查看: 1861|回復(fù): 0
單片機(jī)雙中斷嵌套程序
ID:1013275 發(fā)表于 2022-4-18 16:17 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
雙中斷有優(yōu)先級(jí)的控制LED效果
#include<reg51.h>
#define uchar  unsigned char
void Delay(unsigned int i)
uchar j;
for(;i>0;i--)
for(j=0;j<125;j++)
uchar display[9]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar a;
for(;;)
EA=1;
EX0=1;
EX1=1;
IT0=1;
IT1=1;
PX0=0;
PX1=1;
for(a=0;a<9;a++)
Delay(500);
P2=display[a];
void int0_isr(void) interrupt 0 using 0
for(;;)
P2=0x0f;
Delay(400);
P2=0xf0;
Delay(400);
void int1_isr(void) interrupt 2 using 1
uchar m;
for(m=0;m<5;m++)
P2=0;
Delay(500);
P2=0xff;
Delay(500);
數(shù)字電壓表的設(shè)計(jì)
#include <reg51.h>
#include <intrins.h>
#define unit unsigned int
unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unit ADresult[11];
sbit DATOUT=P1^0;
sbit DATIN=P1^1;
sbit CS=P1^2;
sbit IOCLK=P1^3;
sbit EOC=P1^4;
sbit weil=P3^0;
sbit wei2=P3^1;
sbit wei3=P3^2;
sbit wei4=P3^3;
void delay_ms(unit i)
int j;
for(;i>0;i--)
for(j=0; j<123;j++);
unit getdata(uchar channel)
uchar i,temp;
unit read_ad_data=0;
channel=channel<<4;
IOCLK=0;
CS=0;
temp=channel;
for(i=0;i<12;i++)
if(DATOUT) read_ad_data=read_ad_data|0x01;
DATIN=(bit)(temp&0x80);
IOCLK=1;
_nop_();_nop_();_nop_();
IOCLK=0;
temp=temp<<1;
read_ad_data<<=1;
CS=1;
read_ad_data>>=1;
return(read_ad_data);
void dispaly(void)
uchar qian,bai,shi,ge;
unit value;
value=ADresult[2]*1.221;
qian=value%10000/1000;
bai=value%1000/100;
shi=value%100/10;
ge=value%10;
weil=1;
P2=table[qian]-128;
delay_ms(1);
weil=0;
wei2=1;
P2=table[bai];
delay_ms(1);
wei2=0;
wei3=1;
P2=table[shi];
delay_ms(1);
wei3=0;
wei4=1;
P2=table[ge];
delay_ms(1);
wei4=0;
main(void)
ADresult[2]=getdata(2);
while(!EOC);
dispaly();
附件里面是仿真圖,不含代碼(自行生成hex文件)僅供參考,請(qǐng)自行測(cè)試,如有錯(cuò)誤請(qǐng)告知:
Proteus8.8仿真下載: 中斷嵌套的應(yīng)用.zip (31.63 KB, 下載次數(shù): 11)
