查看: 1380|回復(fù): 4
單片機+LCD1602A液晶時鐘程序的顯示的問題 時間不能順著table1中的值繼續(xù)加
ID:961087 發(fā)表于 2022-4-29 10:37 | 顯示全部樓層 |閱讀模式
問題詳述:當(dāng)液晶顯示時間時,時間不能順著table1中的值繼續(xù)加,比如剛通電秒顯示的是50,然后跳一秒立馬01開始了,而經(jīng)過按鍵盡心設(shè)置的時間就可以跟著設(shè)置的值,想優(yōu)化下讓他能夠根據(jù)輸入的時間直接進行累加,而不是動一秒返回01重新開始。
附件說明:開發(fā)板原理圖。
圖片說明:程序現(xiàn)象。
以下為全部單片機程序:
#include <REGX52.H>
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit RW=P3^6;
sbit lcden=P3^4;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit rd=P3^7;
uchar code table[]="  2022-04-28 WED";
uchar code table1[]="    09:59:50";
uchar count,key1num;
char shi,fen,miao;
void write_sfm(uchar add,uchar date);
void delay(uint xms)
        uint i,j;
        for(i=xms;i>0;i--);
        for(j=110;j>0;j--);
void write_com(uchar com)
        rs=0;
        RW=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        RW=0;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void LCDINIT()
        uchar num;
        dula=0;
        wela=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<15;num++)
                write_date(table[num]);
                delay(5);
        write_com(0x80+0x40);
        for(num=0;num<12;num++)
                write_date(table1[num]);
                delay(5);
void INIT()
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void keyscan()
        rd=0;
        if(key1==0)
                delay(5);
                if(key1==0)
                        key1num++;
                        while(!key1);
                        //key1num++;
                        if(key1num==1)
                                TR0=0;
                                write_com(0x80+0x40+11);
                                write_com(0x0f);
                        if(key1num==2)
                                TR0=0;
                                write_com(0x80+0x40+8);
                                write_com(0x0f);//1a±êéá˸
                        if(key1num==3)
                                TR0=0;
                                write_com(0x80+0x40+5);
                                write_com(0x0f);
                        if(key1num==4)
                                key1num=0;
                                TR0=1;
                                //write_com(0x80+0x40+11);
                                write_com(0x0c);
                        //else
                        if(key1num!=0)
                                if(key2==0)
                                        delay(5);
                                        if(key2==0)
                                                while(!key2);
                                                if(key1num==1)
                                                        miao++;
                                                        if(miao==60)
        miao=0;
                                                        write_com(0x80+0x40+10);
                                                        write_sfm(10,miao);
                                                if(key1num==2)
                                                        fen++;
                                                        if(fen==60)
                                                        fen=0;
                                                        write_sfm(7,fen);
                                                        write_com(0x80+0x40+7);
                                                if(key1num==3)
                                                        shi++;
                                                        if(shi==24)
                                                        shi=0;
                                                        write_sfm(4,shi);
                                                        write_com(0x80+0x40+4);
                                if(key3==0)
                                        delay(5);
                                        if(key3==0)
                                                while(!key3);
                                                if(key1num==1)
                                                        /*miao--;
                                                        if(miao==0)
        miao=59;
        write_sfm(10,miao);
                                                        miao--;
                                                        if(miao==-1)
        miao=59;
        write_sfm(10,miao);
                                                if(key1num==2)
                                                        fen--;
                                                        if(fen==-1)
        fen=59;
                                                        write_sfm(7,fen);
                                                if(key1num==3)
                                                        shi--;
                                                        if(shi==-1)
        shi=23;
                                                        write_sfm(4,shi);
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
        LCDINIT();
        INIT();
                keyscan();
        //while(1);
void time0() interrupt 1
        count++;
        if(count==18)
                 count=0;
                miao++;
                if(miao==60)
                        miao=0;
                        fen++;
                        if(fen==60)
                                fen=0;
                                shi++;
                                if(shi==24)
                                        shi=0;
                        write_sfm(4,shi);
                write_sfm(7,fen);
        write_sfm(10,miao);
TX-1C增強版原理圖.pdf
243.32 KB, 下載次數(shù): 11
ID:161164 發(fā)表于 2022-4-29 11:20 來自手機 | 顯示全部樓層
因為maio的初始值不是50而是0
ID:961087 發(fā)表于 2022-4-29 11:50 | 顯示全部樓層
lkc8210 發(fā)表于 2022-4-29 11:20
因為maio的初始值不是50而是0
謝謝指點,就是怎么可以優(yōu)化成那種可以從我顯示的值直接往上加這個問題,不知道怎么優(yōu)化了.
ID:161164 發(fā)表于 2022-4-29 13:25 | 顯示全部樓層
char shi =9,fen=59,miao=50;
ID:961087 發(fā)表于 2022-4-29 14:55 | 顯示全部樓層
lkc8210 發(fā)表于 2022-4-29 13:25
好的,謝謝,已經(jīng)優(yōu)化測試,非常感謝
