查看: 1524|回復(fù): 0
基于MATLAB編寫的濾波器代碼實(shí)現(xiàn)
ID:1024008 發(fā)表于 2022-5-24 18:24 來自觸屏版 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
MATLAB仿真程序
窗函數(shù)設(shè)計(jì)法:
Fs=100;
t=(1:100)/Fs;
s1=sin(2*pi*t*5);
s2=sin(2*pi*t*15);
s3=sin(2*pi*t*30);
s=s1+s2+s3;
figure(1);
subplot(2,2,1);
plot(t,s)%畫出信號(hào)的時(shí)域波形
xlabel('Time(seconds)')
ylabel('Time waveform')
title('原始信號(hào)的時(shí)域波形')%程序功能:畫出信號(hào)的頻譜圖。
S=fft(s,512);%對(duì)s進(jìn)行快速傅立葉變換
w=(0:255)/256*(Fs/2);
subplot(2,2,2);
plot(w,abs(S(1:256)))%畫出信號(hào)的幅度圖
xlabel('Frequency(Hz)')
ylabel('幅度')
title('幅度譜')
axis([0 35 0 60]);
subplot(2,2,3);
plot(w,angle(S(1:256)))%畫出信號(hào)的相位圖
ylabel('相位')
title('相位譜')%程序功能:設(shè)計(jì)低通濾波器并畫出其頻譜圖:
%%%%%%%%%%%%%%低通
fb=10;
fc=13;%設(shè)置濾波器截止頻率
fs=100;
wb=2*pi*fb/fs;
ws=2*pi*fc/fs;
wc=0.5*(wb+ws);
tr_width=ws-wb;%過渡帶寬
%%%%%%%%%%%%%%高通
%fb=25;
%fc=22;%設(shè)置濾波器截止頻率
%fs=100;
%wb=2*pi*fb/fs;
%ws=2*pi*fc/fs;
%wc=0.5*(wb+ws);
%tr_width=wb-ws;%過渡帶寬
%%%%%%%%%%%%%%%%%%%帶通
%fc1=9;fb1=12;fb2=18;fc2=21;fs=100;
%wb1=2*pi*fb1/fs;ws1=2*pi*fc1/fs;wb2=2*pi*fb2/fs;
%ws2=2*pi*fc2/fs;wc1=0.5*(wb1+ws1);wc2=0.5*(wb2+ws2);
%tr_width=min((wb1-ws1),(ws2-wb2));
M=ceil(1.8*pi/tr_width);
n=[0:1:M-1];
hd=ideal_lp(wc,M);
%w_box=(boxcar(M))'
%w_box=(triang(M))'
%w_box=(hamming(M))'
w_box=(kaiser(M,2.5))'
h=hd.*w_box;
[H,w]=freqz(h,[1],1000,'whole');
H=(H(1:501))';
w=(w(1:501))';
mag=abs(H);
db=20*log10((mag+eps)/max(mag));
pha=angle(H);
grd=grpdelay(h,[1],w);
figure(2);
subplot(2,2,1);stem(n,hd);%理想脈沖響應(yīng)
xlabel('n');
ylabel('hd(n)');
title('Ideal Impulse Response');
subplot(2,2,2);stem(n,w_box);%矩形窗
xlabel('n');
ylabel('w(n)');
title('Kaiser Window');
subplot(2,2,3);stem(n,h);%實(shí)際脈沖響應(yīng)
xlabel('n');
ylabel('h(n)');
title('Actual Impulse Response');
subplot(2,2,4);plot(w*fs/(2*pi),db);%幅度響應(yīng)(dB)
axis([0 40-50 0]);
xlabel('Frequency(Hz)');
ylabel('Decibels');
title('Magnitude Response in dB');
sf=filter(h,[1],s);%sf為濾濾波后的信號(hào)
figure(3);
subplot(2,2,1);
plot(t,sf)%畫出濾波后信號(hào)的時(shí)域波形
axis([0 1-1 1]);
title('濾波后信號(hào)的時(shí)域波形')
SF=fft(sf,512);%對(duì)sf進(jìn)行快速傅里葉變換
subplot(2,2,2);
plot(w,abs(SF(1:256)))%畫出濾波后信號(hào)的幅度圖
ylabel('幅度譜')
title('濾波后信號(hào)的幅度譜');
subplot(2,2,3);
plot(w,angle(SF(1:256)))%畫出濾波后信號(hào)的相位圖
ylabel('相位譜')
title('濾波后信號(hào)的相位譜')%程序功能:對(duì)濾波前后信號(hào)進(jìn)行比較
subplot(2,2,4);
plot(w,abs([S(1:256)'SF(1:256)']))%將濾波前后信號(hào)的幅度譜畫在一起
ylabel('Mag.of Fourier transform')
legend({'before','after'})%對(duì)兩個(gè)曲線進(jìn)行區(qū)分命名
title('濾波前后信號(hào)對(duì)比')
頻率采樣設(shè)計(jì)法:
N=100;Fs=100; %數(shù)據(jù)總數(shù)和采樣頻率
fc1=12;
fc2=18;
n=[0:N-1];t=n/Fs;%時(shí)間序列
f1=5;f2=15;f3=30;
x=sin(2*pi*f1*t)+sin(2*pi*f2*t)+sin(2*pi*f3*t);%輸入信號(hào)
%設(shè)計(jì)25階的低通濾波器,歸一化截止頻率為fc*2/Fs
b=fir1(25,0.2);
y1=fftfilt(b,x,256);%對(duì)數(shù)據(jù)進(jìn)行濾波
n1=1:100;t1=t(n1);%選擇采樣點(diǎn)間隔
x1=x(n1);%與采樣點(diǎn)對(duì)應(yīng)的輸入信號(hào)
subplot(2,2,1);plot(t1,x1);%繪制輸入信號(hào)
title('輸入信號(hào)');
S=fft(x,512);% 對(duì)x進(jìn)行快速傅立葉變換
subplot(2,2,2);
plot(w,abs(S(1:256)))% 畫出信號(hào)的幅度圖
xlabel('Frequency (Hz)')
ylabel('幅度')
title('幅度譜')
n2=n1;t2=t(n2);%輸出信號(hào),扣除了相位延遲N/2
y2=y1(n2);
subplot(2,2,3);plot(t2,y2);%繪制輸出信號(hào)
title('輸出信號(hào)');
xlabel('時(shí)間/s')
SF=fft(y1,512);% 對(duì)sf進(jìn)行快速傅里葉變換
subplot(2,2,4);
plot(w,abs(SF(1:256)))% 畫出濾波后信號(hào)的幅度圖
ylabel('幅度譜')
figure(2);
[H,f]=freqz(b,1,512,Fs);
plot(f,20*log10(abs(H)));
DSP實(shí)現(xiàn)程序
FIR.c程序:
#include<math.h>
#define FIRNUMBER 25
#define PI 3.1415926
float InputWave();
float FIR();
FloatfHn[FIRNUMBER]={51455693,35039587,0,-43569197,-79886877,-91884544,-66619233,0,100778399,218060512,327780957,405671856,433829342,405671856,327780957,218060512,100778399,0,-66619233,-91884544,-79886877,-43569197,0,35039587,51455693};
float fXn[FIRNUMBER]={0.0};
float fInput,fOutput;
float fSignal1,fSignal2,fSignal3;
float fStepSignal1,fStepSignal2,fStepSignal3;
float f2PI;
int i;
float fIn[256],fOut[256];
int nIn,nOut;
main()
nIn=0;nOut=0;
f2PI=2*PI;
fSignal1=0.0;
fSignal2=0.0;
fStepSignal1=2*PI/20;
fStepSignal2=6*PI/20;
fStepSignal3=12*PI/20;
        fInput=InputWave();
        fIn[nIn]=fInput;
        nIn++;nIn%=256;
        fOutput=FIR();
        fOut[nOut]=-fOutput;
        nOut++;                                /*break point*/
        if(nOut>=256)
                nOut=0;
float InputWave()
        for(i=FIRNUMBER-1;i>0;i--)
                fXn[i]=fXn[i-1];
        fXn[0]=sin(fSignal1)+sin(fSignal2)+sin(fSignal3);
        fSignal1+=fStepSignal1;
        if(fSignal1>=f2PI)        fSignal1-=f2PI;
        fSignal2+=fStepSignal2;
        if(fSignal2>=f2PI)        fSignal2-=f2PI;
        fSignal3+=fStepSignal3;
        if(fSignal3>=f2PI)        fSignal3-=f2PI;
        return(fXn[0]);
float FIR()
        float fSum;
        fSum=0;
        for(i=0;i<FIRNUMBER;i++)
                fSum+=(fXn[i]*fHn[i]);
        return(fSum);
Test.cmd程序:
-heap 100
-stack 400
-sysstack 400
-l rts55x.lib
MEMORY
        PAGE 0:PROG(R):origin=0x80000,length=0x10000
        PAGE 0:BOOT(R):origin=0x3FF000,length=0xFC0
        PAGE 0:RESET(R):origin=0x3FFC0,length=0x2
        //PAGE 0:VECTORS(R):origin=0x3FFC2,length=0x3E
        PAGE 1:M0RAM(RW):origin=0x000000,length=0x400
        PAGE 1:M1RAM(RW):origin=0x000400,length=0x400
        PAGE 1:L0L1RAM(RW):origin=0x008000,length=0x2000
        PAGE 1:H0RAM(RW):origin=0x3F8000,length=0x2000
SECTIONS
        .reset:>RESET,PAGE=0
        .pinit:>PROG,PAGE=0
        .cinit:>PROG,PAGE=0
        .text:>PROG,PAGE=0
        .const:>L0L1RAM,PAGE=1
        .bass:>L0L1RAM,PAGE=1
