查看: 1004|回復(fù): 0
關(guān)于步進(jìn)電機(jī) 這個單片機(jī)程序怎么實(shí)現(xiàn)正反轉(zhuǎn)的?
ID:569299 發(fā)表于 2022-3-14 16:35 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
  switch(capstastus)
                   case 5: EPwm1Regs.AQCTLA.all=0x90;EPwm1Regs.AQCSFRC.all=0x8;//A+
                    EPwm2Regs.AQCTLB.all=0x90;EPwm2Regs.AQCSFRC.all=0x2;//B-
                EPwm3Regs.AQCSFRC.all=0x0a;
                                break;
            case 1:
                    EPwm2Regs.AQCSFRC.all=0x0a;
                    EPwm3Regs.AQCTLB.all=0x90;EPwm3Regs.AQCSFRC.all=0x2;//C-
                    break;
            case 3: EPwm1Regs.AQCSFRC.all=0x0a;
                        EPwm2Regs.AQCTLA.all=0x90;EPwm2Regs.AQCSFRC.all=0x8;//B+
                EPwm3Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCTLB.all=0x90;//C-
                break;
            case 2: EPwm1Regs.AQCTLB.all=0x90;EPwm1Regs.AQCSFRC.all=0x2;//A-
                                break;
            case 6: EPwm1Regs.AQCTLB.all=0x90;EPwm1Regs.AQCSFRC.all=0x2;//A-
                        EPwm3Regs.AQCTLA.all=0x90;EPwm3Regs.AQCSFRC.all=0x8;//C+
                        break;
            case 4: EPwm1Regs.AQCSFRC.all=0x0a;
                                break;
            switch(capstastus)//ir2136 的hin和lin是反向的
                           case 5: EPwm1Regs.AQCSFRC.all=0x2;EPwm1Regs.AQCTLB.all=0x90;EPwm2Regs.AQCTLA.all=0x90;EPwm2Regs.AQCSFRC.all=0x8;EPwm3Regs.AQCSFRC.all=0xA;break;//h1 rise
                           case 1: EPwm1Regs.AQCSFRC.all=0xA;EPwm2Regs.AQCTLB.all=0x90;EPwm2Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCSFRC.all=0x8;EPwm3Regs.AQCTLA.all=0x90;//h3 fall
                           case 3:  EPwm1Regs.AQCTLB.all=0x90;EPwm1Regs.AQCSFRC.all=0x2;EPwm2Regs.AQCSFRC.all=0x0a;EPwm3Regs.AQCTLA.all=0x90;EPwm3Regs.AQCSFRC.all=0x8;break;//h2 rise
                           case 2: EPwm1Regs.AQCSFRC.all=0x8;EPwm1Regs.AQCTLA.all=0x90;EPwm2Regs.AQCTLB.all=0x90;EPwm2Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCSFRC.all=0xA;break;//h1 fall
                           case 6: EPwm1Regs.AQCTLA.all=0x90;EPwm1Regs.AQCSFRC.all=0x8;EPwm2Regs.AQCSFRC.all=0x0a;EPwm3Regs.AQCTLB.all=0x90;EPwm3Regs.AQCSFRC.all=0x2;break;//h3 rise
                           case 4: EPwm1Regs.AQCSFRC.all=0xA;EPwm2Regs.AQCTLA.all=0x90;EPwm2Regs.AQCSFRC.all=0x8;EPwm3Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCTLB.all=0x90;break;//h2 fall
有哪位大佬能夠知道這個電機(jī)是怎么實(shí)現(xiàn)正反轉(zhuǎn)的,謝謝了
