查看: 3260|回復(fù): 1
C語(yǔ)言PID控溫講解及源碼
ID:1037617 發(fā)表于 2022-6-30 08:41 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
參考資料:http://www.torrancerestoration.com/bbs/dpj-181096-1.html
功能:用軟件模擬PID控制溫度
模型一:夏天要求室內(nèi)的溫度為23攝氏度左右,假定房間受室外高溫影響,1分鐘上升0.1攝氏度(上限為室外溫度37攝氏度)。
        釋放一包制冷劑可降低5攝氏度,一包制熱劑,可上升五度,溫度變化由傳感器采集,但是我用軟件模擬溫度變化,
        假設(shè)一切處于理想狀態(tài)。
#include "SoftSimulation_PID_Header.h"
int main()
    init_PID();
    time_t timep;
    struct tm *tp;
    while (1)
        if (pid.ActualTemperature < outdoorTemperature)
            // 獲取時(shí)間
            time(&timep);
            tp = gmtime(&timep);
            AcquireTemperature(tp->tm_hour,tp->tm_min,tp->tm_sec);
        PID_controlTemperature();
        /* 當(dāng)溫度處于人體舒適的溫度時(shí),則不用制冷或加熱 */
        while (fabs(pid.SetTemperature - pid.ActualTemperature) < ComfortTemperature)
            // 獲取時(shí)間
            time(&timep);
            // 獲取計(jì)算機(jī)時(shí)間,10秒鐘打印一次
            printf("%d/%d/%d %d/%d/%d\n",1900+tp->tm_year,(1+tp->tm_mon),tp->tm_mday,tp->tm_hour + 8, tp->tm_min,tp->tm_sec);
            printf("Display:設(shè)定溫度為:%.2f\t室內(nèi)溫度為:%f\t\n\n", pid.SetTemperature, pid.ActualTemperature);
            // 獲取實(shí)時(shí)溫度
            AcquireTemperature(tp->tm_hour, tp->tm_min, tp->tm_sec);
            Sleep(500);
/* Acquire indoor Temperature */
void AcquireTemperature(int hour,int minute,int second)
    static int lastTime[3] = { 0 };
    static float Minute = 0;
    if (!lastTimeFlag )
        lastTime[0] = hour;
        lastTime[1] = minute;
        lastTime[2] = second;
        lastTimeFlag = 1;
        if (pid.ActualTemperature <= outdoorTemperature)
            Minute = (hour - lastTime[0]) * 60 + (minute - lastTime[1]) + float(second - lastTime[2]) / 60.0;
            pid.ActualTemperature = pid.ActualTemperature + Minute * IncrementTemperature;
            lastTime[0] = hour;
            //printf("Test:設(shè)定溫度為:%.2f\t室內(nèi)溫度為:%f\t\n\n", pid.SetTemperature, pid.ActualTemperature);
            // 溫度升高過(guò)快,只記錄時(shí)間,程序會(huì)在PID_controlTemperature函數(shù)中處理
            lastTime[0] = hour;
/* release the refrigeration */
void Refrigeration()
    pid.ActualTemperature = pid.ActualTemperature - 5;
/* release the heating */
void Heating()
    pid.ActualTemperature = pid.ActualTemperature + 5;
/* the PID arithmetic control the temperature of indoor */
void PID_controlTemperature()
    if (pid.SetTemperature >= pid.ActualTemperature + TemperatureErr)
        // 室內(nèi)溫度偏低,調(diào)用制熱模塊
        Heating();
    // 室內(nèi)溫度處于23度左右,使用PID精調(diào)
    else if (fabs(pid.SetTemperature - pid.ActualTemperature) < TemperatureErr)
        IncrementPID_realize();    // 增量式PID控制
        //PositionPID_realize();    // 位置式PID控制,兩者只要一個(gè)就可以了,之所以都貼出來(lái),為了試試兩種方式有什么不同
    else if (pid.SetTemperature + TemperatureErr <= pid.ActualTemperature)
        // 室內(nèi)溫度偏高,調(diào)用制冷模塊
        Refrigeration();
        printf("區(qū)間考慮不周全\n");
/* initialize PID */
void init_PID()
    pid.Kp = 0.2;
    pid.Ki = 0.015;
    pid.Kd = 0.2;
    pid.SetTemperature = 23.0;
    pid.ActualTemperature = outdoorTemperature;
    lastTimeFlag = 0;
    pid.ErrVal[0] = 0;
    pid.ErrVal[1] = 0;
    pid.ErrVal[2] = 0;
    pid.Integral = 0;
    printf("accomplish initialize PID \n");
功能:使用增量式PID調(diào)節(jié)
公式:U(k)+Kp*[E(k)-E(k-1)]+Ki*E(k)+Kd*[E(k)-2E(k-1)+E(k-2)]
備注:網(wǎng)上的公式Kp乘以的東西有兩種,第一種是Kp*[E(k)-E(k-1)],第二種是Kp*([E(k)-E(k-1)]+Ki*E(k)+Kd*[E(k)-2E(k-1)+E(k-2)])
      這兩種我都測(cè)試過(guò),都能實(shí)現(xiàn)功能,前者更快一些,后者慢,但是我個(gè)人喜歡第二種
void IncrementPID_realize()
    pid.ErrVal[0] = pid.SetTemperature - pid.ActualTemperature;            // 計(jì)算設(shè)定值與實(shí)際值直接的誤差
    float Temp0 = pid.Kp * (pid.ErrVal[0] - pid.ErrVal[1]);
    //float Temp0 = (pid.ErrVal[0] - pid.ErrVal[1]);
    float Temp1 = pid.Ki * pid.ErrVal[0];
    float Temp2 = pid.Kd * (pid.ErrVal[0] - 2 * pid.ErrVal[1] + pid.ErrVal[2]);
    float Increment = Temp0 + Temp1 + Temp2;                            // 通過(guò)公式計(jì)算增量
    // float Increment = pid.Kp * (Temp0 + Temp1 + Temp2);                // 通過(guò)公式計(jì)算增量
    pid.ActualTemperature += Increment;                                    // 計(jì)算實(shí)際溫度
    pid.ErrVal[1] = pid.ErrVal[0];
    pid.ErrVal[2] = pid.ErrVal[1];
    //printf("Realize:設(shè)定溫度為:%.2f\t室內(nèi)溫度為:%.2f\t\n\n", pid.SetTemperature, pid.ActualTemperature);
功能:使用位置式PID調(diào)節(jié)
公式:Kp*(E(k)+Ki*∑E(j)+Kd*[E(k)-E(k-1)])
備注:參考增量式的備注
void PositionPID_realize()
    pid.Integral += pid.ErrVal[0];
    pid.ActualTemperature = pid.Kp * pid.ErrVal[0] + pid.Ki * pid.Integral + pid.Kd * (pid.ErrVal[0] - pid.ErrVal[1]);
</textarea>
頭文件如下:
#include <stdio.h>
#include<stdlib.h>
#include<math.h>
#include<time.h>
#include<windows.h>
typedef struct PID_Value
    float ErrVal[3];            // 三次誤差值
    float Kp;                    // 比例系數(shù)
    float Ki;                    // integral 系數(shù)
    float Kd;                    // derivative 系數(shù)
    float Integral;                // 積分
    float SetTemperature;
    float ActualTemperature;
}PID_ValueStr,*PID_ValueT;
PID_Value pid;
#define        outdoorTemperature        36.2
#define        TemperatureErr            3
#define        ComfortTemperature        0.5
#define        IncrementTemperature    1            // 每分鐘房間上升的溫度
int lastTimeFlag = 0;
void AcquireTemperature(int hour, int minute, int second);
void PID_controlTemperature();
void Refrigeration();
void init_PID();
void IncrementPID_realize();
void PositionPID_realize();
收藏收藏6 分享淘帖 頂 踩
ID:93341 發(fā)表于 2022-9-28 22:17 | 只看該作者
還有呢,能補(bǔ)全嗎。
