請大佬幫我看看
- #include<reg52.h> //包含51單片機(jī)系統(tǒng)頭文件
- sfr T2MOD = 0xC9;
- #define SPEED_30C 3495 //30攝氏度時(shí)的聲速,聲速V= 331.5 + 0.6*溫度;
- #define SPEED_23C 3453 //23攝氏度時(shí)的聲速,聲速V= 331.5 + 0.6*溫度;
- #define LCD_Data P0 //定義液晶1602數(shù)據(jù)接口對應(yīng)單片機(jī)的P0口
- #define Busy 0x80 //液晶為忙時(shí)對應(yīng)的狀態(tài)字
- //定義智能小車電機(jī)驅(qū)動(dòng)芯片L293D輸入IO口
- sbit IN1 = P1^4; //電機(jī)驅(qū)動(dòng)芯片L298N的IN1管腳
- sbit IN2 = P1^5; //電機(jī)驅(qū)動(dòng)芯片L298N的IN2管腳
- sbit IN3 = P1^6; //電機(jī)驅(qū)動(dòng)芯片L298N的IN3管腳
- sbit IN4 = P1^7; //電機(jī)驅(qū)動(dòng)芯片L298N的IN4管腳
- sbit EN1 = P1^3; //電機(jī)驅(qū)動(dòng)芯片L298N的EN1管腳
- sbit EN2 = P3^2; //電機(jī)驅(qū)動(dòng)芯片L298N的EN2管腳
- sbit key1 = P3^7; //暫停按鍵
- sbit key2 = P3^6; //避障按鍵
- sbit key3 = P3^5; //循跡按鍵
- sbit key4 = P3^4;
- sbit LCD_RS = P1^0; //液晶的RS管腳
- sbit LCD_RW = P1^1; //液晶的RW管腳
- sbit LCD_E = P1^2; //液晶的E管腳
- sbit ECHO = P2^6; //超聲波模塊回聲接收端口
- sbit TRIG = P2^5; //超聲波模塊觸發(fā)端口
- sbit left_led = P2^7; //左循跡引腳
- sbit right_led = P2^0; //右循跡引腳
- sbit zhong_led = P2^2; //中循跡引腳
- unsigned char code table0[] = {"State:Stop "}; //定義字符數(shù)組SL-51B用于液晶顯示
- unsigned char code table1[] = {" "}; //定義字符數(shù)組NO ECHO用于液晶顯示
- unsigned char code table2[] ={"State:Avoiding "}; //液晶顯示避障標(biāo)志
- unsigned char code table3[] ={"Distance:xxx.xcm"}; //定義字符數(shù)組Distance:xxx.xcm用于顯示
- unsigned char code table4[] ={"State:Tracing "}; //液晶顯示循跡標(biāo)志
- unsigned char code table5[] ={"State:Telecont "};
- unsigned char disbuff[4]={0,0,0,0}; //用于分別存放距離的值0.1mm、mm、cm和m的值
- unsigned char pwmval_left = 0; //變量定義pwmval_left 并初始化為0.用于小車的PWM調(diào)速
- unsigned char pwmval_right = 0; //變量定義pwmval_right并初始化為0.用于小車的PWM調(diào)速
- //小車啟動(dòng)時(shí)的初始占空比(左電機(jī))
- unsigned char pwmval_left_init = 8; //左電機(jī)占空比調(diào)節(jié) ,調(diào)節(jié)值在0到20之間,調(diào)節(jié)此值可調(diào)節(jié)小車速度。
- unsigned char pwmval_right_init = 8; //右電機(jī)占空比調(diào)節(jié),調(diào)節(jié)值在0到20之間,調(diào)節(jié)此值可調(diào)節(jié)小車速度。
- bit right_pwm = 1; //右電機(jī)PWM開關(guān),為1時(shí)打開
- bit left_pwm = 1; //左電機(jī)PWM開關(guān),為1時(shí)打開
- bit bz_flag1 = 1; //超聲波避障標(biāo)志變量
- unsigned char lyen = 0; //小車工作模式標(biāo)識(為0時(shí)表示小車暫停,為1時(shí)表示工作在避障模式,為2表示工作在循跡模式)
- long int distance = 0; //用于暫存超聲波模塊測到的距離
- long int distance1 = 0; //用于轉(zhuǎn)存超聲波模塊測到的距離
- unsigned char count; //count變量用于超聲波測距
- unsigned char UART_data;
- void delay(int In,int Out) //定義延時(shí)函數(shù)
- inti,j;
- for(i = 0;i < In;i++ )
- for( j = 0;j < Out;j++ )
- void delayt(unsigned int x) //延時(shí)函數(shù)
- unsigned char j;
- while(x-- > 0)
- for(j = 0;j < 125;j++)
- void Delay5Ms(void) //延時(shí)函數(shù)
- unsigned int TempCyc = 3552;
- while(TempCyc--);
- /**************************讀狀態(tài)函數(shù)***************************/
- unsigned char ReadStatusLCD(void) //讀液晶狀態(tài)函數(shù)
- LCD_Data = 0xFF; //給液晶1602的數(shù)據(jù)口置0xff
- LCD_RS = 0; //控制液晶的RS管腳為低電平
- LCD_RW = 1; //控制液晶的RW管腳為高電平
- LCD_E = 0; //控制液晶的E管腳為低電平
- LCD_E = 1;
- while (LCD_Data & Busy); //檢測忙信號
- return(LCD_Data);
- /**************************寫數(shù)據(jù)函數(shù)***************************/
- void WriteDataLCD(unsigned char WDLCD)
- ReadStatusLCD(); //檢測忙
- LCD_Data = WDLCD; //將數(shù)據(jù)寫入液晶的數(shù)據(jù)口
- LCD_E = 0; //控制液晶的E管腳為低電平(若晶振速度太高可以在這后加小的延時(shí))
- LCD_E = 0; //控制液晶的E管腳為低電平(設(shè)置兩次,相當(dāng)于小小的延時(shí))
- LCD_RS = 1; //控制液晶的RS管腳為高電平
- LCD_RW = 0; //控制液晶的RW管腳維低電平
- LCD_E = 1; //控制液晶的E管腳為高電平
- /*************************寫指令函數(shù)****************************/
- void WriteCommandLCD(unsigned charWCLCD,BuysC) //BuysC為0時(shí)忽略忙檢測
- if(BuysC) ReadStatusLCD(); //根據(jù)需要檢測忙
- LCD_Data = WCLCD; //給液晶寫命令
- LCD_E = 0; //將液晶的管腳E設(shè)置成0,若晶振速度太高可以在這后加小的延時(shí)
- LCD_E = 0; //延時(shí)
- LCD_RS = 0; //將液晶的RS設(shè)置成0
- LCD_RW = 0; //將液晶的RW設(shè)置成0
- LCD_E = 1; //將液晶的E設(shè)置成1
- LCD_E = 0; //將液晶的E設(shè)置成0
- /***************************LCD初始化***************************/
- void LCDInit(void) //LCD初始化
- LCD_Data = 0;
- WriteCommandLCD(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號(給液晶寫命令0x38)
- Delay5Ms(); //延時(shí) 5ms
- WriteCommandLCD(0x38,0); //給液晶寫命令0x38
- WriteCommandLCD(0x38,1); //顯示模式設(shè)置, 開始要求每次檢測忙信號 (給液晶寫命令0x38)
- WriteCommandLCD(0x08,1); //關(guān)閉顯示,(給液晶寫命令0x08)
- WriteCommandLCD(0x01,1); //顯示清屏 ,(給液晶寫命令0x01)
- WriteCommandLCD(0x06,1); //顯示光標(biāo)移動(dòng)設(shè)置 ,(給液晶寫命令0x06)
- WriteCommandLCD(0x0C,1); //顯示開及光標(biāo)設(shè)置 , (給液晶寫命令0x0C)
- /**********************按指定位置顯示一個(gè)字符*********************/
- void DisplayOneChar(unsigned char X,unsigned char Y, unsigned char DData)
- Y&= 0x1;
- X&= 0xF; //限制X不能大于15,Y不能大于1
- if(Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
- X |=0x80; //算出指令碼
- WriteCommandLCD(X, 0); //這里不檢測忙信號,發(fā)送地址碼
- WriteDataLCD(DData); //將需要顯示的字符發(fā)給液晶
- /***********************按指定位置顯示一串字符********************/
- void DisplayListChar(unsigned char X,unsigned char Y, unsigned char code *DData)
- unsigned char ListLength;
- ListLength = 0;
- Y&= 0x1;
- while (DData[ListLength]>=0x20) //若到達(dá)字串尾則退出
- if(X <= 0xF) //X坐標(biāo)應(yīng)小于0xF
- DisplayOneChar(X, Y, DData[ListLength]); //依次顯示單個(gè)字符,最終完成一串字符的顯示
- ListLength++;
- X++;
- void Init_Parameter(void) //超聲波模塊初始化
- TRIG = 1; //將超聲波模塊的trig管腳設(shè)置成高電平
- ECHO = 1; //將超聲波模塊的echo管腳設(shè)置成低電平
- count = 0; //將變量count設(shè)置成0
- distance = 0; //將變量distance設(shè)置成0
- void Trig_SuperSonic(void) //控制超聲波模塊發(fā)出超聲波
- TRIG= 1; //設(shè)置超聲波模塊的trig為高,發(fā)出超聲波
- delayt(1); //延時(shí)
- TRIG= 0; //設(shè)置超聲波模塊的trig為低,停止發(fā)出超聲波
- void Measure_Distance(void) //距離計(jì)算函數(shù)
- unsigned char l;
- unsigned int h,y;
- TR0= 1; //讓定時(shí)器0開始計(jì)數(shù)
- while(ECHO) //等待超聲波的回波信號
- TR0= 0; //讓定時(shí)器0停止計(jì)數(shù)
- l =TL0; //讀取定時(shí)器0計(jì)數(shù)值的低8位
- h =TH0; //讀取定時(shí)器0計(jì)數(shù)值的高8位
- y =(h << 8) + l; //得到定時(shí)器總的計(jì)數(shù)值
- y =y - 0xfc66; //us部分
- distance = y + 1000 * count; //計(jì)算總時(shí)間
- TL0= 0x66; //重置定時(shí)器0的tl0
- TH0= 0xfc; //重置定時(shí)器0的th0
- delayt(30); //延時(shí)
- distance = SPEED_30C * distance / 20000; //計(jì)算距離值
- distance1 = distance; //將距離值放在變量distance1中
- void forward(void) //小車前進(jìn)控制函數(shù)
- IN1= 1; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN1設(shè)置成高電平
- IN2= 0; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN2設(shè)置成低電平
- IN3= 1; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN3設(shè)置成高電平
- IN4= 0; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN4設(shè)置成低電平
- void back(void) //小車后退控制函數(shù)
- IN1= 0; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN1設(shè)置成低電平
- IN2= 1; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN2設(shè)置成高電平
- IN3= 0; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN3設(shè)置成低電平
- IN4= 1; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN4設(shè)置成高電平
- void stop(void) //小車停止控制函數(shù)
- void left(void) //小車向左轉(zhuǎn)控制函數(shù)
- void right(void) //小車向右轉(zhuǎn)控制函數(shù)
- void circle_right(void) //小車向右打轉(zhuǎn)控制函數(shù)
- IN1= 1; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN1設(shè)置成低電平
- IN2= 0; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN2設(shè)置成高電平
- IN3= 0; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN3設(shè)置成高電平
- IN4= 1; //將電機(jī)驅(qū)動(dòng)芯片L298N的控制管腳 IN4設(shè)置成低電平
- void left_moto(void) //小車左電機(jī)PWM調(diào)速控制函數(shù)
- if(left_pwm) //如果變量left_pwm為1,執(zhí)行左電機(jī)pwm調(diào)速功能(left_pwm相當(dāng)于一個(gè)開關(guān),只有為1時(shí)才有pwm調(diào)速功能)
- if(pwmval_left <= pwmval_left_init) //當(dāng)pwmval_left小于等于pwm_left_init時(shí)
- EN1 = 1;
- //將電機(jī)驅(qū)動(dòng)芯片的EN1管腳設(shè)置成高電平
- else //當(dāng)pwmval_left小不于等于pwm_left_init時(shí)
- EN1 = 0;
- //將電機(jī)驅(qū)動(dòng)芯片的EN1管腳設(shè)置成低電平
- if(pwmval_left >= 20) //如果 pwmval_left大于等于20
- pwmval_left = 0; //將 pwmval_left設(shè)為0
- else // 如果變量left_pwm為0,將電機(jī)驅(qū)動(dòng)芯片的EN1管腳設(shè)置成低電平 (left_pwm相當(dāng)于一個(gè)開關(guān),只有為1時(shí)才有pwm調(diào)速功能)
- EN1= 0;
- void right_moto(void) //小車右電機(jī)PWM調(diào)速控制函數(shù)
- if(right_pwm) //如果變量right_pwm為1,執(zhí)行右電機(jī)pwm調(diào)速功能(right_pwm相當(dāng)于一個(gè)開關(guān),只有為1時(shí)才有pwm調(diào)速功能)
- if(pwmval_right <= pwmval_right_init) //當(dāng)pwmval_right小于等于pwm_right_init時(shí)
- EN2 = 1; //將電機(jī)驅(qū)動(dòng)芯片的EN2管腳設(shè)置成高電平
- else if(pwmval_right > pwmval_right_init) //當(dāng)pwmval_right小不于等于pwm_right_init時(shí)
- EN2 = 0; //將電機(jī)驅(qū)動(dòng)芯片的EN2管腳設(shè)置成低電平
- if(pwmval_right >= 20) //如果 pwmval_right大于等于20
- pwmval_right = 0; //將 pwmval_right設(shè)為0
- else //如果變量right_pwm為0,將電機(jī)驅(qū)動(dòng)芯片的EN2管腳設(shè)置成低電平 (right_pwm相當(dāng)于一個(gè)開關(guān),只有為1時(shí)才有pwm調(diào)速功能)
- EN2= 0;
- void timer0_init() //定時(shí)器0初始化 ,此定時(shí)器用于超聲波模塊測距
- TMOD|=0x01; //設(shè)置定時(shí)器的工作模式
- TH0=0xfc; //設(shè)置定時(shí)器0為1ms定時(shí)
- TL0=0x66; //設(shè)置定時(shí)器0為1ms定時(shí)
- TR0=1; //啟動(dòng)定時(shí)器0的計(jì)數(shù)
- ET0=1; //開定時(shí)器0中斷
- EA =1; //開總中斷
- /* 串口配置函數(shù),baud-通信波特率 */
- void ConfigUART(unsigned int baud)
- SCON = 0x50; //配置串口為模式1
- TMOD &= 0x0F; //清零T1的控制位
- TMOD |= 0x20; //配置T1為模式2
- TH1 = 256 - (11059200/12/32)/baud; //計(jì)算T1重載值
- TL1 = TH1; //初值等于重載值
- ET1 = 0; //禁止T1中斷
- TR1 = 1; //啟動(dòng)T1
- EA=1;
- ES=1;
- void timer2_init() //定時(shí)器2初始化 ,此定時(shí)器用于pwm調(diào)速
- T2CON=0; //設(shè)置定時(shí)器的T2CON,設(shè)置T2為內(nèi)部定時(shí)器,T2EX的跳變對定時(shí)器2無效
- T2MOD=0; //定時(shí)器2輸出使能,定時(shí)器遞增計(jì)數(shù)
- /// 以下設(shè)置將定時(shí)器2的輸出頻率設(shè)置成42HZ///
- RCAP2H = (0xFFFF-0x400)/256; //設(shè)置定時(shí)器2的RCAP2H為254
- RCAP2L = (0xFFFF-0x400)%256; //設(shè)置定時(shí)器2的RCAP2L為255
- TH2 =RCAP2H; //將RCAP2H中的值(254)重裝到TH2中
- TL2 =RCAP2L; //將RCAP2L中的值(255)重裝到TL2中
- TR2 =1; //開啟定時(shí)器2計(jì)數(shù)
- ET2 =1; //開啟定時(shí)器2中斷
- EA =1; //開總中斷
- void PROCESS(void) //藍(lán)牙遙控與工作模式切換處理函數(shù)
- if(key1 == 0)
- Delay5Ms();
- if (key1 == 0)
- while(!key1);
- lyen=0;
- DisplayListChar(0,0,table0); //在液晶上顯示字體 SL-51B
- DisplayListChar(0,1,table1); //在液晶上顯示字體 ECHO
- if(key2 == 0)
- Delay5Ms();
- if (key2 == 0)
- while(!key2);
- lyen=1; //如果小車單片機(jī)接收到的命令是將小車工作模式切換成避障模式
- DisplayListChar(0,0,table2); //在液晶上顯示字體 SL-51B
- DisplayListChar(0,1,table3); //在液晶上顯示字體 ECHO
- stop(); //控制小車停下 //將小車工作模式切換到避障模式(非藍(lán)牙遙控模式)
- pwmval_left_init = 8;
- pwmval_right_init = 8;
- if(key3 == 0)
- Delay5Ms();
- if (key3 == 0)
- while(!key3);
- lyen=2; //如果小車單片機(jī)接收到的命令是將小車工作模式切換成循跡模式
- DisplayListChar(0,0,table4); //在液晶上顯示字體
- stop();
- pwmval_left_init = 6;
- pwmval_right_init = 6; //控制小車停下 //將小車工作模式切換到循跡模式(非藍(lán)牙遙控模式)
- if(key4 == 0)
- Delay5Ms();
- if (key4 == 0)
- while(!key4);
- lyen=3; //如果小車單片機(jī)接收到的命令是將小車工作模式切換成無線遙控模式
- DisplayListChar(0,0,table5); //在液晶上顯示字體
- stop(); //將小車工作模式切換到循跡模式(非藍(lán)牙遙控模式)
- void PROCESS1(void)//ok //避障處理函數(shù)
- if((distance1>=300)||(distance1 == 0)) //超聲波模塊測到障礙物在30毫米外
- bz_flag1 = 0; //將標(biāo)志變量bz_flag1設(shè)置成0
- else
- bz_flag1 = 1; //否則將標(biāo)志變量bz_flag1設(shè)置成1
- if(bz_flag1 == 0) //如果標(biāo)志變量bz_flag1和標(biāo)志變量bz_flag2都為0(表示超聲波模塊和紅外避障模塊都沒有感應(yīng)到障礙物)
- forward(); //智能小車前進(jìn)
- elseif(bz_flag1 == 1) //超聲波模塊或紅外避障模塊感應(yīng)到障礙物
- back(); //小車后退
- delay(20,1000); //延時(shí)
- circle_right(); //小車轉(zhuǎn)個(gè)角度
- delay(5,500); //延時(shí)
- distance1 = 0; //將變量distance1清零
- void display(int number) //顯示距離值
- unsigned char b,c,d,e;
- b =(number/1000); //計(jì)算出距離的百位
- c =(number/100)%10; //計(jì)算出距離的十位
- d =(number/10)%10; //計(jì)算出距離的個(gè)位
- e =number%10; //計(jì)算出距離的小數(shù)位
- DisplayOneChar(9,1,(0x30+b)); //顯示距離的百位
- DisplayOneChar(10,1,(0x30+c)); //顯示距離的十位
- DisplayOneChar(11,1,(0x30+d)); //顯示距離的個(gè)位
- DisplayOneChar(13,1,(0x30+e)); //顯示距離的小數(shù)位
- void PROCESS2(void) //ok //超聲波模塊測距函數(shù)
- Trig_SuperSonic(); //觸發(fā)超聲波發(fā)射
- while(ECHO == 0) //等待回聲
- Measure_Distance(); //計(jì)算脈寬并轉(zhuǎn)換為距離
- DisplayListChar(0,1,table3); //在液晶1602上顯示distance字體
- display(distance); //顯示距離值
- Init_Parameter(); //參數(shù)重新初始化
- delayt(100); //延時(shí),兩次發(fā)射之間要至少有10ms間隔
- void PROCESS3(void) // 白0 黑1 //循跡處理函數(shù)
- if((left_led == 1) && (right_led ==1)&& (zhong_led == 1)) //全是黑線
- pwmval_left_init = 5;
- pwmval_right_init = 5;
- forward(); //調(diào)用前進(jìn)函數(shù)
- if((left_led == 0 && right_led ==0&& zhong_led == 0)||(left_led == 0 && right_led == 0&&zhong_led == 1)) //全是白線,或中間檢測到黑線
- if((left_led == 1) && (right_led == 0) ) //左邊檢測到黑線
- pwmval_left_init = 4;
- pwmval_right_init = 4;
- left(); //調(diào)用小車左轉(zhuǎn)函數(shù)
- while(!zhong_led);
- // right();
- // delayt(150);
- forward();
- // delay(50,50);Delay5Ms() ;
- if((right_led == 1) && (left_led == 0)) //右邊檢測到黑線
- right(); //調(diào)用小車右轉(zhuǎn)函數(shù)
- // left();
- // delayt(150);
- forward();
- //delay(50,50); Delay5Ms(); (zhong_led == 1)
- //系統(tǒng)初始化函數(shù)
- void sys_init(void)
- timer0_init(); //定時(shí)器0初始化
- timer2_init(); //定時(shí)器2初始化
- ConfigUART(9600); //配置波特率為9600
- Init_Parameter(); //超聲波模塊初始化
- EA =1; //打開總中斷
- LCDInit(); //液晶1602初始化
- void main(void) //主函數(shù)
- sys_init(); //系統(tǒng)初始化函數(shù)
- while(1) //while(1)循環(huán)(死循環(huán))
- PROCESS(); //調(diào)用小車工作模式切換處理函數(shù)
- if(lyen== 0) //暫停模式
- stop();
- } //調(diào)用超聲波模塊測距函數(shù)
- if(lyen == 1) //如果小車工作在避障工作模式
- PROCESS2(); //當(dāng)前工作模式是避障模式
- PROCESS1(); //調(diào)用避障處理函數(shù)
- if(lyen == 2) //當(dāng)前工作模式是循跡模式
- PROCESS3(); //調(diào)用循跡處理函數(shù)
- void timer0()interrupt 1 using 2 //定時(shí)器0中斷處理函數(shù)
- TF0= 0; //清定時(shí)器0中斷標(biāo)志
- TL0= 0x66; //重置定時(shí)器0的TL0
- TH0= 0xfc; //重置定時(shí)器0的TH0
- count++; //變量count加1,count用于超聲波測距,每毫秒count加1(定時(shí)器0每毫秒中斷一次)
- if(count == 18) //超聲波回聲脈寬最多18ms
- TR0=0; //定時(shí)器0停止計(jì)數(shù)
- count = 0; //變量count置0
- void timer2()interrupt 5 using 1 //定時(shí)器2中斷處理函數(shù)
- TF2= 0; //清定時(shí)器2中斷標(biāo)志
- pwmval_left = pwmval_left + 1; //變量pwmval_left加1,用于小車PWM調(diào)速
- pwmval_right = pwmval_right + 1; //變量pwmval_right加1,用于小車PWM調(diào)速
- left_moto(); //調(diào)用小車左電機(jī)調(diào)速函數(shù)
- right_moto(); //調(diào)用小車右電機(jī)調(diào)速函數(shù)
- /************串行口1中斷處理函數(shù)*************/
- void ser() interrupt 4
- if(RI)
- UART_data=SBUF;
- if(lyen== 3)
- switch(UART_data)
- case 'a':forward();break; //前
- case 'b':back(); break; //后
- case 'c':left(); break; //左
- case 'd':right(); break; //右
- case 'e':stop(); break; //停
- RI=0;
