#include <reg52.h>
#include <intrins.h>
#define delayNOP() {_nop_();_nop_();_nop_();_nop_();}
sbit DQ = P3^3;
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
uchar code Temp_Disp_Title[]={"Current Temp : "};
uchar Current_Temp_Display_Buffer[]={" TEMP: "};
uchar code Temperature_Char[8] =
0x0c,0x12,0x12,0x0c,0x00,0x00,0x00,0x00
uchar code df_Table[]=
0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9
uint CurrentT = 0;
uchar Temp_Value[]={0x00,0x00};
uchar Display_Digit[]={0,0,0,0};
bit DS18B20_IS_OK = 1;
void DelayXus(uint x)
uchar i;
while(x--)
for(i=0;i<200;i++);
bit LCD_Busy_Check()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN=0;
return result;
void Write_LCD_Command(uchar cmd)
while(LCD_Busy_Check());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void Write_LCD_Data(uchar dat)
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void LCD_Initialise()
Write_LCD_Command(0x01);
DelayXus(5);
Write_LCD_Command(0x38);
DelayXus(5);
Write_LCD_Command(0x0c);
DelayXus(5);
Write_LCD_Command(0x06);
DelayXus(5);
void Set_LCD_POS(uchar pos)
Write_LCD_Command(pos|0x80);
void Delay(uint x)
while(--x);
uchar Init_DS18B20()
uchar status;
DQ = 0;
Delay(90);
DQ = 1;
Delay(8);
status = DQ;
while(DQ==0);
return status;
uchar ReadOneByte()
uchar i,dat=0;
for(i=0;i<8;i++)
DQ = 0;
dat >>= 1;
DQ = 1;
_nop_(); _nop_();
if(DQ) dat |= 0X80;
Delay(5);
while(DQ==0);
return dat;
void WriteOneByte(uchar dat)
uchar i;
for(i=0;i<8;i++)
DQ = 0;
_nop_();
DQ = dat& 0x01;
Delay(5);
DQ = 1;
dat >>= 1;
void Read_Temperature()
if(Init_DS18B20()==1)
DS18B20_IS_OK=0;
WriteOneByte(0xcc);
WriteOneByte(0x44);
Init_DS18B20();
WriteOneByte(0xcc);
WriteOneByte(0xbe);
Temp_Value[0] = ReadOneByte();
Temp_Value[1] = ReadOneByte();
DS18B20_IS_OK=1;
void Display_Temperature()
uchar i;
uchar t = 150, ng = 0;
if((Temp_Value[1]&0xf8)==0xf8)
Temp_Value[1] = ~Temp_Value[1];
Temp_Value[0] = ~Temp_Value[0]+1;
if(Temp_Value[0]==0x00)
Temp_Value[1]++;
ng = 1;
Display_Digit[0] = df_Table[Temp_Value[0]&0x0f];
CurrentT = ((Temp_Value[0]&0xf0)>>4) | ((Temp_Value[1]&0x07)<<4);
Display_Digit[3] = CurrentT/100;
Display_Digit[2] = CurrentT%100/10;
Display_Digit[1] = CurrentT%10;
Current_Temp_Display_Buffer[11] = Display_Digit[0] + '0';
Current_Temp_Display_Buffer[10] = '.';
Current_Temp_Display_Buffer[9] = Display_Digit[1] + '0';
Current_Temp_Display_Buffer[8] = Display_Digit[2] + '0';
Current_Temp_Display_Buffer[7] = Display_Digit[3] + '0';
if(Display_Digit[3] == 0)
Current_Temp_Display_Buffer[7] = ' ';
if(Display_Digit[2] == 0&&Display_Digit[3]==0)
Current_Temp_Display_Buffer[8] = ' ';
if(ng)
if(Current_Temp_Display_Buffer[8] == ' ')
Current_Temp_Display_Buffer[8] = '-';
else if(Current_Temp_Display_Buffer[7] == ' ')
Current_Temp_Display_Buffer[7] = '-';
Current_Temp_Display_Buffer[6] = '-';
Set_LCD_POS(0x00);
for(i=0;i<16;i++)
Write_LCD_Data(Temp_Disp_Title[ i]);
Set_LCD_POS(0x40);
for(i=0;i<16;i++)
Write_LCD_Data(Current_Temp_Display_Buffer[ i]);
Set_LCD_POS(0x4d);
Write_LCD_Data(0x00);
Set_LCD_POS(0x4e);
Write_LCD_Data('C');
LCD_Initialise();
Read_Temperature();
Delay(50000);
Delay(50000);
Read_Temperature();
if(DS18B20_IS_OK)
Display_Temperature();
DelayXus(100);
