本人小白一個(gè)
由于PIN44對(duì)應(yīng)的引腳PC4沒(méi)有定時(shí)器,于是將PIN44和43連接起來(lái)了。使用43對(duì)應(yīng)的引腳PA7,配置為上拉輸入,使用TIM8_CH1下降沿捕獲計(jì)數(shù),求指點(diǎn)了哪里出問(wèn)題了計(jì)數(shù)進(jìn)不去timer.c文件
TIM_ICInitTypeDef TIM8_ICInitStructure;
void TIM8_Int_Init(u32 arr, u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE); //使能TIM8時(shí)鐘
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE); //使能GPIOC時(shí)鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //PC4 清除之前設(shè)置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//復(fù)用功能
// GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
GPIO_Init(GPIOC, &GPIO_InitStructure);
// GPIO_PinAFConfig(GPIOC,GPIO_PinSource4,GPIO_AF_TIM8);
//初始化定時(shí)器8 TIM8
TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)定計(jì)數(shù)器自動(dòng)重裝值
TIM_TimeBaseStructure.TIM_Prescaler = psc; //預(yù)分頻器
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
// TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; //為0,溢出一次就進(jìn)中斷一次,高級(jí)定時(shí)器必須設(shè)置
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上計(jì)數(shù)模式
TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
// TIM_ClearITPendingBit(TIM8,TIM_IT_Update); //清除中斷標(biāo)志位,避免第一次自動(dòng)進(jìn)入中斷一次
// TIM_TIxExternalClockConfig( TIM8, TIM_TIxExternalCLK1Source_TI1,TIM_ICPolarity_Rising, 0xF );
//初始化TIM8輸入捕獲參數(shù)
TIM8_ICInitStructure.TIM_Channel = TIM_Channel_1; //CC1S=01 選擇輸入端 IC1映射到TI1上
TIM8_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling; //下降沿捕獲
TIM8_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上
TIM8_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置輸入分頻,不分頻
TIM8_ICInitStructure.TIM_ICFilter = 0x00;//IC1F=0000 配置輸入濾波器 不濾波
TIM_ICInit(TIM8, &TIM8_ICInitStructure);
//中斷分組初始化
NVIC_InitStructure.NVIC_IRQChannel = TIM8_UP_TIM13_IRQn; //TIM8中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //先占優(yōu)先級(jí)2級(jí)
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //從優(yōu)先級(jí)0級(jí)
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
NVIC_Init(&NVIC_InitStructure); //根據(jù)NVIC_InitStruct中指定的參數(shù)初始化外設(shè)NVIC寄存器
TIM_ITConfig(TIM8, TIM_IT_Update | TIM_IT_CC1, ENABLE); //允許更新中斷 ,允許CC1IE捕獲中斷
TIM_Cmd(TIM8, ENABLE ); //使能定時(shí)器2
u8 TIM8CH1_CAPTURE_STA = 0; //輸入捕獲狀態(tài)
u32 TIM8CH1_CAPTURE_VAL; //輸入捕獲值
u32 TIM8CH1_CAPTURE_STB = 0; //計(jì)數(shù)
//捕獲狀態(tài)
//[7]:0,沒(méi)有成功的捕獲;1,成功捕獲到一次.
//[6]:0,還沒(méi)捕獲到低電平;1,已經(jīng)捕獲到低電平了.
//[5:0]:捕獲低電平后溢出的次數(shù)(對(duì)于 32 位定時(shí)器來(lái)說(shuō),1us 計(jì)數(shù)器加 1,溢出時(shí)間:4294 秒)
//定時(shí)器2中斷服務(wù)程序
void TIM8_UP_TIM13_IRQHandler(void)
if((TIM8CH1_CAPTURE_STA & 0X40) == 0) //還未成功捕獲
if (TIM_GetITStatus(TIM8, TIM_IT_Update) != RESET)
if(TIM8CH1_CAPTURE_STA & 0X80) //已經(jīng)捕獲到低電平了
if((TIM8CH1_CAPTURE_STA & 0X3F) == 0X3F) //高電平太長(zhǎng)了
TIM8CH1_CAPTURE_STA |= 0X40; //標(biāo)記成功捕獲了一次
TIM8CH1_CAPTURE_VAL = 0XFFFFFFFF;
else TIM8CH1_CAPTURE_STA++;
if (TIM_GetITStatus(TIM8, TIM_IT_CC1) != RESET)//捕獲1發(fā)生捕獲事件
if(TIM8CH1_CAPTURE_STA & 0X80) //捕獲到一個(gè)上升沿
TIM8CH1_CAPTURE_STA |= 0X40; //標(biāo)記成功捕獲到一次下降沿
TIM8CH1_CAPTURE_VAL = TIM_GetCapture1(TIM8); //獲取當(dāng)前的捕獲值
TIM8CH1_CAPTURE_STB++;
TIM_OC1PolarityConfig(TIM8, TIM_ICPolarity_Falling); //CC1P=0 設(shè)置為下降沿捕獲
else //還未開(kāi)始,第一次捕獲上升沿
TIM8CH1_CAPTURE_STA = 0; //清空
TIM8CH1_CAPTURE_VAL = 0;
TIM8CH1_CAPTURE_STA |= 0X80; //標(biāo)記捕獲到了下降沿
TIM_Cmd(TIM8, DISABLE);
TIM_SetCounter(TIM8, 0);
TIM_OC1PolarityConfig(TIM8, TIM_ICPolarity_Rising); //CC1P=1 設(shè)置為上升沿捕獲
TIM_Cmd(TIM8, ENABLE);
TIM_ClearITPendingBit(TIM8, TIM_IT_CC1 | TIM_IT_Update); //清除中斷標(biāo)志位
main
TIM8_Int_Init(10000-1,8400-1);
while(1){
if(TIM8CH1_CAPTURE_STA&0X40)//成功捕獲到了一次低電平
printf("count:%d \r\n",TIM8CH1_CAPTURE_STB);
TIM8CH1_CAPTURE_STA=0; //開(kāi)啟下一次捕獲
delay_ms(1000);
(9.01 KB, 下載次數(shù): 55)
2022-3-25 13:41 上傳
