查看: 2791|回復: 0
51單片機數(shù)碼管顯示計數(shù)器程序
ID:1031277 發(fā)表于 2022-6-1 15:06 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define dula P0                //段選
#define wela P2                //位選
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x76,0x38};        //共陰極
void Timer0Init();        //定時器初始化
void display(uint first,uint second,uint third,uint forth);        //顯示函數(shù)
void delay_ms(unsigned int timer);        //延時函數(shù) ms
unsigned int count =0;        //計數(shù)值
void main()        //主函數(shù)
                display(count/1000,(count%1000)/100,(count%100)/10,count%10);        //顯示函數(shù)
*函數(shù):數(shù)碼管顯示函數(shù)
*參數(shù):das
*返回:無
void display(uint first,uint second,uint third,uint forth)        //顯示
        wela = 0xfe;
        dula = table[first];        //顯示第一個
        delay_ms(5);
        dula = 0x00;        //一定要加,否則不穩(wěn)定
        wela = 0xfd;
        dula = table[second];        //顯示第二個
        delay_ms(5);
        wela = 0xfb;
        dula = table[third];        //顯示第三個
        delay_ms(5);
        wela = 0xf7;
        dula = table[forth];        //顯示第四個
        delay_ms(5);
*函數(shù):延時_ms函數(shù)
*參數(shù):timer
*返回:無
void delay_ms(uint timer)
        uint i,j;
        for(i=0;i<timer;i++)
                for(j=0;j<110;j++);
*函數(shù)名:Timer0Init
*函數(shù)功能:定時器0初始化
*輸        入:無
*輸        出:無
void Timer0Init()
        TMOD|=0x01;        //選擇為定時器0模式,工作方式1,僅用TR0打開啟動
        TH0=0XFC;        //給定時器賦初值,定時1ms
        TL0=0X18;
        ET0=1;        //打開定時器0中斷允許
        EA=1;        //打開總中斷
        TR0=1;        //打開定時器
*函數(shù)名:void time0() interrupt 1
*函數(shù)功能:定時器0中斷函數(shù)
*輸        入:無
*輸        出:無
        static unsigned int i=0;
        TL0=0X18;
        i++;
        if(i==1000)        //1s
                i=0;
                if(count<9999)        //小于9999
                        count++;        //加一
                        count=0;        //清零
參與人數(shù) 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎勵!
