查看: 4561|回復(fù): 0
單片機(jī)溫濕度檢測(cè)RS485多機(jī)通信仿真+主、從機(jī)源程序
ID:1011991 發(fā)表于 2022-3-22 14:10 | 顯示全部樓層 |閱讀模式
#include "reg52.h"
#include "lcd1206.h"
sbit Rs485_die=P3^7; //高電平輸出  低電平輸入
sbit Data=P1^0;              //傳感器接口
sbit KEY1=P1^1;              //傳感器接口
u8 tempt1;
unsigned char RH_TP[6];
void serial_init(void);
u8 SEND_data(u8 addr);
void delay_1ms(unsigned int t);
void DISplay_RT_1()           //傳感器1的數(shù)據(jù)        顯示
///顯示溫度
    lcd_pos(0X03);
         LcdWriteData(RH_TP[0]+'0');
        lcd_pos(0X04);
         LcdWriteData(RH_TP[1]+'0');
///顯示濕度
     lcd_pos(0X43);
         LcdWriteData(RH_TP[2]+'0');
        lcd_pos(0X44);
         LcdWriteData(RH_TP[3]+'0');
void DISplay_RT_2()           //傳感器2的數(shù)據(jù)
///顯示溫度
    lcd_pos(0X0C);
        lcd_pos(0X0D);
///顯示濕度
     lcd_pos(0X4C);
        lcd_pos(0X4D);
main()
        LcdInit();
        serial_init();
  Rs485_die=1;
  TB8=1;SM2=0; Rs485_die=1;         //fa song di zi
lcd_pos(0x00);                           ///溫度1
LcdWriteData( 'T');
  lcd_pos(0x01);
LcdWriteData('1');
  lcd_pos(0x02);
LcdWriteData( ':');
  lcd_pos(0x06);
LcdWriteData( 'C');
                                                        //濕度1
lcd_pos(0x40);
LcdWriteData( 'R');
  lcd_pos(0x41);
LcdWriteData('1');
  lcd_pos(0x42);
LcdWriteData( ':');
  lcd_pos(0x46);
LcdWriteData( 'H');
  lcd_pos(0x09);                ///溫度2
LcdWriteData( 'T');
  lcd_pos(0x0A);
LcdWriteData( '2');
  lcd_pos(0x0B);
LcdWriteData( ':');
   lcd_pos(0x0F);
LcdWriteData( 'C');
   lcd_pos(0x49);                ///濕度2
LcdWriteData( 'T');
  lcd_pos(0x4A);
LcdWriteData( '2');
  lcd_pos(0x4B);
LcdWriteData( ':');
   lcd_pos(0x4F);
LcdWriteData( 'H');
  Data=1;
         TB8=1;
     delay_1ms(5);
         SEND_data(0x01);         //獲取主機(jī)一的數(shù)據(jù)
         delay_1ms(5);
            DISplay_RT_1();              //顯示獲取的數(shù)據(jù)
         TB8=1;
     delay_1ms(5);
         SEND_data(0x02);         //獲取主機(jī)2的數(shù)據(jù)
         delay_1ms(5);
            DISplay_RT_2();              //顯示獲取的數(shù)據(jù)
         if(KEY1==0)
          Data=0;
         }else
             Data=1;
unsigned int x,y;
for(x=t;x>0;x--)
  for(y=110;y>0;y--);
//緩沖區(qū)初始化
//串口初始化函數(shù)
TMOD=0x20; //定時(shí)器1工作于方式2
TH1=0xfd;
TL1=0xfd; //波特率為9600
PCON=0;
SCON=0xd0;  //串口工作于方式3
TR1=1;  //開啟定時(shí)器
TI=0;        //                                                           清除中斷標(biāo)志位
RI=0;
//ES=1;                                                //打開接收中斷
//EA=1;                                                //打開總中斷
SM2=0;
//發(fā)送數(shù)據(jù)函數(shù)
      u8 i=0;
      Rs485_die=1;
      TB8=1;
          TI=0;
          SBUF=addr;
          while(!TI);
          TI=0;
          Rs485_die=0;
          for(i=0;i<6;i++)
          RI=0;
          while(!RI);
          RH_TP[ i] =SBUF;
          RI=0;
         Rs485_die=1;
Keil代碼與Proteus仿真下載: 溫濕度檢測(cè)單片機(jī)485多機(jī)通信.zip (145.06 KB, 下載次數(shù): 155)
