查看: 2272|回復(fù): 0
C51單片機(jī)日歷時(shí)鐘設(shè)計(jì)
  • #include "public.h"
  • //共陽極數(shù)碼管顯示編碼
  • u16 code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  • //數(shù)碼管顯示內(nèi)容
  • bit smg_show_flag = 1;
  • bit smg_show_flag1 = 1;
  • //數(shù)碼管顯示功能,1:數(shù)碼管顯示年月日,2:數(shù)碼管顯示時(shí)分秒,3:串口輸出日期
  • u8 smg_show_mode = 1;
  • u8 time_buf[50]={0};
  • //定義年月日變量
  • u16  year = 2021;
  • u16 month = 7;
  • u16 day = 3;
  • //定義時(shí)分秒變量
  • u16 hour=3,min=12,sec,ssec;
  • //延時(shí)函數(shù)
  • void delay(u8 i)
  •    u8 k;
  •         for(k=0;k<i;k++);
  •         函數(shù)名字:TIM0_IT_Init
  •         函數(shù)功能:定時(shí)器0的中斷初始化函數(shù)
  • void Timer0Init(void)
  •         //1.配置定時(shí)器0為工作方式1
  •         TMOD |= 0x01;
  •         //2.配置TH和TL確定定時(shí)時(shí)長(zhǎng),50ms
  •         //單片機(jī)時(shí)鐘頻率為12000000Hz,定時(shí)器時(shí)鐘頻率=單片機(jī)時(shí)鐘頻率/12=1000000Hz
  •         //50ms = 50/1000 = 1/20s,所以50ms定時(shí)器計(jì)數(shù)值為1000000/20 = 50000
  •         //由于定時(shí)器是自加計(jì)數(shù)
  •         TH0 = (65535-50000) / 256;
  •         TL0 = (65535-50000) % 256;
  •         //3.啟動(dòng)定時(shí)器0開始計(jì)數(shù)
  •         TR0 = 1;
  •         //4.清零定時(shí)器0的溢出標(biāo)志位
  •         TF0 = 0;
  •         //5.打開定時(shí)器0中斷
  •         ET0 = 1;
  •         //6.打開全局中斷
  •         EA = 1;
  • //定時(shí)器1的初始化函數(shù)
  • void Timer1Init()
  •         TMOD|=0X10;
  •         TH1=0Xd8;
  •         TL1=0Xf0;
  •         ET1=1;
  •         EA=1;
  •         TR1=1;
  •         函數(shù)名字:smg_display_date
  •         函數(shù)功能:數(shù)碼管顯示日期函數(shù)
  •         參數(shù):顯示的內(nèi)容標(biāo)志:1:年,0:月和日
  • void smg_display_date(u8 showflag)
  •         u8 i;
  •         if(showflag == 1)
  •                 for(i=0; i<4; i++)
  •                         switch(i)
  •                                 //進(jìn)行數(shù)碼管位選1,點(diǎn)亮第1位數(shù)碼管
  •                                 case 0:        WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[year/1000%10];break;
  •                                 //進(jìn)行數(shù)碼管位選2,點(diǎn)亮第2位數(shù)碼管
  •                                 case 1:        WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[year/100%10];break;
  •                                 //進(jìn)行數(shù)碼管位選3,點(diǎn)亮第3位數(shù)碼管
  •                                 case 2:        WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[year/10%10];break;
  •                                 //進(jìn)行數(shù)碼管位選4,點(diǎn)亮第4位數(shù)碼管
  •                                 case 3:        WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[year%10];break;
  •                         //點(diǎn)亮延時(shí)2ms
  •                 delay(2000);
  •                         //關(guān)顯示
  •                         SMG_PORT = 0xff;
  •         else if(showflag == 0)
  •                         switch(i)
  •                                 case 0:        WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[month/10%10];break;
  •                                 case 1:        WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[month%10];break;
  •                                 case 2:        WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[day/10%10];break;
  •                                 case 3:        WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[day%10];break;
  •                         delay(2000);
  •                         //關(guān)顯示
  •                         SMG_PORT = 0xff;
  • void smg_display_time(u8 showflag1)
  •         u8 i;
  •         if(showflag1 == 1)
  •                         switch(i)
  •                                 case 0:        WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[min/10%10];break;
  •                                 case 1:        WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[min%10];break;
  •                                 case 2:        WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[sec/10%10];break;
  •                                 case 3:        WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[sec%10];break;
  •                                 delay(2000);
  •                         //關(guān)顯示
  •                         SMG_PORT = 0xff;
  •         else if(showflag1 == 0)
  •                         switch(i)
  •                                 case 0:        WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[hour/10%10];break;
  •                                 case 1:        WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[hour%10];break;
  •                                 case 2:        WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[min/10%10];break;
  •                                 case 3:        WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[min%10];break;
  •                         delay(2000);
  •                         //關(guān)顯示
  •                         SMG_PORT = 0xff;
  •         函數(shù)名字:USART_Init
  •         函數(shù)功能:串口初始化函數(shù),沒有開啟串口中斷
  • void USART_Init(void)
  •            T2MOD =0;     //自動(dòng)重載
  •     T2CON = 0x30;     //T2用做發(fā)送接收時(shí)鐘
  •     TH2 = 0xFF;      //9600波特率,11.0592Mhz晶振
  •     TL2 = 0xDC;
  •     RCAP2H = 0xFF;
  •     RCAP2L = 0xDC;
  •     SCON = 0x50;     //串口方式1,1個(gè)起始位,1個(gè)停止位,8位數(shù)據(jù),可變波特率
  •     PCON = 0X00;    //波特率不加倍
  •     TR2 = 1;          //啟動(dòng)T2
  • //    ES = 1;         //開串口中斷
  • //    EA = 1;
  •         函數(shù)名字:Send_Byte
  •         函數(shù)功能:發(fā)送字符函數(shù)
  • void Send_Byte(u8 da)
  •         //發(fā)送字符H
  •         SBUF = da;
  •         //等待發(fā)送完成
  •         while(TI != 1);
  •         //清空發(fā)送標(biāo)志位
  •         TI = 0;
  •         函數(shù)名字:Send_Str
  •         函數(shù)功能:發(fā)送封裝發(fā)送字符串函數(shù)符函數(shù)
  • void Send_Str(u8  *str)
  •         u8 i;
  •         for(i=0; str[ i]!='\0'; i++)
  •                 Send_Byte(str[ i]);
  • //按鍵函數(shù)
  • void key_san()
  •   if(KEY1==0)
  •                   Send_Str("        當(dāng)前運(yùn)行的功能為A\r\n");
  •                         delay(200);
  •                         if(KEY1==0)
  •                                 smg_display_date(smg_show_flag);
  •                         if(KEY2==0)
  •                         Send_Str("        當(dāng)前運(yùn)行的功能為B\r\n");
  •                                 delay(200);
  •                         if(KEY2==0)
  •                                 smg_display_time(smg_show_flag1);
  •                 if(KEY3==0)
  •                         Send_Str("        當(dāng)前運(yùn)行的功能為C\r\n");
  •                         delay(200);
  •                         if(KEY3==0)
  •                         sprintf(time_buf, "當(dāng)前時(shí)間為%d年%d月%d日%d時(shí)%d分%d秒\r\n",year,month,day,hour,min,sec);
  •                    Send_Str(time_buf);
  •         函數(shù)名字:timer0_irq
  •         函數(shù)功能:定時(shí)器0的中斷服務(wù)函數(shù)
  • void timer0_irq(void) interrupt 1
  •         static u8 i = 0;
  •         //循環(huán)給定時(shí)器0裝入初值
  •         //讓計(jì)數(shù)值自加
  •         i++;
  •         //40*50=2000ms,即2秒的延時(shí)
  •         if(i == 40)
  •                 //清空計(jì)數(shù)值,讓程序進(jìn)行下一次1秒的延時(shí)
  •                 i = 0;
  •                 //每2秒鐘切換數(shù)碼管顯示的內(nèi)容
  •                 smg_show_flag=~smg_show_flag;
  •                 smg_show_flag1=~smg_show_flag1;
  • //定時(shí)器1的中斷服務(wù)函數(shù)
  • void Timer0() interrupt 3
  •                         TH1=0Xd8;
  •                         TL1=0Xf0;
  •                         ssec++;
  •                         if(ssec>=100)
  •                         ssec=0;
  •                         sec++;
  •                         if(sec>=60)
  •                         sec=0;
  •                         min++;
  •                         if(min>=60)
  •                         min=0;
  •                         hour++;
  •                         if(hour>=24)
  •                         hour=0;
仿真原理圖
仿真原理圖
