查看: 945|回復: 0
單片機中斷和按鍵結合控制數碼管 程序問題
ID:1007138 發(fā)表于 2022-3-6 12:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
為什么我輕輕一碰電源第一個計分會變化啊,是我電源的問題還是中斷的問題?
單片機源程序如下:
#include <reg52.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
sbit K1 = P3^4;
uint point1 = 0,point2 = 0;
uchar code duan[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar disp[8] = {0,0,0,0x40,0x40,0,0,0};
void delay(uint z) {
        uint y;
        for (;z>0;z--)
                for (y = 0; y < 110; y++);
void Display() {
        uchar i = 0;
        disp[0] = duan[point1 / 100];
        disp[1] = duan[point1 % 100 / 10];
        disp[2] = duan[point1 % 10];
        disp[5] = duan[point2 / 100];
        disp[6] = duan[point2 % 100 / 10];
        disp[7] = duan[point2 % 10];
        for (i = 0; i < 8; i++) {
                P0 = 0x00;
                P1 &= 0xf8;
                P1 |= i;
                P0 = disp[ i];
                delay(1);
void main() {           //觸碰電源時第一個計分會變動,這是為什么?
        IT1 = 1;
        IT0 = 1;
        PX0 = 1;
          IE = 0x85;
        while (1) {
                if (!K1) point1 = 0,point2 = 0;
                Display();
void EX_INT0() interrupt 0 {
        //EA = 0;
        delay(10);
        point1++;
        //EA = 1;
void EX_INT1() interrupt 2 {
        //EA = 0;
        delay(10);
        point2++;
        //EA = 1;
Powered by 單片機教程網
