怎樣將PT100將AD轉(zhuǎn)換成溫度,算法不會,所以精度太大
#include <reg51.h>
#include<intrins.h>
#include<math.h>
uchar code str1[]={"Temper" } ;
uchar code str2[]={" " } ;
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
sbit CS=P2^4;
sbit CLK=P2^5;
sbit DIDO=P2^7;
sbit be=P3^4;
sbit jdq=P3^3;
sbit led1=P3^5;
sbit led2=P3^6;
uchar flag,num,count,k1num,k2num,
k3num,k4num,a,b,c,d,e,f;
char tempmax,tempmin;//設(shè)定的溫度
uchar dat;
long int temp;
double deal,U ;//電阻值,溫度對電阻的變化量(Q
//延時函數(shù)
void delay(uint z)
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<114;y++);}
//蜂鳴器子程序
void di()
be=0;delay(100);be=1;}
// 忙碌
bit lcd_busy(void)
bit result;
lcdrs=0;//根據(jù)規(guī)定,RS為低電平,RW為高電平時,可以讀狀態(tài)
lcdrw=1;
lcden=1; //E=1,才允許讀寫
_nop_();//空操作
_nop_();
_nop_();
_nop_();//空操作四個機器周期,給硬件反應(yīng)時間
result=(bit)(P0&0x80); //將忙碌標(biāo)志電平賦給result
lcden=0;//將E恢復(fù)低電平
return result;
//寫命令函數(shù)
void write_com(uchar com)
while( lcd_busy());
lcdrs=0;lcdrw=0;lcden=0;
_nop_();_nop_();
P0=com;delay(5);
lcden=1;delay(5);
lcden=0;}
//寫數(shù)據(jù)函數(shù)
void write_date(uchar date)
while( lcd_busy());
lcdrs=1;
lcdrw=0;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
//LCD1602顯示函數(shù)
void lcd1602_display(uchar *p,uchar*q)
write_com(0x80+0x40);
while(*p!='\0')
write_date(*p);
p++;
delay(1);
write_com(0x80+0x48);
while(*q!='\0')
write_date(*q);
q++;
delay(1);
//D0832初始話顯示 ///////////////////////
void Init_AD0808()
lcd_init();
lcd1602_display(str1,str2);
void delay_ADC(uint i)
while(i--);
uchar ADC0808()
uchar i;
CS=1;delay_ADC(5) ;
CLK =1; delay_ADC(5) ;
CS = 0;
DIDO = 1;CLK = 0; delay_ADC(5) ;
CLK =1; DIDO =1; delay_ADC(5) ;
CLK = 0; CLK = 1; delay_ADC(5) ;
DIDO = 0; CLK = 0; delay_ADC(5) ;
CLK = 1;DIDO =1; delay_ADC(5) ;
for(i = 0; i< 8; i++)
if(DIDO) dat |=0x01;
CLK =1;
dat <<= 1; delay_ADC(5) ;
U=5.0/255.0*dat;
deal=10.0*59.9*U;
temp=(long int)deal;
tempmax=temp/10;tempmin=temp/10;
return temp;
CS= 1;
//AD 轉(zhuǎn)換
void AD0808_display()
disdata[0]=temp/1000+0x30;//百位數(shù)
disdata[1]=temp/100%10+0x30;//十位數(shù)
disdata[2]=temp/10%10+'0';//個位數(shù)
disdata[3]=temp%10+0x30;//小數(shù)位
if(disdata[0]==0x30)
disdata[0]=0x20;//如果百位為0,不顯示
if(disdata[1]==0x30)
disdata[1]=0x20;//如果百位為0,十位為0也不顯示
write_com(0x80+0x49);
write_date(disdata[0]);//顯示百位
write_com(0x80+0x4a);
write_date(disdata[1]);//顯示十位
write_com(0x80+0x4b);
write_date(disdata[2]);//顯示個位
write_com(0x80+0x4c);
write_date(0x2e);//顯示小數(shù)點
write_com(0x80+0x4d);
write_date(disdata[3]);//顯示小數(shù)位
if((tempmax>290)||(tempmin<30))
{jdq=0;be=~be;led2=0;delay(50);}
{led2=1;}
//主函數(shù)
TMOD=0x01;
TH0=(65536-46080)/256;
TL0=(65536-46080)%256;
EA=1;
ET0=1;
TR0=1;
lcd_init();
Init_AD0808();
write_com(0x80);
ADC0808();
AD0808_display();
tempmax = temp/10;
