初始倒計(jì)時(shí)設(shè)置了djfen的值但是仿真顯示不出來,只能顯示設(shè)置的djmiao,還有按鍵按到小時(shí)設(shè)置的時(shí)候不能加也不能減,只能加減秒和分,不知道又是哪里有問題了,求解決呀
#include <reg52.h>
#include <intrins.h>
#include <lcd.h>
sbit key1=P3^0; //設(shè)置鍵
sbit key2=P3^1; //加鍵
sbit key3=P3^2; //減鍵
sbit key4=P3^3; //開始鍵
sbit beep=P2^4;
sbit trig=P1^7;
sbit echo=P1^6;
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
uchar djshi,djfen=1,djmiao=8;
uchar r,num,s,i;
uchar distance,t;
bit flag=0;
bit flag1s=0;
uchar code table1[]={"time: 00:00:00 "};
uchar code table2[]={" "};
uchar code table3[13]={'0','1','2','3','4','5','6','7','8','9','.','-','M'};
uchar code table4[]={"xdz:"};
uchar cc[4]={0,0,0,0};
void startmodule();
void start();
void count();
void LcdInit() //LCD初始化子程序
uchar i;
lcd_writecom(0x38); //開顯示
lcd_writecom(0x0c); //開顯示不顯示光標(biāo)
lcd_writecom(0x06); //寫一個(gè)指針加1
lcd_writecom(0x01); //清屏
lcd_writecom(0x80); //設(shè)置數(shù)據(jù)指針起點(diǎn)
for(i=0;i<16;i++)
lcd_writedate(table1[ i]);[ i]
void Timer0Init(void) //
TMOD |= 0x01; //使用定時(shí)器T0的模式1 定時(shí)器T1的模式1
TL0 = 15536%256; //設(shè)置定時(shí)0初值
TH0 = 15536/256; //設(shè)置定時(shí)0初值
TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
ET0=1;
EA=1;
void Timer1Init(void) //
TMOD |= 0x10; //使用定時(shí)器T0的模式1 定時(shí)器T1的模式1
TL1 = 0; //設(shè)置定時(shí)0初值
TH1 = 0; //設(shè)置定時(shí)0初值
TF1=0;
TR1 = 1; //定時(shí)器0開始計(jì)時(shí)
ET0=1;
EA=1;
void Delay1ms(uint n)
uint x,y;
for(x=n;x>0;x--)
for(y=110;y>0;y--);
void write_sfm(uchar add,uchar date)
lcd_writecom(0x80+add);
lcd_writedate(date/10+0x30);
lcd_writedate(date%10+0x30);
lcd_writecom(0x80+add+1);
void keyscan()
if(key1==0)
Delay1ms(5);
if(key1==0)
num++;
TR0=0;
while(!key1);
if(num==1)
lcd_writecom(0x0f);
lcd_writecom(0x8D);
if(num==2)
lcd_writecom(0x8A);
if(num==3)
lcd_writecom(0x87);
num=0;
if(num==1)
if(key2==0)
Delay1ms(5);
if(key2==0)
djmiao++;
while(!key2);
if(djmiao==60)
djmiao=0;
lcd_writecom(0x8c);
lcd_writedate(djmiao/10+0x30);
lcd_writedate(djmiao%10+0x30);
lcd_writecom(0x8D);
if(key3==0)
Delay1ms(5);
if(key3==0)
djmiao--;
while(!key3);
if(djmiao==255)
djmiao=59;
lcd_writecom(0x8c);
lcd_writecom(0x8D);
if(num==2)
if(key2==0)
Delay1ms(5);
if(key2==0)
djfen++;
while(!key2);
if(djfen==60)
djfen=0;
lcd_writecom(0x89);
lcd_writedate(djfen/10+0x30);
lcd_writedate(djfen%10+0x30);
lcd_writecom(0x8A);
if(key3==0)
Delay1ms(5);
if(key3==0)
djfen--;
while(!key3);
if(djfen==255)
djfen=59;
lcd_writecom(0x89);
lcd_writecom(0x8A);
if(num==3)
if(key2==0)
Delay1ms(5);
if(key2==0)
djshi++;
while(!key2);
if(djshi==24)
djshi=0;
lcd_writecom(0x86);
lcd_writedate(djshi/10+0x30);
lcd_writedate(djshi%10+0x30);
lcd_writecom(0x88);
if(key3==0)
Delay1ms(5);
if(key3==0)
djshi--;
while(!key3);
if(djshi==255)
djshi=23;
lcd_writecom(0x86);
lcd_writecom(0x88);
if(key4==0)
Delay1ms(5);
if(key4==0)
TR0=1;
lcd_writecom(0x0c);
void fmq()
beep=1;
Delay1ms(5);
beep=0;
Delay1ms(5);
LcdInit();
Timer0Init();
Timer1Init();
trig=0;
Delay1ms(1000);
if(flag1s)
flag1s=0;
startmodule();
start();
count();
keyscan();
if(djshi==0 && djfen==0 &&djmiao==0) //倒計(jì)時(shí)時(shí)間到
TR0=0; //停止計(jì)時(shí)
fmq();
void Timer0() interrupt 1
TL0 = 15536%256; //設(shè)置定時(shí)初值
TH0 = 15536/256; //設(shè)置定時(shí)初值
r++;
if(r==20)
r=0;
djmiao--;
if(djmiao==255)
djmiao=59;
djfen--;
if(djfen==255)
djfen=59;
djshi--;
if(djshi==255)
djshi=0;
if(djshi==0)
djfen=59;
if(djfen==0&djshi==0)
djfen=0;
write_sfm(6,djshi);
write_sfm(9,djfen);
write_sfm(12,djmiao);
flag1s=1;
void startmodule()
trig=1;
_nop_(); _nop_(); _nop_(); _nop_();
trig=0;
void start()
while(!echo); //當(dāng)Echo為零時(shí)等待
TR1=1; //開啟
while(echo); //當(dāng)Echo為1計(jì)數(shù)并等待
TR1=0; //關(guān)閉
void count()
t=TH1*256+TL1;
TH1=0;
TL1=0;
distance=t/58.0;
cc[0]=distance/1000%10;
cc[1]=distance/100%10;
cc[2]=distance/10%10;
cc[3]=distance/1%10;
