可以通過按鍵控制角度增減,程序和仿真齊全,可以運行,相互交流。
單片機源程序如下:
#include<reg51.h>
sbit PWM0 = P1^0;
sbit PWM1 = P1^1;
sbit PWM2 = P1^2;
sbit PWM3 = P1^3;
sbit PWM4 = P1^4;
sbit PWM5 = P1^5;
sbit PWM6 = P1^6;
sbit PWM7 = P1^7;
sbit ADD = P2^1;
sbit SUB = P2^2;
uint t_up0 = 1500;
uint t_up1 = 1500; //1.5ms
uint t_up2 = 1500;
uint t_up3 = 1500;
uint t_up4 = 1500;
uint t_up5 = 1500;
uint t_up6 = 1500;
uint t_up7 = 1500;
uint t0_h;
uint t0_l;
void delayms(uint ms)
unsigned char a,b,c;
while(ms--)
for(c=1;c>0;c--)
for(b=142;b>0;b--)
for(a=2;a>0;a--);
void timer_init()
EA = 1;
ET0 = 1;
PT0 = 1;
TMOD = 0x11;
TH0 = (65536 - t_up0)/256;
TL0 = (65536 - t_up0)%256;
uchar t0_flag = 0;
uint num_max = 65535;
uint t_change = 63036;
uchar error0 = 45;
uchar error1 = 45;
uchar error2 = 52;
uchar error3 = 52;
uchar error4 = 57;
uchar error5 = 57;
uchar error6 = 63;
uchar error7 = 63;
uchar error8 = 70;
uchar error9 = 70;
uchar error10 = 76;
uchar error11 = 76;
uchar error12 = 82;
uchar error13 = 82;
uchar error14 = 88;
uchar error15 = 88;
void timer0() interrupt 1
if(t0_flag == 0)
PWM0 = 1;
TH0 = (num_max - t_up0 + error0)/256;
TL0 = (num_max - t_up0 + error0)%256;
t0_flag = 1;
else if(t0_flag == 1)
PWM0 = 0;
TH0 = (t_change + t_up0 +error1)/256;
TL0 = (t_change + t_up0 +error1)%256;
t0_flag = 2;
else if(t0_flag == 2)
PWM1 = 1;
TH0 = (num_max - t_up1 + error2)/256;
TL0 = (num_max - t_up1 + error2)%256;
t0_flag = 3;
else if(t0_flag == 3)
PWM1 = 0;
TH0 = (t_change + t_up1 +error3)/256;
TL0 = (t_change + t_up1 +error3)%256;
t0_flag = 4;
else if(t0_flag == 4)
PWM2 = 1;
TH0 = (num_max - t_up2 + error4)/256; //+£¿êÇÎaáËμÖÏûÖ′DDóï¾ä»¨μÄê±¼ä
TL0 = (num_max - t_up2 + error4)%256;
t0_flag = 5;
else if(t0_flag == 5)
PWM2 = 0;
TH0 = (t_change + t_up2 +error5)/256;
TL0 = (t_change + t_up2 +error5)%256;
t0_flag = 6;
else if(t0_flag == 6)
PWM3 = 1;
TL0 = (num_max - t_up3 + error6)%256;
t0_flag = 7;
else if(t0_flag == 7)
PWM3 = 0;
TH0 = (t_change + t_up3 +error7)/256;
TL0 = (t_change + t_up3 +error7)%256;
t0_flag = 8;
else if(t0_flag == 8)
PWM4 = 1;
TH0 = (num_max - t_up4 + error8)/256; //+£¿êÇÎaáËμÖÏûÖ′DDóï¾ä»¨μÄê±¼ä
TL0 = (num_max - t_up4 + error8)%256;
t0_flag = 9;
else if(t0_flag == 9)
PWM4 = 0;
TH0 = (t_change + t_up4 +error9)/256;
TL0 = (t_change + t_up4 +error9)%256;
t0_flag = 10;
else if(t0_flag == 10)
PWM5 = 1;
TH0 = (num_max - t_up5 + error10)/256; //+£¿êÇÎaáËμÖÏûÖ′DDóï¾ä»¨μÄê±¼ä
TL0 = (num_max - t_up5 + error10)%256;
t0_flag = 11;
else if(t0_flag == 11)
PWM5 = 0;
TH0 = (t_change + t_up5 + error11)/256;
TL0 = (t_change + t_up5 + error11)%256;
t0_flag = 12;
else if(t0_flag == 12)
PWM6 = 1;
TH0 = (num_max - t_up6 + error12)/256; //+£¿êÇÎaáËμÖÏûÖ′DDóï¾ä»¨μÄê±¼ä
TL0 = (num_max - t_up6 + error12)%256;
t0_flag = 13;
else if(t0_flag == 13)
PWM6 = 0;
TH0 = (t_change + t_up6 + error13)/256;
TL0 = (t_change + t_up6 + error13)%256;
t0_flag = 14;
else if(t0_flag == 14)
PWM7 = 1;
TH0 = (num_max - t_up7 + error14)/256; //+£¿êÇÎaáËμÖÏûÖ′DDóï¾ä»¨μÄê±¼ä
TL0 = (num_max - t_up7 + error14)%256;
t0_flag = 15;
else if(t0_flag == 15)
PWM7 = 0;
TH0 = (t_change + t_up7 + error15)/256;
TL0 = (t_change + t_up7 + error15)%256;
t0_flag = 0;
uint t_while;
timer_init();
TR0 = 1;
if(ADD == 0)
delayms(2);
if(ADD == 0)
if(t_up0 <= 1950)
t_up0 = t_up0 + 50;
t_up1 = t_up1 + 50;
t_up2 = t_up2 + 50;
t_up3 = t_up3 + 50;
t_up4 = t_up4 + 50;
t_up5 = t_up5 + 50;
t_up6 = t_up6 + 50;
t_up7 = t_up7 + 50;
t_while = 50000;
while(t_while--) //
if(ADD == 1)
break;
if(SUB == 0)
delayms(2);
if(SUB == 0)
if(t_up0 >= 1050)
t_up0 = t_up0 - 50;
t_up1 = t_up1 - 50;
t_up2 = t_up2 - 50;
t_up3 = t_up3 - 50;
t_up4 = t_up4 - 50;
t_up5 = t_up5 - 50;
t_up6 = t_up6 - 50;
t_up7 = t_up7 - 50;
t_while = 50000;
while(t_while--)
if(SUB == 1)
break;
需要雙擊單片機重新選擇hex文件:
Keil代碼與Proteus8.8仿真下載:
8路舵機.zip
(158.11 KB, 下載次數(shù): 40)
2022-5-10 17:57 上傳
點擊文件名下載附件
