main.c 部分
#include <REGX52.H>
#include "LCD1602.h"
LCD_Init();
LCD_ShowChar(1,1,'n');
LCD1602.H 部分
#ifndef __LCD1602_H__
#define __LCD1602_H__
//用戶(hù)調(diào)用函數(shù):
void LCD_Init();
void LCD_ShowChar(unsigned char Line,unsigned char Column,char Char);
void LCD_ShowString(unsigned char Line,unsigned char Column,char *String);
void LCD_ShowNum(unsigned char Line,unsigned char Column,unsigned int Number,unsigned char Length);
void LCD_ShowSignedNum(unsigned char Line,unsigned char Column,int Number,unsigned char Length);
void LCD_ShowHexNum(unsigned char Line,unsigned char Column,unsigned int Number,unsigned char Length);
void LCD_ShowBinNum(unsigned char Line,unsigned char Column,unsigned int Number,unsigned char Length);
#endif
LCD1602.c部分
#include <REGX52.H>
//引腳配置:
sbit LCD_RS=P3^4;
sbit LCD_RW=P3^5;
sbit LCD_EN=P3^6;
#define LCD_DataPort P0
//函數(shù)定義:
* @brief LCD1602延時(shí)函數(shù),12MHz調(diào)用可延時(shí)1ms
* @param 無(wú)
* @retval 無(wú)
void LCD_Delay()
unsigned char i, j;
i = 2;
j = 239;
do
while (--j);
} while (--i);
* @brief LCD1602寫(xiě)命令
* @param Command 要寫(xiě)入的命令
* @retval 無(wú)
void LCD_WriteCommand(unsigned char Command)
LCD_RS=0;
LCD_RW=0;
LCD_DataPort=Command;
LCD_EN=1;
LCD_Delay();
LCD_EN=0;
LCD_Delay();
* @brief LCD1602寫(xiě)數(shù)據(jù)
* @param Data 要寫(xiě)入的數(shù)據(jù)
* @retval 無(wú)
void LCD_WriteData(unsigned char Data)
LCD_RS=1;
LCD_RW=0;
LCD_DataPort=Data;
LCD_EN=1;
LCD_Delay();
LCD_EN=0;
LCD_Delay();
* @brief LCD1602設(shè)置光標(biāo)位置
* @param Line 行位置,范圍:1~2
* @param Column 列位置,范圍:1~16
* @retval 無(wú)
void LCD_SetCursor(unsigned char Line,unsigned char Column)
if(Line==1)
LCD_WriteCommand(0x80|(Column-1));
else if(Line==2)
LCD_WriteCommand(0x80|(Column-1+0x40));
* @brief LCD1602初始化函數(shù)
* @param 無(wú)
* @retval 無(wú)
void LCD_Init()
LCD_WriteCommand(0x38);//八位數(shù)據(jù)接口,兩行顯示,5*7點(diǎn)陣
LCD_WriteCommand(0x0c);//顯示開(kāi),光標(biāo)關(guān),閃爍關(guān)
LCD_WriteCommand(0x06);//數(shù)據(jù)讀寫(xiě)操作后,光標(biāo)自動(dòng)加一,畫(huà)面不動(dòng)
LCD_WriteCommand(0x01);//光標(biāo)復(fù)位,清屏
* @brief 在LCD1602指定位置上顯示一個(gè)字符
* @param Char 要顯示的字符
* @retval 無(wú)
LCD_SetCursor(Line,Column);
LCD_WriteData(Char);
* @brief 在LCD1602指定位置開(kāi)始顯示所給字符串
* @param Line 起始行位置,范圍:1~2
* @param Column 起始列位置,范圍:1~16
* @param String 要顯示的字符串
* @retval 無(wú)
unsigned char i;
for(i=0;String[ i]!='\0';i++)
LCD_WriteData(String[ i]);
* @brief 返回值=X的Y次方
int LCD_Pow(int X,int Y)
unsigned char i;
int Result=1;
for(i=0;i<Y;i++)
Result*=X;
return Result;
* @brief 在LCD1602指定位置開(kāi)始顯示所給數(shù)字
* @param Number 要顯示的數(shù)字,范圍:0~65535
* @param Length 要顯示數(shù)字的長(zhǎng)度,范圍:1~5
* @retval 無(wú)
unsigned char i;
for(i=Length;i>0;i--)
LCD_WriteData(Number/LCD_Pow(10,i-1)%10+'0');
* @brief 在LCD1602指定位置開(kāi)始以有符號(hào)十進(jìn)制顯示所給數(shù)字
* @param Number 要顯示的數(shù)字,范圍:-32768~32767
* @retval 無(wú)
unsigned char i;
unsigned int Number1;
if(Number>=0)
LCD_WriteData('+');
Number1=Number;
LCD_WriteData('-');
Number1=-Number;
LCD_WriteData(Number1/LCD_Pow(10,i-1)%10+'0');
* @brief 在LCD1602指定位置開(kāi)始以十六進(jìn)制顯示所給數(shù)字
* @param Number 要顯示的數(shù)字,范圍:0~0xFFFF
* @param Length 要顯示數(shù)字的長(zhǎng)度,范圍:1~4
* @retval 無(wú)
unsigned char i,SingleNumber;
SingleNumber=Number/LCD_Pow(16,i-1)%16;
if(SingleNumber<10)
LCD_WriteData(SingleNumber+'0');
LCD_WriteData(SingleNumber-10+'A');
* @brief 在LCD1602指定位置開(kāi)始以二進(jìn)制顯示所給數(shù)字
* @param Number 要顯示的數(shù)字,范圍:0~1111 1111 1111 1111
* @param Length 要顯示數(shù)字的長(zhǎng)度,范圍:1~16
* @retval 無(wú)
unsigned char i;
LCD_WriteData(Number/LCD_Pow(2,i-1)%2+'0');
還附帶的51單片機(jī)的原理圖 哪里還需要修改 顯示屏無(wú)法顯示數(shù)字
