查看: 1985|回復(fù): 13
為什么我的單片機(jī)程序輸出波形的頻率最大只能30HZ
ID:494908 發(fā)表于 2022-4-14 13:38 | 顯示全部樓層 |閱讀模式
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. #define uint unsigned int
  5. #define AddWr 0x90                           //PCF8591地址1001 0000
  6. sbit SCL=P3^6;
  7. sbit SDA=P3^7;
  8. sbit RS=P2^0;
  9. sbit RW=P2^1;
  10. sbit E =P2^2;
  11. sbit sin=P1^0;
  12. sbit square=P1^1;
  13. sbit triangle=P1^2;
  14. sbit juchi=P1^3;
  15. sbit key1=P1^4;
  16. sbit key2=P1^5;
  17. sbit key3=P1^6;
  18. sbit key4=P1^7;
  19. bit ack;
  20. uchar pinlv,shi,ge;                 //頻率變量//
  21. uchar change;                        //波形切換變量//
  22. uchar num;                                 //波形表輸出個數(shù)變量//
  23. uint TH0_PL,TL0_PL;                   //重設(shè)初值//
  24. uint timer_value;                        //初值變量//
  25. uchar fd;
  26. uchar code table[]="0123456789";
  27. void delay_ms(unsigned int n)  //12MHZ晶振時延時1ms,若用11.0592MHZ,則j=110
  28. {
  29.   unsigned int i=0,j=0;
  30.    for(i=n;i>0;i--)
  31.     for(j=0;j<123;j++);
  32. }
  33. void delay_8591()
  34. {
  35.    _nop_();   _nop_(); _nop_(); _nop_();           //起始條件建立時間大于4.7us,延時
  36. }
  37. uchar code sin_table[]={0x7F,0x98,0xB0,0xC6,0xD9,0xE9,0xF5,0xFC,
  38.                                                 0xFE,0xFC,0xF5,0xE9,0xD9,0xC6,0xB0,0x98,
  39.                                                 0x7F,0x66,0x4E,0x38,0x25,0x15,0x09,0x02,
  40.                                                 0x00,0x02,0x09,0x15,0x25,0x38,0x4E,0x66};
  41. uchar code square_table[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  42.                                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  43.                                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  44.                                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
  45. uchar code triangle_table[]={0x00,0x10,0x20,0x30,0x40,0x50,0x60,0x70,
  46.                                                         0x80,0x90,0xa0,0xb0,0xc0,0xd0,0xe0,0xf0,
  47.                                                         0xff,0xf0,0xe0,0xd0,0xc0,0xb0,0xa0,0x90,
  48.                                                         0x80,0x70,0x60,0x50,0x40,0x30,0x20,0x10};
  49. uchar code juchi_table[]={0x00,0x07,0x10,0x17,0x20,0x27,0x30,0x37,
  50.                                                         0x40,0x47,0x50,0x57,0x60,0x67,0x70,0x77,
  51.                                                         0x80,0x87,0x90,0x97,0xa0,0xa7,0xb0,0xb7,
  52.                                                         0xc0,0xc7,0xd0,0xd7,0xe0,0xe7,0xf0,0x00};
  53. /*******************************************PCF8591DA轉(zhuǎn)換模塊**************************/////////////////////
  54. /****************************************************************************************///////////
  55.    void start()//開始信號
  56. {
  57.     SDA=1;            //確保SDA線為高電平,開始        之前都確保為高電平
  58.     delay_8591();
  59.     SCL=1;                             //確保SCL為高電平
  60.      delay_8591();
  61.     SDA=0;                     //在SCL為高時拉低SDA線,即為起始信號
  62.     delay_8591();
  63.         SCL=0;                                   //將SCL線拉低,為后面SDA的傳數(shù)據(jù)時電平變化做準(zhǔn)備
  64. }
  65. void stop() //停止信號
  66. {
  67.     SDA=0;                    //確保SDA線為低電平
  68.      delay_8591();
  69.     SCL=1;                          //確保SCL線為高電平
  70.      delay_8591();
  71.     SDA=1;                      //在SCL為高時拉高SDA線,即為停止信號,此時SDA和SCL均為高,同時完成IIC初始化過程
  72.      delay_8591();
  73. }
  74. void ack_check(bit a)
  75. {
  76.         if(a==0)
  77.                   SDA=0;              //*在此發(fā)出應(yīng)答或非應(yīng)答信號 *//
  78.     else
  79.                 SDA=1;
  80.                 _nop_();
  81.                 SCL=1;
  82.                 delay_8591();
  83.                 SCL=0;
  84.                 _nop_();
  85.                 _nop_();                     //*清時鐘線,鉗住I2C總線以便繼續(xù)接收*//
  86.                 SDA=1;
  87. }
  88. void send_byte(uchar date)
  89. {
  90.         uchar i;
  91.         for(i=0;i<8;i++)  //*要傳送的數(shù)據(jù)長度為8位*//
  92.     {
  93.      if((date<<i)&0x80)
  94.                     SDA=1;                                           //*判斷發(fā)送位*//
  95.      else
  96.                          SDA=0;
  97.                         _nop_();
  98.                SCL=1;                               //*置時鐘線為高,通知被控器開始接收數(shù)據(jù)位*/
  99.                delay_8591();
  100.                SCL=0;
  101.             }
  102.                     SDA=1;                //*8位發(fā)送完后釋放數(shù)據(jù)線,準(zhǔn)備接收應(yīng)答位*/
  103.                         _nop_();
  104.                     SCL=1;
  105.                     if(SDA==1)
  106.                                 ack=0;
  107.                     else ack=1;        //*判斷是否接收到應(yīng)答信號*/
  108.                             SCL=0;
  109.
  110. }
  111. void write_add()
  112. {
  113.         start();
  114.         send_byte(AddWr);
  115.         if(ack==0)                                                //判斷有無應(yīng)答信號
  116.         {        //有應(yīng)答信號應(yīng)該給低電平
  117.                  stop();
  118.                 return;
  119.         }
  120.          send_byte(0x40);                         //01000000 寫入控制位,使能DA輸出
  121. }
  122. /*********************************************************顯示模塊*///////////////////////////////////////////////
  123. /**********************************************************************************************//////////
  124. void LCD12864_BusyCheck()        //讀一下當(dāng)前代碼是否在忙,最高位為0為不忙,1為忙
  125.     {
  126.        unsigned char temp;
  127.        P0=0xff;        //釋放整個口,全部為高電平
  128.        RS=0;         //RS為0是讀狀態(tài) ,為1是寫數(shù)據(jù)
  129.        RW=1;          //高讀低寫
  130.        delay_ms(10);
  131.      while(1)             //一直檢測知道不忙為止
  132.       {
  133.           E=1;             //E是使能口,由1到0才可寫入數(shù)據(jù)
  134.           temp=P0;
  135.           E=0;
  136.           if((temp&0x80)==0)  //如果等于零意味著最高位為0,不忙
  137.           break;          //結(jié)束(如果上面代碼不為0,則循環(huán)一直檢測
  138.      }
  139.    }
  140. void LCD12864_wcmd(unsigned char cmd)      //命令函數(shù)
  141. {
  142.     LCD12864_BusyCheck();
  143.     RS=0;           //高數(shù)低命
  144.     RW=0;
  145.     delay_ms(1);
  146.     P0=cmd;  //命令把想寫的內(nèi)容送到數(shù)據(jù)口
  147.     delay_ms(1);
  148.     E=1;
  149.     E=0;          //產(chǎn)生一個下降沿寫數(shù)據(jù)
  150.    }
  151. void LCD12864_wdat(unsigned char dat)     //寫數(shù)據(jù)函數(shù)
  152. {
  153.     LCD12864_BusyCheck();
  154.     RS=1;   //寫數(shù)據(jù)
  155.     RW=0;
  156.     delay_ms(1);
  157.     P0=dat;                 //把想寫的內(nèi)容送到數(shù)據(jù)口
  158.     E=1;
  159.     delay_ms(1);
  160.     E=0;
  161. }
  162. void LCD12864_SetPos(unsigned char x,unsigned char y)     //x是行,y是列
  163. {
  164.    unsigned char pos;
  165.    switch(x)
  166.      {
  167.       case 0:x=0x80;break;     //第一行從0x80開始
  168.       case 1:x=0x90;break;
  169.       case 2:x=0x88;break;
  170.       case 3:x=0x98;break;
  171.       default:break;
  172.       }
  173.       pos=x+y;    //x范圍:0-3,y范圍:0-7 (因?yàn)橐恍兄荒軐懓藗漢字)
  174.       LCD12864_wcmd(pos);
  175.       }
  176. void LCD12864_DisHZ_Str(unsigned char*s)
  177.     {
  178.      while(*s)
  179.      LCD12864_wdat(*s++);  //指針++,指針指向下一個
  180.      }
  181. void LCD12864_init()
  182.    {
  183.      LCD12864_wcmd(0x01);     //清屏指令
  184.      delay_ms(3);
  185.      LCD12864_wcmd(0x30);
  186.      delay_ms(5);
  187.      LCD12864_wcmd(0x30);
  188.      delay_ms(5);
  189.      LCD12864_wcmd(0x0c);
  190.      delay_ms(3);
  191.      LCD12864_wcmd(0x01);
  192.      delay_ms(3);
  193.      LCD12864_wcmd(0x80);
  194.      delay_ms(3);
  195.      LCD12864_wcmd(0x06);                          //游標(biāo)右移,地址自動加一
  196.      delay_ms(3);
  197.     }
  198. //*******定時器程序*********//
  199. //*定時次數(shù)=(1/pinlv*32)/(1/12/12)=31250/pinlv*//  更改頻率原理:單片機(jī)12MHZ晶振,所以產(chǎn)生1s的時鐘,也就是1000000us,而輸出波形表內(nèi)有32個數(shù)據(jù),
  200.        //           所以用1000000/(頻率*32),得出數(shù)值作為定時器初值,每隔一個時間輸出一個數(shù)值。
  201. void timer0_init()
  202. {
  203.         uchar a;                        //頻率儲存
  204.         shi=pinlv/10;
  205.         ge=pinlv%10;
  206.         a=shi*10+ge;
  207.         timer_value=31250/a;                //定時次數(shù)計算
  208.         timer_value=timer_value-28;           //誤差補(bǔ)償
  209.         TMOD=0x01;
  210.         TH0_PL=(65535-timer_value)/256;
  211.         TL0_PL=(65535-timer_value)%256;
  212.         TH0=TH0_PL;
  213.         TL0=TL0_PL;
  214.         TF0=0;
  215.         EA=1;
  216.         ET0=1;
  217.         TR0=1;
  218. }
  219. /***************************************按鍵模塊********************************************/
  220. /******************************************************************************************/
  221. void key()
  222. {
  223.                 if(key1==0)//按下鍵盤
  224.                         {
  225.                                 delay_ms(10);        //消抖動
  226.                                 if(key1==0);//在確認(rèn)一次
  227.                         {        pinlv++;//發(fā)光二極管點(diǎn)亮
  228.                                 if(pinlv==51)                   //*設(shè)置頻率調(diào)節(jié)范圍1~50
  229.                                 pinlv=1;
  230.                                 }
  231.                                 while(!key1)//松手
  232.                                 delay_ms(10);          ////消抖動
  233.                                 while(!key1);                }
  234.                 if(key2==0)//按下鍵盤
  235.                         {
  236.                                 delay_ms(10);        //消抖動
  237.                                 if(key2==0);//在確認(rèn)一次
  238.                         {
  239.                                 pinlv--;//發(fā)光二極管點(diǎn)亮
  240.                                 if(pinlv==1)                                  //*設(shè)置頻率調(diào)節(jié)范圍1~50
  241.                                 pinlv=50;
  242.                                 }
  243.                                 while(!key2)//松手
  244.                                 delay_ms(10);          ////消抖動
  245.                                 while(!key2);                }
  246.                 if(key3==0)//按下鍵盤
  247.                         {
  248.                                 delay_ms(10);        //消抖動
  249.                                 if(key3==0);//在確認(rèn)一次
  250.                         {
  251.                                 fd++;
  252.                                 if(fd==11)                                                //*設(shè)置幅度調(diào)節(jié)范圍1~10
  253.                                 fd=1;
  254.                                 }
  255.                                 while(!key3)//松手
  256.                                 delay_ms(10);          ////消抖動
  257.                                 while(!key3);                }
  258.            if(key4==0)//按下鍵盤
  259.                         {
  260.                                 delay_ms(10);        //消抖動
  261.                                 if(key4==0);//在確認(rèn)一次
  262.                         {
  263.                             fd--;
  264.                                 if(fd==1)
  265.                                 fd=10;
  266.                                 }
  267.                                 while(!key4)//松手
  268.                                 delay_ms(10);          ////消抖動
  269.                                 while(!key4);                }
  270. }
  271. void wave_KEY()
  272. {
  273.         if(square==0)//按下鍵盤
  274.                         {
  275.                                 delay_ms(10);        //消抖動
  276.                                 if(square==0);//在確認(rèn)一次
  277.                         {
  278.                                 change=2;
  279.                                 }
  280.                                 while(square)//松手
  281.                                 delay_ms(10);          ////消抖動
  282.                                 while(square);                }
  283.         else if(sin==0)//按下鍵盤
  284.                         {
  285.                                 delay_ms(10);        //消抖動
  286.                                 if(sin==0);//在確認(rèn)一次
  287.                         {
  288.                                 change=1;
  289.                                 }
  290.                                 while(sin)//松手
  291.                                 delay_ms(10);          ////消抖動
  292.                                 while(sin);                }
  293.         else if(triangle==0)//按下鍵盤
  294.                         {
  295.                                 delay_ms(10);        //消抖動
  296.                                 if(triangle==0);//在確認(rèn)一次
  297.                         {
  298.                                 change=3;
  299.                                 }
  300.                                 while(triangle)//松手
  301.                                 delay_ms(10);          ////消抖動
  302.                                 while(triangle);                }
  303.         else if(juchi==0)//按下鍵盤
  304.                         {
  305.                                 delay_ms(10);        //消抖動
  306.                                 if(juchi==0);//在確認(rèn)一次
  307.                         {
  308.                                 change=4;
  309.                                 }
  310.                                 while(juchi)//松手
  311.                                 delay_ms(10);          ////消抖動
  312.                                 while(juchi);                }
  313. }
  314. void display()                             //顯示子程序
  315. {
  316.    LCD12864_init();
  317.    LCD12864_wcmd(0x0c);    //開顯示
  318.    LCD12864_wcmd(0x30);
  319.       LCD12864_SetPos(0,0);                  //在第一行第一個漢字輸出
  320.       delay_ms(1);
  321.       LCD12864_DisHZ_Str("  波形發(fā)生器");
  322.           LCD12864_SetPos(1,0);                  //第二行
  323.       delay_ms(1);
  324.       LCD12864_DisHZ_Str("波形:");
  325.
  326.          LCD12864_SetPos(2,0);           //第三行
  327.      delay_ms(1);
  328.      LCD12864_DisHZ_Str("頻率:");
  329.
  330.                                                             LCD12864_SetPos(2,7);
  331.                                 LCD12864_DisHZ_Str("HZ");
  332.          LCD12864_SetPos(3,0);                          //第四行
  333.      delay_ms(1);
  334.      LCD12864_DisHZ_Str("幅度:");
  335.
  336.                                      LCD12864_SetPos(3,7);
  337.                                 LCD12864_DisHZ_Str("V");
  338.        }
  339. void state_init()                        //*初始波形數(shù)據(jù)設(shè)置(正弦波,頻率5hz,幅度5v*//
  340. {
  341.         pinlv=5;
  342.         change=1;
  343.         fd=10;
  344.         write_add();
  345. }
  346. /****************************************主程序*********************************//////
  347. /************************************************************************///////////////
  348. void main()
  349. {
  350.                 state_init();
  351.             P0=0xff;
  352.         display();
  353.                    while(1)
  354.                 {
  355.                  if(change==1)        // 此處數(shù)據(jù)是隨按鍵改變的數(shù)據(jù)程序,因此放入while循環(huán)中,隨波形轉(zhuǎn)換而改變顯示
  356.        {
  357.        LCD12864_SetPos(1,4);
  358.                                                    LCD12864_DisHZ_Str("sin");
  359.        }
  360.        if(change==2)
  361.                                                    {
  362.        LCD12864_SetPos(1,4);
  363.                                                    LCD12864_DisHZ_Str("方波");
  364.        }
  365.        if(change==3)   {
  366.        LCD12864_SetPos(1,4);
  367.                                                    LCD12864_DisHZ_Str("角波");
  368.        }
  369.        if(change==4)   {
  370.        LCD12864_SetPos(1,4);
  371.                                                    LCD12864_DisHZ_Str("鋸齒");
  372.        }
  373.        LCD12864_SetPos(2,4);
  374.        shi=pinlv/10;
  375.        ge=pinlv%10;
  376.        if(shi==0)
  377.        LCD12864_wdat(' ');
  378.        else
  379.                                                             LCD12864_wdat(table[shi]);
  380.        if(shi==0&&ge==0)
  381.        LCD12864_wdat(' ');
  382.                                             else
  383.                                                             LCD12864_wdat(table[ge]);
  384.        LCD12864_SetPos(3,4);
  385.                                                             LCD12864_wdat(table[fd*5/10]);
  386.                                 LCD12864_DisHZ_Str(".");
  387.        LCD12864_wdat(table[fd*5%10]);
  388.                         wave_KEY();
  389.                          key();
  390.                         delay_ms(10);
  391.                         timer0_init();
  392.                         delay_ms(10);
  393.                         }
  394. }
  395. void timer0() interrupt 1        //改變頻率
  396. {
  397.         TH0=TH0_PL;
  398.         TL0=TL0_PL;
  399.         if(change==1)
  400.                 send_byte(sin_table[num]*0.1*fd);                         //單片機(jī)輸出為5V,因此FD變化1~10,在乘以0.1后,可編程0~5的調(diào)節(jié)
  401.         else if(change==2)
  402.                 send_byte(square_table[num]*0.1*fd);                //假如不加幅度程序,則輸出頻率可靈活調(diào)制1~40hz!!,即去掉*0.1*fd
  403.         else if(change==3)
  404.                 send_byte(triangle_table[num]*0.1*fd);
  405.         else if(change==4)
  406.                 send_byte(juchi_table[num]*0.1*fd);
  407.         if(num>=31)
  408.                 num=0;
  409.         else
  410.                 num++;
  411. }
ID:161164 發(fā)表于 2022-4-14 17:30 | 顯示全部樓層
因?yàn)?9C52太慢了
當(dāng)50Hz時
定時器的更新時間是31250/50 = 625us
但計算  square_table[num]*0.1*fd  耗時394us
傳送數(shù)據(jù)  send_byte(XXX)  又耗時331
加起來共耗時725us
已經(jīng)超出定時器的溢出時間了
于是不斷進(jìn)出中斷
ID:494908 發(fā)表于 2022-4-14 17:44 | 顯示全部樓層
lkc8210 發(fā)表于 2022-4-14 17:30
因?yàn)?9C52太慢了
當(dāng)50Hz時
那這要怎么改呀,求大神幫幫忙
ID:494908 發(fā)表于 2022-4-14 18:45 | 顯示全部樓層
因?yàn)?9C52太慢了
當(dāng)50Hz時
怎么省去square_table[num]*0.1*fd  這個時間
ID:161164 發(fā)表于 2022-4-14 22:56 | 顯示全部樓層
米霽113 發(fā)表于 2022-4-14 17:44
那這要怎么改呀,求大神幫幫忙
換芯片吧~
ID:494908 發(fā)表于 2022-4-14 23:03 | 顯示全部樓層
你說的這個耗時725us是怎么計算的??
ID:494908 發(fā)表于 2022-4-14 23:14 | 顯示全部樓層
不換芯片的話,程序可以做改動嗎?
ID:491577 發(fā)表于 2022-4-14 23:16 | 顯示全部樓層
中斷函數(shù)要盡量簡單,復(fù)雜運(yùn)算放在主函數(shù)中運(yùn)行。晶振用30M的。最好換單片機(jī),新一點(diǎn)的單片機(jī)都有定時器對外輸出管腳,定時器可以直接對外輸出方波,連中斷都不需要。輸出10MHz都可以。89C52只是學(xué)習(xí)用,做產(chǎn)品扔了吧。
ID:494908 發(fā)表于 2022-4-14 23:58 | 顯示全部樓層
hhh402 發(fā)表于 2022-4-14 23:16
中斷函數(shù)要盡量簡單,復(fù)雜運(yùn)算放在主函數(shù)中運(yùn)行。晶振用30M的。最好換單片機(jī),新一點(diǎn)的單片機(jī)都有定時器對 ...
那我這個square_table[num]*0.1*fd 運(yùn)算改怎么在主函數(shù)改,求求大神幫幫忙!做設(shè)計的,感謝!
ID:123289 發(fā)表于 2022-4-15 11:29 | 顯示全部樓層
波形極限周期:T=DAC轉(zhuǎn)換時間 * 波形周期點(diǎn)數(shù)
點(diǎn)數(shù)32是死的,就看DA的時間了,需要查手冊,看看DA的時間。
升頻要點(diǎn):
下達(dá)DA轉(zhuǎn)換命令后,不要死等轉(zhuǎn)換完成。。,浪費(fèi)時間,而是利用這段時間準(zhǔn)備好下一個轉(zhuǎn)換數(shù)據(jù),這樣DA完成后,下個數(shù)據(jù)就可以立即給到DA了。這樣最快!
ID:625730 發(fā)表于 2022-4-15 11:48 | 顯示全部樓層
米霽113 發(fā)表于 2022-4-14 23:58
你最好把你的設(shè)計要達(dá)到的目標(biāo)講一講,你放到主函數(shù)也未必能解決你的問題,設(shè)計上有空間的話,單獨(dú)用一個單片機(jī)來輸出波形,別讓一個單片機(jī)干這么多事。
ID:494908 發(fā)表于 2022-4-16 18:12 | 顯示全部樓層
yzwzfyz 發(fā)表于 2022-4-15 11:29
點(diǎn)數(shù)32是死的,就看DA的時間了,需要查手冊,看看DA的時間 ...
這樣的話程序應(yīng)該怎么改呢?
ID:494908 發(fā)表于 2022-4-16 18:14 | 顯示全部樓層
TEC 發(fā)表于 2022-4-15 11:48
你最好把你的設(shè)計要達(dá)到的目標(biāo)講一講,你放到主函數(shù)也未必能解決你的問題,設(shè)計上有空間的話,單獨(dú)用一個 ...
設(shè)計目的就是實(shí)現(xiàn)一個可以調(diào)節(jié)頻率、幅度的波形發(fā)生器,使用PCF8591芯片,STC89C52,頻率越高越好。我現(xiàn)在做的最高只有20HZ,單片機(jī)的話應(yīng)該沒有時間改了
ID:123289 發(fā)表于 2022-4-18 14:37 | 顯示全部樓層
DA有無中斷信號(查DA手冊)
有:DA用中斷做,下達(dá)開始轉(zhuǎn)換后,立即退出。轉(zhuǎn)去執(zhí)行下個數(shù)據(jù)的輸出準(zhǔn)備工作(準(zhǔn)備好輸出數(shù)據(jù))。
       中斷響應(yīng)后,立即將(準(zhǔn)備好的輸出數(shù)據(jù))送DA,重復(fù)上述過程。
無:查手冊給出DA轉(zhuǎn)換時間TS,下達(dá)開始轉(zhuǎn)換后,立即執(zhí)行下個數(shù)據(jù)的輸出準(zhǔn)備工作(準(zhǔn)備好輸出數(shù)據(jù))并統(tǒng)計準(zhǔn)備工作用了多少時間,如果不足TS,用延時去補(bǔ)。達(dá)到TS時間時,立即立即將(準(zhǔn)備好的輸出數(shù)據(jù))送DA,重復(fù)上述過程。
不懂匯編的人,做這種對時序要求嚴(yán)的程序,吃虧許多。
