查看: 3771|回復(fù): 9
*** ERROR L211: I/O ERROR ON OUTPUT FILE Keil 編譯時(shí)出現(xiàn)問(wèn)題,請(qǐng)幫指點(diǎn)一下
ID:46943 發(fā)表于 2022-4-26 21:28 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
Build started: Project: Project
Build target 'Target 1'
linking...
LX51 LINKER/LOCATER V4.66.97.0 - SN: K1DZC-4GYRBC
COPYRIGHT ARM Germany GmbH 1995 - 2019
@..\Project.lnp "..\main.obj"
TO "..\Project"
Rtx51Tiny
PRINT(".\Listings\Project.map")
*** ERROR L211: I/O ERROR ON OUTPUT FILE:
    EXCEPTION 0029H: ACCESS TO FILE DENIED
    FILE: ..\Project
Target not created.
Build Time Elapsed:  00:00:01
ID:46943 發(fā)表于 2022-4-26 21:29 | 只看該作者
#include "datatype.h"
#include "menu.h"
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
void func(void)
//首先定義一個(gè)菜單結(jié)構(gòu)體
typedef struct menu                      //定義一個(gè)菜單
unsigned char range_from,range_to;     //當(dāng)前顯示的項(xiàng)開始及結(jié)束序號(hào)
unsigned char itemCount;               //項(xiàng)目總數(shù)
unsigned char selected;                //當(dāng)前選擇項(xiàng)
unsigned char *menuItems[17];                  //菜單項(xiàng)目
struct menu **subMenus;                //子菜單
struct menu *parent;                   //上級(jí)菜單 ,如果是頂級(jí)則為null
void (**func)();                       //選擇相應(yīng)項(xiàng)按確定鍵后執(zhí)行的函數(shù)
}Menu;
Menu MainMenu = {                       //定義主菜單
0,3,4,0,                               //默認(rèn)顯示0-3項(xiàng),總共4項(xiàng),當(dāng)前選擇第0項(xiàng)
  "測(cè)量表          ",                   //  >表示有下級(jí)選項(xiàng)
  "其他設(shè)置        ",
  "保護(hù)設(shè)定        ",
  "查詢           >"
Menu searchMenu = {                    //查詢菜單
0,3,6,0,
  "記帳記錄明細(xì)   ",
  "未采集記錄數(shù)   ",
  "設(shè)備機(jī)號(hào)       ",
  "本機(jī)IP地址     ",
  "記錄空間大小   ",
  "軟件版本       "
Menu *currentMenu;                               //當(dāng)前的菜單
//初始化菜單:
void initMenu()
char mempool[512];
init_mempool (&mempool, sizeof(mempool));
MainMenu.subMenus = malloc(sizeof(&MainMenu)*4);
MainMenu.subMenus[0] = &searchMenu;//第1到3項(xiàng)沒有子菜單置null,選擇后程序會(huì)調(diào)用func中相應(yīng)項(xiàng)中的函數(shù)
MainMenu.subMenus[1] = NULL;
MainMenu.subMenus[2] = NULL;
MainMenu.subMenus[3] = NULL;//第四項(xiàng)查詢有子菜單
MainMenu.func = malloc(sizeof(&func)*4);
MainMenu.func[0] = NULL;
MainMenu.func[1] = NULL;
MainMenu.func[2] = &func;//當(dāng)選擇了并按了確定,會(huì)執(zhí)行func函數(shù)
MainMenu.func[3] = NULL;
MainMenu.parent = NULL;//表示是頂級(jí)菜單
searchMenu.subMenus = malloc(sizeof(&searchMenu)*6);
searchMenu.subMenus[0] = searchMenu.subMenus[1] = searchMenu.subMenus[2] = searchMenu.subMenus[3] = searchMenu.subMenus[4] = searchMenu.subMenus[5] = NULL;
searchMenu.func = malloc(sizeof(&printf)*6);
searchMenu.func[0] = searchMenu.func[1] = searchMenu.func[2] = searchMenu.func[3] = searchMenu.func[4] = searchMenu.func[5] = NULL;
searchMenu.parent = &MainMenu;//上一級(jí)菜單是MainMenu.進(jìn)入查詢子菜單后按返回鍵,將會(huì)顯示這個(gè)菜單項(xiàng)
currentMenu = &MainMenu;
void main(void)
以上是代碼
ID:301191 發(fā)表于 2022-4-27 03:17 | 只看該作者
頂一下
ID:46943 發(fā)表于 2022-4-27 13:35 來(lái)自觸屏版 | 只看該作者
有沒有高手指點(diǎn)一下,感覺是keil設(shè)置問(wèn)題
ID:161164 發(fā)表于 2022-4-27 14:56 | 只看該作者
你把Project 和 Hex的output路徑放到哪里了?
Keil沒有權(quán)限產(chǎn)生檔案
ID:951528 發(fā)表于 2022-4-27 15:10 | 只看該作者
output要自己選路徑的,好比你買快遞又不給人家收貨地址
ID:883242 發(fā)表于 2022-4-27 15:29 | 只看該作者
早年C51必須用DOS8.3文件名,包括路徑名,舉個(gè)栗子,12345678.ABC,如果長(zhǎng)度長(zhǎng)了就認(rèn)不出來(lái),會(huì)出現(xiàn)系統(tǒng)IO錯(cuò)誤,無(wú)法生成文件。
ID:46943 發(fā)表于 2022-4-27 17:59 | 只看該作者
zenmoleshi 發(fā)表于 2022-4-27 15:10
指定了output文件夾
ID:46943 發(fā)表于 2022-4-27 18:02 | 只看該作者
lkc8210 發(fā)表于 2022-4-27 14:56
謝謝了,重新指定了output文件夾,剛試了一下編譯通過(guò)了
