==12)
                num8=0;
void Mode_9(void)
                LEDShow(LEDIndex=led9[num9]);
                num9++;
         if(num9==236)
                num9=0;
void TimerEventRun(void)
        if(RunMode==0x00)
                Mode_0();
        else if(RunMode ==0x01)
                Mode_1();
       else if(RunMode ==0x02)
                Mode_2();
        else if(RunMode ==0x03)
                Mode_3();
        else if(RunMode ==0x04)
                Mode_4();
                else if(RunMode ==0x05)
                Mode_5();
                else if(RunMode ==0x06)
                Mode_6();
        else if(RunMode ==0x07)
                Mode_7();
        else if(RunMode ==0x08)
                Mode_8();
                else if(RunMode ==0x09)
                Mode_9();
void Timer0(void) interrupt 1 using 1
        if(++TimerCount>=SystemSpeed)
                                TimerCount = 0;
                                TimerEventRun();
unsigned int MusicIndex=1 ;
void KeyDispose(unsigned char Key)
        if(Key&0x01)
                LEDDirection = 1;
                LEDIndex = 0;
                LEDFlag = 1;
                RunMode = (RunMode+1)%10;
                            cc(0x0000);
                                    xcx(0x0000, RunMode);
        if(Key&0x02)
                if(SystemSpeedIndex>0)
                        --SystemSpeedIndex;
                                                SetSpeed(SystemSpeedIndex);
                                            cc(0x0200);
                                     xcx(0x0200,SystemSpeedIndex);
        if(Key&0x04)
                if(SystemSpeedIndex<26)
                        ++SystemSpeedIndex;
                                        cc(0x0200);
                unsigned char Key ;
                P1M0 = 0x00;
                   P1M1 = 0x00;
                //P3M0 = 0x00;
            //P3M1 = 0x00;
        InitialCPU();
        InitialTimer0();
                Key = GetKey();
                if(Key!=0x00)
                        KeyDispose(Key);
ID:584814 發(fā)表于 2022-3-3 20:36 | 顯示全部樓層
很認(rèn)真地看完了程序,竟然沒(méi)看出哪個(gè)是加速鍵、在哪里加速、200多次后正常是否能上高速 ......
ID:86926 發(fā)表于 2022-3-4 08:32 | 顯示全部樓層
可能是上電后void InitialCPU(void)中的SetSpeed( SystemSpeedIndex);前沒(méi)有初始化SystemSpeedIndex;讀到的內(nèi)部數(shù)據(jù)是0xff就拿來(lái)用了
ID:879080 發(fā)表于 2022-3-4 09:10 | 顯示全部樓層
man1234567 發(fā)表于 2022-3-3 20:36
     if(Key&0x02)
                        --SystemSpeedIndex;
                                            cc(0x0200);
按這個(gè)按鍵200多次后程序才能正常運(yùn)行
ID:879080 發(fā)表于 2022-3-4 09:18 | 顯示全部樓層
本帖最后由 hanxingyijian 于 2022-3-4 09:20 編輯
藍(lán)魄 發(fā)表于 2022-3-4 08:32
可能是上電后void InitialCPU(void)中的SetSpeed( SystemSpeedIndex);前沒(méi)有初始化SystemSpeedIndex;讀到 ...
當(dāng)我用STC12C2052AD單片機(jī)的時(shí)候,下載第2次程序就能正常工作(當(dāng)然要改擦寫(xiě)寄存器和相應(yīng)的命令,程序不改)
ID:213173 發(fā)表于 2022-3-4 09:36 | 顯示全部樓層
hanxingyijian 發(fā)表于 2022-3-4 09:10
if(Key&0x02)
功能似乎很簡(jiǎn)單,洋洋灑灑一大堆代碼寫(xiě)的很復(fù)雜,看著頭大。你把具體的功能要求講清楚才好判斷。
ID:161164 發(fā)表于 2022-3-4 12:29 | 顯示全部樓層
同意,應(yīng)加上判斷程序以防讀錯(cuò)地址
  1. void InitialCPU(void)
  2. {
  3.
  4.         RunMode = dcx(0x0000);
  5.         TimerCount = 0;
  6.         SystemSpeedIndex = dcx(0x0200);
  7.                 if(SystemSpeedIndex > 26)
  8.                 {
  9.                         SystemSpeedIndex = 10;
  10.                 }
  11.
  12.         P3 = 0xff;
  13.         Delay1ms(500);
  14.         //P1 = 0xff;
  15.         P3 = 0xFF;
  16.
  17.        SetSpeed( SystemSpeedIndex);
  18. }
ID:139866 發(fā)表于 2022-3-4 13:12 | 顯示全部樓層
要在我們公司,代碼注釋寫(xiě)成這樣, 頭都給你錘爆
ID:123289 發(fā)表于 2022-3-4 13:57 | 顯示全部樓層
證明一下,你按的200多次,每次都被程序“收到”了。
提示:設(shè)整個(gè)程序執(zhí)行時(shí)間是100,其中讀鍵程序發(fā)生在50-70之間,這時(shí)只有在50-70之間發(fā)生的按鍵才被認(rèn)可。
ID:879080 發(fā)表于 2022-3-4 15:09 | 顯示全部樓層
lkc8210 發(fā)表于 2022-3-4 12:29
按您的方法問(wèn)題解決了。多謝指導(dǎo)。我想增加一個(gè)P1口漸亮漸滅的程序。卻不知道能不能實(shí)現(xiàn)
ID:879080 發(fā)表于 2022-3-4 15:12 | 顯示全部樓層
天ノ憶 發(fā)表于 2022-3-4 13:12
見(jiàn)諒!我是個(gè)剛步入單片機(jī)應(yīng)用大門(mén)的小白,有很多問(wèn)題還需要跟師傅們學(xué)習(xí)。
ID:879080 發(fā)表于 2022-3-4 15:27 | 顯示全部樓層
wulin 發(fā)表于 2022-3-4 09:36
主要是我剛學(xué)習(xí),想做個(gè)有趣的練練,功能是三個(gè)按鍵控制6路輸出,一個(gè)按鍵調(diào)花樣,另外2個(gè)按鍵調(diào)快慢。稍微復(fù)雜點(diǎn)的都無(wú)從下手。如果讓熟練的師傅們寫(xiě)程序,代碼估計(jì)可以少很多。感謝!
