查看: 827|回復(fù): 1
STM32 PWM無(wú)輸出
ID:31164 發(fā)表于 2022-8-25 07:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "pbdata.h"
u16 fre;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void TIM8_Configuration();
void  Delay (uint32_t nCount)
  for(; nCount != 0; nCount--);
int main(void)
     u16 arr=42000;
     u16 led_dt = arr/2;
                 RCC_Configuration();        //系統(tǒng)時(shí)鐘初始化
                 GPIO_Configuration();//端口初始化
                 TIM8_Configuration(arr);//定時(shí)器和pwm配置
                                TIM_SetCompare3(TIM8,led_dt); //用的是TIM3的通道2,輸出PWM         送到相應(yīng)的寄存器中   //滿占空比為900
                          TIM_SetCompare3(TIM8, 20);
                                                GPIO_SetBits(GPIOB,GPIO_Pin_5);        //LED 發(fā)光
                                                        Delay(0x2ffff);
                                                GPIO_ResetBits(GPIOB,GPIO_Pin_5);//LED 熄滅
                                                        Delay(0x2ffff);
  SystemInit();
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8,ENABLE);//這個(gè)是必須的,仿真軟件必須的
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//端口復(fù)用,一定在APB2的時(shí)鐘線
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
void TIM8_Configuration(arr)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
        TIM_OCInitTypeDef TIM_OCInitStructure;             //PWM的結(jié)構(gòu)體
//PWM
        GPIO_InitStructure.GPIO_Pin= GPIO_Pin_8;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;      //通過PWM控制,端口為復(fù)用方式輸出
        GPIO_Init(GPIOC,&GPIO_InitStructure);
        //GPIO_PinRemapConfig(GPIO_PartialRemap_TIM1,ENABLE);//TIM3 復(fù)用功能部分映射,可以此找到對(duì)應(yīng)的管腳
        //關(guān)于部分映射可以參考“STM32參考手冊(cè)”119面
        //定時(shí)器初始化
        TIM_TimeBaseStruct.TIM_Period=arr;//初值
        TIM_TimeBaseStruct.TIM_Prescaler=2;//預(yù)分頻
        //不分頻,在晶振為72MHz的情況下,定時(shí)器執(zhí)行到899后即會(huì)溢出,表示計(jì)數(shù)滿
        TIM_TimeBaseStruct.TIM_ClockDivision=0;
        TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;//向上
        TIM_TimeBaseInit(TIM8,&TIM_TimeBaseStruct);
        //TIM_TimeBaseStruct.TIM_ClockDivision = TIM_CKD_DIV1;
        //pwm初始化
        //TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;             //使用模式1
        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable; //使能位
        TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
//設(shè)置輸出極性,一定注意
        //TIM_OCInitStructure.TIM_Pulse = 20;
        TIM_OC2Init(TIM8,&TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM8,TIM_OCPreload_Enable);            //與裝載使能,不會(huì)說執(zhí)行一次后就不執(zhí)行了
        TIM_CtrlPWMOutputs(TIM8,ENABLE);        //MOE 主輸出使能
        TIM_ARRPreloadConfig(TIM8, ENABLE);
        TIM_Cmd(TIM8,ENABLE);
/*PWM不是中斷,所以不需要設(shè)置中斷優(yōu)先級(jí) */
stm32f103無(wú)輸出PWM.rar
1.27 MB, 下載次數(shù): 4
PROTUES
ID:935919 發(fā)表于 2022-8-25 16:09 | 只看該作者
沒有細(xì)看, 不過似乎沒有指定 PC8和TIM3的那個(gè)通道對(duì)應(yīng)上, 就是TIM3設(shè)定的PWM用在哪個(gè)引腳上面. 試試看 在GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;  后面加一條 GPIO_InitStruct.Alternate = GPIO_xxx_TIM3; 嘻嘻嘻\
