查看: 1964|回復(fù): 0
單片機(jī)LCD1602時(shí)鐘程序設(shè)計(jì)
ID:1013275 發(fā)表于 2022-4-18 16:08 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
簡(jiǎn)易時(shí)鐘設(shè)計(jì)
#include<reg51.h>
#include<lcd1602.H>
uchar int_time;
uchar second;
uchar minute;
uchar hour;
uchar code date[]="  H.I.T.CHINA";
uchar code time[]=" TIME 23:59:55";
uchar second=55,minute=59,hour=23;
void clock_write( uint s, uint m, uint h)
        write_sfm(0x47,h);
        write_sfm(0x4a,m);
        write_sfm(0x4d,s);
void clock_init()
        uchar i,j;
        for(i=0;i<16;i++)
   write_date(date[ i]);
        write_com(0x80+0x40);
        for(j=0;j<16;j++)
                write_data(time[j]);
        init1602();
        clock_init();
        TMOD=0x01;
        EA=1;
        ETO=1;
        TH0=(65536-46483)/256;
        TL0=(65536-46483)%256;
        TR0=1;
        int_time=0;
        second=55;
        minute=59;
        hour=23;
                clock_write(second,minute,hour);
void TO_interserve(void) interrupt 1 using 1
{  int_time++;
          if(int_time==20)
                        int_time=0;
                        second++;
                if(second==60)
                        second=0;
                        minute++;
                if(minute==60)
                        minute=0;
                        hour++;
                if(hour=24)
                        hour=0;
                TH0=(65536-46083)/256;
                TL0=(65536-46083)%256;
附件里面是仿真圖,不含代碼(自行生成hex文件)僅供參考,請(qǐng)自行測(cè)試,如有錯(cuò)誤請(qǐng)告知:
Proteus仿真下載: LCD時(shí)鐘的設(shè)計(jì).zip (41.81 KB, 下載次數(shù): 17)
