- #include <reg51.h> //頭文件
- #include "1.h"
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define u8 unsigned char
- #define PWM_Cycle 100
- //數(shù)據(jù)定義區(qū)
- unsigned char Minute_set=1; //定時時間設(shè)置
- unsigned char Distance_DIS=50; //設(shè)定的距離提醒舉例
- sbit TX=P1^6; //超聲波傳感器的接口
- sbit RX=P1^5;
- sbit PWM_1=P1^7;
- sbit PWM_2=P2^2;
- sbit LED_ALARM=P1^4;
- #define LED_PORT P3//燈光控制
- unsigned long int counter_time=0;
- unsigned char Minute_time=0;
- unsigned char second_time=0;
- uint time=0; //聲波時間
- uint S=0; //距離
- //LCD port
- sbit LCD1602_RS= P1^2;
- sbit LCD1602_RW= P1^1;
- sbit LCD1602_EN= P1^0;
- sfr LCD1602_DATAPINS= 0x80; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.數(shù)據(jù)端口
- sbit KEY1=P2^0;
- sbit KEY2=P2^1;
- sbit KEY3=P2^2;
- sbit KEY4=P2^3;
- #define KEY3_VALUE 3
- #define KEY4_VALUE 4
- extern void Delay1ms(uint c); //@11.0592MHz
- uchar KEY_Scan(uchar mode);
- //在LCD1602上顯示時間
- void Display_Time_lcd1602();
- uchar code number[10]={"0123456789"};
- void delayms ( uint c) //@12.000MHz
- unsigned char i, j;
- for(;c>0;c--)
- i = 2;
- j = 239;
- do
- while (--j);
- } while (--i);
- #define Lcd1602_Delay1ms delayms
- * 函 數(shù) 名 : LcdWriteCom
- * 函數(shù)功能 : 向LCD寫入一個字節(jié)的命令
- * 輸 入 : com
- * 輸 出 : 無
- #ifndef LCD1602_4PINS //當(dāng)沒有定義這個LCD1602_4PINS時
- void Write_LCD_Command(uchar com) //寫入命令
- LCD1602_EN = 0; //使能
- LCD1602_RS = 0; //選擇發(fā)送命令
- LCD1602_RW = 0; //選擇寫入
- LCD1602_DATAPINS = com; //放入命令
- Lcd1602_Delay1ms(1); //等待數(shù)據(jù)穩(wěn)定
- LCD1602_EN = 1; //寫入時序
- Lcd1602_Delay1ms(5); //保持時間
- LCD1602_EN = 0;
- #else
- LCD1602_EN = 0; //使能清零
- LCD1602_RS = 0; //選擇寫入命令
- LCD1602_DATAPINS = com; //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
- LCD1602_EN = 0;
- LCD1602_DATAPINS = com << 4; //發(fā)送低四位
- LCD1602_EN = 0;
- #endif
- * 函 數(shù) 名 : LcdWriteData
- * 函數(shù)功能 : 向LCD寫入一個字節(jié)的數(shù)據(jù)
- * 輸 入 : dat
- * 輸 出 : 無
- void Write_LCD_Data(uchar dat) //寫入數(shù)據(jù)
- LCD1602_RS = 1; //選擇輸入數(shù)據(jù)
- LCD1602_DATAPINS = dat; //寫入數(shù)據(jù)
- LCD1602_EN = 0;
- #else
- LCD1602_RS = 1; //選擇寫入數(shù)據(jù)
- LCD1602_DATAPINS = dat; //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
- LCD1602_E = 0;
- LCD1602_DATAPINS = dat << 4; //寫入低四位
- LCD1602_EN = 0;
- #endif
- void LCD_Init() //1602LCD 初始化
- Write_LCD_Command(0x01);//清屏
- Write_LCD_Command(0x38);//設(shè)置8位格式,2行,5*8
- Write_LCD_Command(0x0c);//整體顯示,關(guān)光標(biāo),不閃爍
- Write_LCD_Command(0x06);//設(shè)定輸入方式,增量不移位
- /****************寫一個字符數(shù)據(jù)到指定的位置***************/
- void DisplayOneChar(uchar X,uchar Y,uchar DData)
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- Write_LCD_Command(X);
- Write_LCD_Data(DData);
- void Lcd1602SetCursor(uchar X,uchar Y)
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- /****************寫多個個字符數(shù)據(jù)到指定的位置***************/
- void DisplayChars(uchar X,uchar Y,uchar *str)
- Lcd1602SetCursor(X, Y); //設(shè)置起始地址
- while (*str != '\0')
- Write_LCD_Data(*(str++));
- 函數(shù)名稱:Disp_number()
- 功能描述:顯示四數(shù)字
- 入口參數(shù):num:顯示的數(shù)字 n:數(shù)字位數(shù)
- 返回值:無
- void Disp_number(uchar X,uchar Y,uint num,u8 n)
- u8 a; //個位
- u8 b; //十位
- u8 c; //百位
- u8 d; //千位
- u8 e; //萬位
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- switch(n)
- case 1:Write_LCD_Data(num+0x30);
- break;
- case 2:b=num/10;
- a=num%10;
- Write_LCD_Data(number[b]);
- Write_LCD_Data(number[a]);
- break;
- case 3:c=num/100;
- b=num%100/10;
- a=num%10;
- Write_LCD_Data(number[c]);
- break;
- case 4:d=num/1000;
- c=num%1000/100;
- b=num%1000%100/10;
- a=num%10;
- Write_LCD_Data(number[d]);
- break;
- case 5:
- e=num/10000;
- d=num%10000/1000;
- c=num%1000/100;
- b=num%100/10;
- a=num%10;
- Write_LCD_Data(number[e]);
- break;
- void Count(void) //計算距離的函數(shù)
- time=(TH0<<8)+TL0;
- TH0=0;
- TL0=0;
- time=time+counter_time*65536;//us
- S=time/58; //算出來是CM 340m/S聲速
- //定時器初始化
- //初始化為10MS定時器
- void Time0_init()
- TMOD |= 0x01; //使用模式1,16位定時器
- TH0 = 0; //定時器裝入初始值10ms
- TL0 = 0;
- EA = 1; //總中斷
- ET0 = 1;//定時器0初始化
- TR0 = 0;
- //定時器1初始化
- void Timer1Init(void) //1毫秒@12.000MHz
- //AUXR &= 0xBF; //定時器時鐘12T模式
- TMOD &= 0x0F; //設(shè)置定時器模式
- TMOD |= 0x10; //設(shè)置定時器模式
- TL1 = 0x18; //設(shè)置定時初值
- TH1 = 0xFC; //設(shè)置定時初值
- TF1 = 0; //清除TF1標(biāo)志
- TR1 = 1; //定時器1開始計時
- ET1=1;
- void StartModule()
- TX=1; //800MS 啟動一次模塊
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- TX=0;
- unsigned int DATA_V;
- bit channel=0;
- uint AD_val=0;
- float code H_num=0.625 ; //這是一個距離的比例系數(shù)
- //超聲波檢測
- uchar HC_SR04_Task(void)
- static unsigned long try=0;
- static uchar timeout_flag=0;
- StartModule();
- while(!RX) //當(dāng)RX為零時等待
- try++;
- if(try>600000) //等待時間不能太長,防止程序死機(jī)
- try=0;
- timeout_flag=1;//置位超時標(biāo)志
- break;
- counter_time=0;
- TH0=0;
- TL0=0;
- TR0=1; //開啟計數(shù)
- if(timeout_flag==0)
- while(RX) //當(dāng)RX為1計數(shù)并等待
- try++;
- if(try>6000000) //等待時間不能太長,防止程序死機(jī)
- try=0;
- timeout_flag=1; //置位超時標(biāo)志
- break;
- TR0=0; //關(guān)閉計數(shù)
- if(timeout_flag)//如果超時了
- TH0=0;
- TL0=0;
- timeout_flag=0;
- else//正常數(shù)據(jù)
- Count(); //計算
- if(S>=Distance_DIS)
- return 0;
- else//當(dāng)距離小于或等于50時,
- return 4;
- return 0;
- bit Alarm_Time_flag=0;
- void compare_light_time()
- uchar key=0;
- if(Alarm_Time_flag)
- while(1)
- //請注意休息,聲光報警
- LED_ALARM=0;
- DisplayChars(0,0,"Please have");//在LCD1602上顯示Light
- DisplayChars(0,1,"A good rest");
- key=KEY_Scan(0);
- if(key==KEY4_VALUE)//進(jìn)入設(shè)置界面
- Alarm_Time_flag=0;//時間到達(dá)設(shè)定值
- LED_ALARM=1;
- break;
- LED_ALARM=1;
- * 名稱 : Main()
- * 功能 : 主函數(shù)
- * 輸入 : 無
- * 輸出 : 無
- void Main(void)
- uchar key=0,state=0;
- Time0_init(); //初始化定時器 超聲波使用的
- Timer1Init();//定時器1初始化 1ms中斷1次
- LCD_Init();//LCD1602初始化
- while(1)
- key=KEY_Scan(0); //按鍵的掃描
- switch(state)
- case 0:
- state=HC_SR04_Task();//超聲波檢測代碼
- DisplayChars(0,1,"DIS:"); //
- Disp_number(4,1,S,2);
- DisplayChars(6,1,"cm");
- compare_light_time();//比較時間報警
- Disp_number(10,1,Minute_time,2);
- DisplayOneChar(12,1,'-');
- Disp_number(13,1,second_time,2);
- second_time=0;
- Minute_time=0;//清除時間
- break;
- break;
- case 4:
- LED_ALARM=0;
- DisplayChars(0,0,"Please adjust");
- DisplayChars(0,1,"Your sitting pos");
- if(state==0)
- { LED_ALARM=1;
- break;
- default:break;
- void timer0() interrupt 1 //10us定時器累加
- TL0 = 0;
- counter_time++;
- void time1_ISR() interrupt 3
- static uint count=0;
- count++;
- if(count>=1000)//1s
- count=0;
- second_time++;
- if(second_time>=60)
- Minute_time++;
- second_time=0;
- if(Minute_time>=Minute_set)
- Alarm_Time_flag=1; //超出時間
- else
- //按鍵控制
- static u8 key=1;
- if(mode==1) //連續(xù)按鍵按下
- key=1;
- if(KEY3==0||KEY4==0) //任意一個按鍵按下
- delayms(10); //消抖
- key=0;
- if(KEY3==0)
- return KEY3_VALUE;
- else if(KEY4==0)
- return KEY4_VALUE;
- else if(KEY3==1&&KEY4==1) //無按鍵按下
- key=1;
- return 0;
