查看: 1917|回復(fù): 0
單片機的串口通信上位機代碼
ID:1031401 發(fā)表于 2022-5-31 23:03 | 顯示全部樓層 |閱讀模式
就想蹭黑幣
import serial
from serial.tools import list_ports
import tkinter as tk
from tkinter import ttk
from tkinter.messagebox import *
class MySerial:
    def __init__(self):
        self.ser = serial.Serial()
    # 顯示連接的端口
    # 建立連接
    def connect(self, port, baudrate, bytesize, stopbits, parity, timeout):
        # 如果之前打開的串口沒有關(guān)閉,這里自動關(guān)閉
        if self.ser.is_open:
            self.ser.close()
        self.ser = serial.Serial(port=port, baudrate=baudrate,bytesize=bytesize, stopbits=stopbits, parity=parity, timeout=timeout)
        print("連接成功")
    # 發(fā)送數(shù)據(jù)
    def send(self, data):
        self.ser.write(data.encode())
    # 接受數(shù)據(jù)
    def rcve(self):
        pass
    def close(self):
        self.ser.close()
class Interface:
    def __init__(self):
        self.my_serial = MySerial()
        self.window =tk.Tk()
        self.window.title("LED上位機")
        self.window.geometry("400x300")
        self.port_name_var = tk.Variable()
        self.baudrate_var = tk.Variable()
        self.button_connect_var = tk.Variable()
        self.button_connect_var.set("打開串口")
        self.serial_status = "OFF"
        self.combobox_port = ttk.Combobox(self.window, textvariable=self.port_name_var)
        self.combobox_baudrate = ttk.Combobox(self.window, textvariable=self.baudrate_var)
        self.button_connect = tk.Button(self.window, textvariable=self.button_connect_var, command=self.open_close_serial)
        self.button_led1 = tk.Button(self.window, text="LED1", command=lambda: self.command(str(chr(0x01))))
        self.button_led2 = tk.Button(self.window, text="LED2", command=lambda: self.command(str(chr(0x02))))
        self.button_led3 = tk.Button(self.window, text="LED3", command=lambda: self.command(str(chr(0x03))))
        self.button_led4 = tk.Button(self.window, text="LED4", command=lambda: self.command(str(chr(0x04))))
        self.button_led5 = tk.Button(self.window, text="LED5", command=lambda: self.command(str(chr(0x05))))
        self.button_led6 = tk.Button(self.window, text="LED6", command=lambda: self.command(str(chr(0x06))))
        self.button_led7 = tk.Button(self.window, text="LED7", command=lambda: self.command(str(chr(0x07))))
        self.button_led8 = tk.Button(self.window, text="LED8", command=lambda: self.command(str(chr(0x08))))
        self.combobox_port.place(relx=1/9, rely=1/8, relwidth=2/9, relheight=1/10)
        self.combobox_baudrate.place(relx=6/9, rely=1/8, relwidth=2/9, relheight=1/10)
        self.button_connect.place(relx=3/9, rely=5/16, relwidth=3/9, relheight=1/8)
        self.button_led1.place(relx=1 / 9, rely=2 / 4, relwidth=1 / 9, relheight=1 / 8)
        self.button_led2.place(relx=3 / 9, rely=2 / 4, relwidth=1 / 9, relheight=1 / 8)
        self.button_led3.place(relx=5 / 9, rely=2 / 4, relwidth=1 / 9, relheight=1 / 8)
        self.button_led4.place(relx=7 / 9, rely=2 / 4, relwidth=1 / 9, relheight=1 / 8)
        self.button_led5.place(relx=1 / 9, rely=3 / 4, relwidth=1 / 9, relheight=1 / 8)
        self.button_led6.place(relx=3 / 9, rely=3 / 4, relwidth=1 / 9, relheight=1 / 8)
        self.button_led7.place(relx=5 / 9, rely=3 / 4, relwidth=1 / 9, relheight=1 / 8)
        self.button_led8.place(relx=7 / 9, rely=3 / 4, relwidth=1 / 9, relheight=1 / 8)
    # 顯示串口列表
    def show_list(self):
        # 顯示串口列表
        self.combobox_port['values'] = [file:///C:\Users\21039\AppData\Roaming\Tencent\QQ\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngx.name for x in list(list_ports.comports())]
        # 顯示波特率列表
        self.combobox_baudrate['values'] = [600, 1200, 1800, 2400, 4800, 9600, 19200, 38400, 57600, 115200]
    def open_close_serial(self):
        var = self.button_connect_var.get()
        if var == "打開串口":
            port = self.combobox_port.get()
            baudrate = self.baudrate_var.get()
            print(port)
            if port == "":
                return
            try:
                self.my_serial.connect(port=port, baudrate=baudrate, bytesize=8, stopbits=1, parity="N", timeout=1)
                self.button_connect_var.set("關(guān)閉串口")
                self.combobox_baudrate.configure(state="disable")
                self.combobox_port.configure(state="disable")
            except:
                showerror("串口錯誤", "該串口被占用或不存在!")
        else:
            self.my_serial.close()
            self.combobox_baudrate.configure(state="enable")
            self.combobox_port.configure(state="enable")
    def command(self, data):
        self.my_serial.send(data=data)
    def run(self):
        self.show_list()
