查看: 1900|回復(fù): 0
單片機(jī)匯編語(yǔ)言動(dòng)態(tài)顯示程序與Proteus仿真圖
單片機(jī)匯編語(yǔ)言源程序如下:
org   0000h
      jmp   Start
; CODE SEGMENT
Start:
                MOV        R2        ,#00
                MOV        R3        ,#04
                MOV        DPTR        ,#TAB
                MOV        R7        ,#01
LP0:        MOV        A                ,R2
                MOVC        A                ,@A+DPTR
LP:        MOV        SBUF        ,A
                JNB        TI        ,$
                CLR        TI
                DJNZ        R3        ,LP
                INC        R2
                MOV        R3        ,#04
                ACALL                DEL05
                CJNE        R2        ,#10        ,LP0
                MOV        R3        ,#04
                MOV        R2        ,#00
                DEC                R7
                CJNE        R7        ,#00        ,LP0
                ACALL        DEL05
                MOV        30H        ,#00100100B
                MOV        R0        ,30H
                MOV        A                ,R0
                ANL                A                ,#0FH
                MOVC        A                ,@A+DPTR
                MOV        SBUF        ,A
                JNB                TI                ,$
                CLR                TI
                ACALL        DEL05
                MOV        A                ,R0
                ANL                A                ,#0F0H
                SWAP        A
                MOVC        A                ,@A+DPTR
                MOV        SBUF        ,A
                JNB                TI                ,$
                CLR                TI
                ACALL                DEL05
                MOV        31H        ,#01000110B
                MOV        R0        ,31H
                MOV        A                ,R0
                ANL                A                ,#0FH
                MOVC        A                ,@A+DPTR
                MOV        SBUF        ,A
                JNB                TI                ,$
                CLR                TI
                ACALL        DEL05
                MOV        A                ,R0
                ANL                A                ,#0F0H
                SWAP        A
                MOVC        A                ,@A+DPTR
                MOV        SBUF        ,A
                JNB                TI                ,$
                CLR                TI
                ACALL                DEL05
                RET
TAB:        DB        03H,9FH,25H,0DH,99H
                DB        49H,41H,1FH,01H,        09H
DEL05:                MOV        R4,#50
DEL0:                MOV        R5,#91
DEL1:                MOV        R6,#100
                                DJNZ        R6,$
                                DJNZ        R5,DEL1
                                DJNZ        R4,DEL0
                                RET
      END
用的Proteus自帶的編譯器編譯的程序
上圖Proteus8.8仿真pdsprj文件下載: 動(dòng)態(tài)顯示.zip (21.94 KB, 下載次數(shù): 6)
