超級(jí)網(wǎng)口,網(wǎng)關(guān)代碼- #include "main.h"
- #include "iwdg.h"
- #include "usart.h"
- #include "tim.h"
- #include "gpio.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "delay.h"
- #include "buzzer.h"
- #include "rs485.h"
- #include "netport.h"
- #include "relay.h"
- #include "w25qxx.h"
- #include "led.h"
- #include "process.h"
- #include "modbustcp_slave.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void MX_NVIC_Init(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- uint16_t htim22_count=0;
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_LPUART1_UART_Init();
- MX_USART1_UART_Init();
- MX_USART2_UART_Init();
- // MX_IWDG_Init();
- MX_TIM21_Init();
- MX_TIM22_Init();
- MX_TIM2_Init();
- /* Initialize interrupts */
- MX_NVIC_Init();
- /* USER CODE BEGIN 2 */
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- SPI_Flash_ReadID();
- Netport_Reset();
- BUZZER_ON;
- delay_ms(50);
- BUZZER_OFF;
- __HAL_TIM_DISABLE( &htim21 );
- RS485_1_RX;
- Sample();
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- if(netport.sta & 0x8000)
- if(netport.rx_buff[6] == 0xFF)
- //if(Check_CRC16(netport.rx_buff, netport.sta & 0x7FFF))
- RX_LED_BLINK(NETPORT);
- Process_ModbusTCP(MODBUS_TCP, netport.rx_buff, netport.sta&0x7FFF);
- netport.sta = 0;
- if(htim22_count>=50)//2.5s
- htim22_count=0;
- Sample();
- //HAL_GPIO_TogglePin( GPIOB, GPIO_PIN_7);
- // Netport_Send((uint8_t *)"123", 3);
- //delay_ms(10);
- __HAL_IWDG_RELOAD_COUNTER(&hiwdg);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
- /** Configure the main internal regulator output voltage
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
- /** Initializes the RCC Oscillators according to the specified parameters
- * in the RCC_OscInitTypeDef structure.
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.LSIState = RCC_LSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_8;
- RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_2;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB buses clocks
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
- Error_Handler();
- PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2
- |RCC_PERIPHCLK_LPUART1;
- PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
- PeriphClkInit.Usart2ClockSelection = RCC_USART2CLKSOURCE_PCLK1;
- PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
- if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
- Error_Handler();
- * @brief NVIC Configuration.
- * @retval None
- /* TIM21_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(TIM2_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(TIM2_IRQn);
- HAL_NVIC_SetPriority(TIM21_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(TIM21_IRQn);
- /* USART1_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(USART1_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(USART1_IRQn);
- /* USART2_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(USART2_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(USART2_IRQn);
- /* LPUART1_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(LPUART1_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(LPUART1_IRQn);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- __disable_irq();
- while (1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
Keil代碼下載,僅供參考:
485DTU - V1.2.7z
(5.14 MB, 下載次數(shù): 32)
2022-5-19 04:52 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
