OLED為0.96寸四針腳的IIC接口方式
適用于STM32F103ZET6
接線說明:
VCC —— 3.3V
GND —— GND
SCL —— PB6
SDA —— PB7
注意VCC不要接到5V上,容易燒壞屏幕。
單片機源程序如下:
- #include "oled.h"
- #include "myiic.h"
- #include "delay.h"
- #include "oledfont.h"
- //OLED初始化
- void OLED_Init(void)
- IIC_Init();
- delay_ms(200);
- OLED_WR_Byte(0xAE,OLED_CMD);//--display off
- OLED_WR_Byte(0x00,OLED_CMD);//---set low column address0
- OLED_WR_Byte(0x10,OLED_CMD);//---set high column address16
- OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
- OLED_WR_Byte(0xB0,OLED_CMD);//--set page address176
- OLED_WR_Byte(0x81,OLED_CMD); // contract control
- OLED_WR_Byte(0x08,OLED_CMD);//--128
- OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
- OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
- OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
- OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
- OLED_WR_Byte(0x80,OLED_CMD);//
- OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
- OLED_WR_Byte(0x05,OLED_CMD);//
- OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
- OLED_WR_Byte(0xF1,OLED_CMD);//
- OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
- OLED_WR_Byte(0x12,OLED_CMD);//
- OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
- OLED_WR_Byte(0x30,OLED_CMD);//
- OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
- OLED_WR_Byte(0x14,OLED_CMD);//
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
- //OLED寫命令
- void Write_OLED_Command(unsigned char OLED_Command)
- IIC_Start();
- IIC_Send_Byte(0x78); //Slave address,SA0=0
- IIC_Wait_Ack();
- IIC_Send_Byte(0x00); //write command
- IIC_Wait_Ack();
- IIC_Send_Byte(OLED_Command);
- IIC_Wait_Ack();
- IIC_Stop();
- //OLED寫數(shù)據(jù),這個寫數(shù)據(jù)是指要傳輸數(shù)據(jù)
- void Write_OLED_Data(unsigned char OLED_Data)
- IIC_Start();
- IIC_Send_Byte(0x78); //D/C#=0; R/W#=0
- IIC_Wait_Ack();
- IIC_Send_Byte(0x40); //write data
- IIC_Wait_Ack();
- IIC_Send_Byte(OLED_Data);
- IIC_Wait_Ack();
- IIC_Stop();
- //OLED寫函數(shù),在總線上往OLED寫數(shù)據(jù)
- void OLED_WR_Byte(unsigned dat,unsigned cmd)
- if(cmd)
- Write_OLED_Data(dat);
- else
- Write_OLED_Command(dat);
- //fill_picture
- void fill_picture(unsigned char fill_Data)
- unsigned char m,n;
- for(m=0;m<8;m++)
- OLED_WR_Byte(0xb0+m,0); //page0-page1
- OLED_WR_Byte(0x00,0); //low column start address
- OLED_WR_Byte(0x10,0); //high column start address
- for(n=0;n<128;n++)
- OLED_WR_Byte(fill_Data,1);
- //坐標(biāo)設(shè)置
- void OLED_Set_Pos(unsigned char x, unsigned char y)
- OLED_WR_Byte(0xb0+y,OLED_CMD);
- OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
- OLED_WR_Byte((x&0x0f),OLED_CMD);
- //開啟OLED顯示
- void OLED_Display_On(void)
- OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
- OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
- OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
- //關(guān)閉OLED顯示
- void OLED_Display_Off(void)
- OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
- OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
- //清屏函數(shù),清完屏,整個屏幕是黑色的!和沒點亮一樣!!!
- void OLED_Clear(void)
- u8 i,n;
- for(i=0;i<8;i++)
- OLED_WR_Byte (0xb0+i,OLED_CMD); //設(shè)置頁地址(0~7)
- OLED_WR_Byte (0x00,OLED_CMD); //設(shè)置顯示位置—列低地址
- OLED_WR_Byte (0x10,OLED_CMD); //設(shè)置顯示位置—列高地址
- for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
- } //更新顯示
- void OLED_On(void)
- u8 i,n;
- for(i=0;i<8;i++)
- for(n=0;n<128;n++)OLED_WR_Byte(1,OLED_DATA);
- } //更新顯示
- //在指定位置顯示一個字符,包括部分字符
- //x:0~127
- //y:0~63
- //mode:0,反白顯示;1,正常顯示
- //size:選擇字體 16/12
- void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size)
- unsigned char c=0,i=0;
- c=chr-' ';//c就是庫里的偏移值,看F8X16的取模庫,輸入chr是個字符的ascii碼,減去空格32,得到庫里的的所要顯示數(shù)字的位置
- if(x>Max_Column-1){x=0;y=y+2;}//如果超出了128列就從0列開始并換到下面數(shù)第二頁,中間空了一頁
- if(Char_Size ==16) //char_size是描述行的,size=16,說明寫了2頁,8列,標(biāo)準(zhǔn)的英文格式
- OLED_Set_Pos(x,y); //設(shè)置從x列,y頁開始寫,是從上往下寫的,并且是低位在前
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA); //這是寫所選擇的第一頁
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else
- OLED_Set_Pos(x,y); //重新設(shè)置頁,開始寫的列不變
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA); //寫一個
- //m^n函數(shù) 這是拆分?jǐn)?shù)字中的每一位使用的,就是找數(shù)字中的每一位
- u32 oled_pow(u8 m,u8 n)
- u32 result=1;
- while(n--)result*=m;
- return result;
- //x,y :起點坐標(biāo)
- //len :數(shù)字的位數(shù)
- //size:字體大小,大小指的其實是字體高度
- //num:數(shù)值(0~4294967295);
- void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2)
- u8 t,temp;
- u8 enshow=0;
- for(t=0;t<len;t++)
- temp=(num/oled_pow(10,len-t-1))%10;//算出顯示數(shù)字的高位
- if(enshow==0&&t<(len-1))
- if(temp==0)
- OLED_ShowChar(x+(size2/2)*t,y,' ',size2); //如果說數(shù)字高位是0的話,顯示空格,知道碰見數(shù)字為止
- continue;
- else enshow=1;
- OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2); //顯示數(shù)字
- //顯示一個字符號串
- void OLED_ShowString(u8 x,u8 y,u8 chr[],u8 Char_Size)
- unsigned char j=0;
- while (chr[j]!='\0')
- OLED_ShowChar(x,y,chr[j],Char_Size); //顯示字符串,拆分成一個一個的字符
- x+=8;
- if(x>120){x=0;y+=2;}
- j++;
- //顯示漢字 要取模,取模軟件及其操作在文件夾中,一般漢字顯示區(qū)域是16*16
- void OLED_ShowCHinese(u8 x,u8 y,u8 no)
- u8 t,adder=0;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
- adder+=1;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
- adder+=1;
- /***********功能描述:顯示顯示BMP圖片128×64起始點坐標(biāo)(x,y),x的范圍0~127,y為頁的范圍0~7*****************/
- void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[])
- unsigned int j=0;
- unsigned char x,y;
- if(y1%8==0) y=y1/8;
- else y=y1/8+1;
- for(y=y0;y<y1;y++)
- OLED_Set_Pos(x0,y);
- for(x=x0;x<x1;x++)
- OLED_WR_Byte(BMP[j++],OLED_DATA); //先把y頁寫滿,然后頁數(shù)加一,繼續(xù)寫該頁
Keil代碼下載:
程序.7z
(187.82 KB, 下載次數(shù): 52)
2022-8-4 16:45 上傳
點擊文件名下載附件
參考程序
