不知道為什么我的超聲波測距程序不成功,只能得到錯誤的結果,改怎么解決呢
2022-4-10 13:10 上傳
單片機源程序如下:
- #include <reg52.h>
- #include <intrins.h>
- #include <lcd.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1=P3^0; //設置鍵
- sbit key2=P3^1; //加鍵
- sbit key3=P3^2; //減鍵
- sbit key4=P3^3; //開始鍵
- sbit beep=P2^4;
- sbit trig=P1^7;
- sbit echo=P1^6;
- sbit RS=P2^0;
- sbit RW=P2^1;
- sbit EN=P2^2;
- uchar djshi,djfen=1,djmiao=8;
- uchar r,num,s,i;
- uchar distance,t;
- bit flag=0;
- bit flag1s=0;
- uchar code table1[]={"time: 00:00:00 "};
- uchar code table2[]={" "};
- uchar code table3[13]={'0','1','2','3','4','5','6','7','8','9','.','-','M'};
- uchar code table4[]={"xdz:"};
- uchar cc[4]={0,0,0,0};
- void startmodule();
- void start();
- void count();
- void LcdInit() //LCD初始化子程序
- uchar i;
- lcd_writecom(0x38); //開顯示
- lcd_writecom(0x0c); //開顯示不顯示光標
- lcd_writecom(0x06); //寫一個指針加1
- lcd_writecom(0x01); //清屏
- lcd_writecom(0x80); //設置數(shù)據(jù)指針起點
- for(i=0;i<16;i++)
- lcd_writedate(table1[i]);[/i][i]
- void Timer0Init(void) //
- TMOD |= 0x01; //使用定時器T0的模式1 定時器T1的模式1
- TL0 = 15536%256; //設置定時0初值
- TH0 = 15536/256; //設置定時0初值
- TR0 = 1; //定時器0開始計時
- ET0=1;
- EA=1;
- void Timer1Init(void) //
- TMOD |= 0x10; //使用定時器T0的模式1 定時器T1的模式1
- TL1 = 0; //設置定時0初值
- TH1 = 0; //設置定時0初值
- TF1=0;
- TR1 = 1; //定時器0開始計時
- ET0=1;
- EA=1;
- void Delay1ms(uint n)
- uint x,y;
- for(x=n;x>0;x--)
- for(y=110;y>0;y--);
- void write_sfm(uchar add,uchar date)
- lcd_writecom(0x80+add);
- lcd_writedate(date/10+0x30);
- lcd_writedate(date%10+0x30);
- lcd_writecom(0x80+add+1);
- void keyscan()
- if(key1==0)
- Delay1ms(5);
- if(key1==0)
- num++;
- TR0=0;
- while(!key1);
- if(num==1)
- lcd_writecom(0x0f);
- lcd_writecom(0x8D);
- if(num==2)
- lcd_writecom(0x8A);
- if(num==3)
- lcd_writecom(0x87);
- if(num==4)
- num=0;
- if(num==1)
- if(key2==0)
- Delay1ms(5);
- if(key2==0)
- djmiao++;
- while(!key2);
- if(djmiao==60)
- djmiao=0;
- lcd_writecom(0x8c);
- lcd_writedate(djmiao/10+0x30);
- lcd_writedate(djmiao%10+0x30);
- if(key3==0)
- Delay1ms(5);
- if(key3==0)
- djmiao--;
- while(!key3);
- if(djmiao==255)
- djmiao=59;
- if(num==2)
- if(key2==0)
- Delay1ms(5);
- if(key2==0)
- djfen++;
- while(!key2);
- if(djfen==60)
- djfen=0;
- lcd_writecom(0x89);
- lcd_writedate(djfen/10+0x30);
- lcd_writedate(djfen%10+0x30);
- if(key3==0)
- Delay1ms(5);
- if(key3==0)
- djfen--;
- while(!key3);
- if(djfen==255)
- djfen=59;
- if(num==3)
- if(key2==0)
- Delay1ms(5);
- if(key2==0)
- djshi++;
- while(!key2);
- if(djshi==24)
- djshi=0;
- lcd_writecom(0x86);
- lcd_writedate(djshi/10+0x30);
- lcd_writedate(djshi%10+0x30);
- if(key3==0)
- Delay1ms(5);
- if(key3==0)
- djshi--;
- while(!key3);
- if(djshi==255)
- djshi=23;
- if(key4==0)
- Delay1ms(5);
- if(key4==0)
- TR0=1;
- void fmq()
- beep=1;
- Delay1ms(5);
- beep=0;
- Delay1ms(5);
- void main()
- LcdInit();
- Timer0Init();
- Timer1Init();
- trig=0;
- while(1)
- if(flag1s)
- flag1s=0;
- startmodule();
- start();
- count();
- keyscan();
- if(djshi==0 && djfen==0 &&djmiao==0) //倒計時時間到
- TR0=0; //停止計時
- fmq();
- void Timer0() interrupt 1
- TL0 = 15536%256; //設置定時初值
- TH0 = 15536/256; //設置定時初值
- r++;
- if(r==20)
- r=0;
- djmiao--;
- if(djmiao==255)
- djmiao=59;
- djfen--;
- if(djfen==255)
- djfen=59;
- djshi--;
- if(djshi==255)
- djshi=0;
- if(djshi==0)
- djfen=59;
- if(djfen==0&djshi==0)
- djfen=0;
- write_sfm(6,djshi);
- write_sfm(9,djfen);
- write_sfm(12,djmiao);
- flag1s=1;
- trig=1;
- _nop_(); _nop_(); _nop_(); _nop_();
- trig=0;
- void start()
- while(!echo); //當Echo為零時等待
- TR1=1; //開啟
- while(echo); //當Echo為1計數(shù)并等待
- TR1=0; //關閉
- void count()
- t=TH1*256+TL1;
- TH1=0;
- TL1=0;
- distance=t/58.0;
- cc[0]=distance/1000%10;
- cc[1]=distance/100%10;
- cc[2]=distance/10%10;
- cc[3]=distance/1%10;
- lcd_writechar(1, 1, table3[cc[0]]);
- lcd_writechar(2, 1, table3[cc[1]]);
- lcd_writechar(3, 1, table3[cc[2]]);
- lcd_writechar(4, 1, table3[cc[3]]);
復制代碼
