制作出來的實(shí)物圖如下:
視頻不知道怎么上傳
bdata unsigned char Side_Data;
sbit bit0=Side_Data^0; //被發(fā)送數(shù)據(jù)的各位定義
sbit bit1=Side_Data^1;
sbit bit2=Side_Data^2;
sbit bit3=Side_Data^3;
sbit bit4=Side_Data^4;
sbit bit5=Side_Data^5;
sbit bit6=Side_Data^6;
sbit bit7=Side_Data^7;
code unsigned char Mode_table[21]=
0x80,0x00,0x00,
0x00,0x80,0x00,
0x00,0x00,0x80,
0x80,0x80,0x00,
0x80,0x00,0x80,
0x00,0x80,0x80,
0x80,0x80,0x80,
unsigned char Side_BufD[3]={0x00};
unsigned char Interval00,kw,iw;
//====位0發(fā)送=====
void TX0(void) // 發(fā)送0
P1_7=1; //通信IO
_nop_(); _nop_(); _nop_(); _nop_(); _nop_();
P1_7=0;
//====位1發(fā)送=====
void TX1(void) // 發(fā)送1
P1_7=1;
_nop_(); _nop_(); _nop_(); //_nop_(); _nop_();
P1_7=0;
//一字節(jié)發(fā)送
void SideSend_Byte (unsigned char *Side_Buf,unsigned char NumLed)
unsigned char idata y,k;
for(k=0;k<NumLed;k++)
for(y=0;y<3;y++)
if(bit7==1){TX1();} else{TX0();}
if(bit6==1){TX1();} else{TX0();}
if(bit5==1){TX1();} else{TX0();}
if(bit4==1){TX1();} else{TX0();}
if(bit3==1){TX1();} else{TX0();}
if(bit2==1){TX1();} else{TX0();}
if(bit1==1){TX1();} else{TX0();}
if(bit0==1){TX1();} else{TX0();}
void main(void)
CfgFsys( ); //時(shí)鐘選擇配置
mDelaymS(5);
init_global_value(); //寄存器 IO初始化
Interval00++;
if(Interval00>10) //間隔50MS
Interval00=0;
for(kw=0;kw<120;kw++) //120個(gè)LED
memset(Side_BufD,0,3);
for(iw=0;iw<3;iw++)
Side_BufD[iw]= *(Mode_table+iw+tw);
tw=tw+3;
if(tw==21)
tw=0;
SideSend_Byte(Side_BufD,1);
P1_7=0;
