查看: 1714|回復(fù): 0
STC12C5A60S2單片機(jī)測(cè)量流量及溫度差的測(cè)量
ID:1024008 發(fā)表于 2022-5-24 18:44 來(lái)自觸屏版 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<STC12C5A60S2.h>
#include<stdio.h>
#include<intrins.h>
float wendu1, wendu2, wendu, reliang;
int jishu = 0;
void delayAD(unsigned int a) //延時(shí)約1ms
        unsigned int i;
        while (--a != 0)
                for (i = 600; i>0; i--);   //1T單片機(jī)i=600,若是12T單片機(jī)i=125
void AD_init()                        //AD初始化
        P1ASF = 0x18; //P1口全部作為模擬功能AD使用
        ADC_RES = 0;   //清零轉(zhuǎn)換結(jié)果寄存器高8位
        ADC_RESL = 0; //清零轉(zhuǎn)換結(jié)果寄存器低2位
        ADC_CONTR = 0x80;//開(kāi)啟電源
        delayAD(2);   //等待1ms,讓電源穩(wěn)定
unsigned int AD_get(unsigned char channel)
        ADC_CONTR = 0x88 | channel;    //開(kāi)啟AD轉(zhuǎn)換1000 1000 即POWER SPEED1 SPEED0 ADC_FLAG   ADC_START CHS2 CHS1 CHS0
        _nop_(); _nop_(); _nop_(); _nop_();//要經(jīng)過(guò)4個(gè)CPU時(shí)鐘的延時(shí),其值才能夠保證被設(shè)置進(jìn)ADC_CONTR 寄存器
        while (!(ADC_CONTR & 0x10));    //等待轉(zhuǎn)換完成
        ADC_CONTR &= 0xe7;      //關(guān)閉VF轉(zhuǎn)換,ADC_FLAG位由軟件清0
        return(ADC_RES * 4 + ADC_RESL);   //返回轉(zhuǎn)換完成的10位數(shù)據(jù)(16進(jìn)制)
float AD_work(unsigned char channel)
        float AD_val;     //定義處理后的數(shù)值VF_val為浮點(diǎn)數(shù)
        unsigned char i;
        for (i = 0; i<250; i++)
                VF_val += VF_get(channel); //轉(zhuǎn)換100次求平均值(提高精度)
        AD_val /= 250;
        AD_val = (AD_val * 5) / 1024; //AD的參考電壓是單片機(jī)上的5v,所以乘5即為實(shí)際電壓值
        return AD_val;
void int_0()                                                //中斷初始化
        IT0 = 1;                        //set INT0 int type (1:Falling 0:Low level)
        EX0 = 1;                        //enable INT0 interrupt
        EA = 1;                         //open global interrupt switch
void serial_init()                                        //串口初始化
        TMOD = 0x20;
        TH1 = 0xfd;
        TL1 = 0xfd; //設(shè)置9600波特率
        SCON = 0x50; //串口方式1,允許接收
        TR1 = 1;
void delay(unsigned int a) //延時(shí)約1ms
        unsigned int i;
        while (--a != 0)
        AD_init();
        int_0();
        serial_init();
        while (1)
                wendu1 = VF_work(1);
                wendu2 = VF_work(2);
                wendu = wendu1 - wendu2;
                reliang = jishu * wendu;
                TI = 1; //使用printf函數(shù)前須先將發(fā)送標(biāo)志位TI置1
                printf("當(dāng)前熱量為 %f\n",reliang);
                TI = 0;
                delay(1000); //延時(shí)約1s
void exint0() interrupt 0           //下降沿出發(fā)的外部中斷0
        jishu++;
