- #include <REG52.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define Byte unsigned char
- #define Word unsigned short
- sbit SCL=P1^0; //IIC時(shí)鐘引腳定義
- sbit SDA=P1^1; //IIC數(shù)據(jù)引腳定義
- Byte BUF[6]; //接收數(shù)據(jù)緩存區(qū)
- Word Wbuf[2];
- void ADXL345_Start();
- void ADXL345_Stop();
- void ADXL345_SendACK(bit ack);
- bit ADXL345_RecvACK();
- void ADXL345_SendByte(Byte dat);
- Byte ADXL345_RecvByte();
- void Multiple_read_ADXL345(void);
- void Single_Write_ADXL345(Byte REG_Address,Byte REG_data);
- void Init_ADXL345();
- void Data_Convert();
- void Delay(unsigned int k);
- void Delay5us();
- void send(Byte pd);
- void send_init();
- void Delay5us() //@11.0592MHz
- //起始信號(hào)
- SDA = 1; //拉高數(shù)據(jù)線
- Delay5us(); //延時(shí)
- SCL = 1; //拉高時(shí)鐘線
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線
- //停止信號(hào)
- SDA = 0; //拉低數(shù)據(jù)線
- SDA = 1; //產(chǎn)生上升沿
- //發(fā)送應(yīng)答信號(hào)
- //入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫應(yīng)答信號(hào)
- //接收應(yīng)答信號(hào)
- CY = SDA; //讀應(yīng)答信號(hào)
- return CY;
- //向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- Byte i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- ADXL345_RecvACK();
- //從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
- Byte i;
- Byte date = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- date <<= 1;
- date |= SDA; //讀數(shù)據(jù)
- return date;
- //單字節(jié)讀取
- //Byte Single_Read_ADXL345(Byte REG_Address)
- //{ Byte REG_data;
- // ADXL345_Start(); //起始信號(hào)
- // ADXL345_SendByte(0xA6); //發(fā)送設(shè)備地址+寫信號(hào)
- // ADXL345_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
- // ADXL345_SendByte(0xA7); //發(fā)送設(shè)備地址+讀信號(hào)
- // REG_data=ADXL345_RecvByte(); //讀出寄存器數(shù)據(jù)
- // ADXL345_SendACK(1);
- // ADXL345_Stop(); //停止信號(hào)
- // return REG_data;
- //連續(xù)讀出ADXL345內(nèi)部加速度數(shù)據(jù),地址范圍0x32~0x37
- { Byte i;
- ADXL345_Start(); //起始信號(hào)
- ADXL345_SendByte(0xA6); //發(fā)送設(shè)備地址+寫信號(hào)
- ADXL345_SendByte(0x32); //發(fā)送存儲(chǔ)單元地址,從0x32開(kāi)始
- ADXL345_SendByte(0xA7); //發(fā)送設(shè)備地址+讀信號(hào)
- for (i=0; i<6; i++) //連續(xù)讀取6個(gè)地址數(shù)據(jù),存儲(chǔ)中BUF
- BUF[i] = ADXL345_RecvByte(); //BUF[0]存儲(chǔ)0x32地址中的數(shù)據(jù)
- if (i == 5)
- ADXL345_SendACK(1); //最后一個(gè)數(shù)據(jù)需要回NOACK
- else
- ADXL345_SendACK(0); //回應(yīng)ACK
- ADXL345_Stop(); //停止信號(hào)
- Delay(5);
- //單字節(jié)寫入
- ADXL345_SendByte(REG_Address); //內(nèi)部寄存器地址
- ADXL345_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù)
- ADXL345_Stop(); //發(fā)送停止信號(hào)
- //初始化ADXL345,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改
- Single_Write_ADXL345(0x31,0x0B); //測(cè)量范圍,正負(fù)16g,13位模式
- Single_Write_ADXL345(0x2C,0x08); //速率設(shè)定為12.5 參考pdf13頁(yè)
- Single_Write_ADXL345(0x2D,0x08); //選擇電源模式 參考pdf24頁(yè)
- Single_Write_ADXL345(0x2E,0x80); //使能 DATA_READY 中斷
- Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
- Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
- Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
- //將兩個(gè)八位數(shù)據(jù)合成為一個(gè)16位數(shù)據(jù)
- Wbuf[0]=BUF[1]<<8|BUF[0];
- Wbuf[0]=Wbuf[0]/64;
- Wbuf[1]=BUF[3]<<8|BUF[2];
- Wbuf[1]=Wbuf[1]/64;
- Wbuf[2]=BUF[5]<<8|BUF[4];
- Wbuf[2]=Wbuf[2]/64;
- //延時(shí)
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++);
- SBUF=pd;
- while(!TI);
- TI=0;
- void send_init()
- TMOD=0X20;
- TH1=0XFD;
- TL1=0XFD;
- TR1=1;
- SM0=0;
- SM1=1;
- EA=1;
- ES=1;
- void main()
- Delay(500); //上電延時(shí)
- Init_ADXL345();
- send_init();
- Delay(150);
- while(1)
- if(Wbuf[0]>350)
- if(Wbuf[1]>350)
- {send('7');}//右前
- if(Wbuf[1]<-350)
- {send('5');}//左前
- if(350>Wbuf[1]>-350)
- {send('4');}//右
- if(Wbuf[0]<-350)
- if(Wbuf[1]>350)
- {send('8');}//右后
- if(Wbuf[1]<-350)
- {send('6');}//左后
- {send('3');}//左
- if(350>Wbuf[0]>-350)
- if(Wbuf[1]>350)
- {send('1');}//前
- if(Wbuf[1]<-350)
- {send('2');}//后
- {send('9');}//停
- Delay(500);
復(fù)制代碼 |
