查看: 2203|回復(fù): 6
大佬幫幫忙,51單片機(jī)驅(qū)動(dòng)OLED,燒錄例程,但沒有反應(yīng),一直黑屏
ID:963938 發(fā)表于 2022-9-17 15:43 | 顯示全部樓層 |閱讀模式
例程只改了SCL、SDA的通道;但OLED沒有反應(yīng)
#include "REG51.h"
#ifndef __OLED_H
#define __OLED_H
//#include "sys.h"
//#include "stdlib.h"
#define  u8 unsigned char
#define  u32 unsigned int
#define OLED_CMD  0        //寫命令
#define OLED_DATA 1        //寫數(shù)據(jù)
#define OLED_MODE 0
sbit OLED_SCL=P3^2;//時(shí)鐘 D0(SCLK?
sbit OLED_SDIN=P3^3;//D1(MOSI) 數(shù)據(jù)
#define OLED_CS_Clr()  OLED_CS=0
#define OLED_CS_Set()  OLED_CS=1
#define OLED_RST_Clr() OLED_RST=0
#define OLED_RST_Set() OLED_RST=1
#define OLED_DC_Clr() OLED_DC=0
#define OLED_DC_Set() OLED_DC=1
#define OLED_SCLK_Clr() OLED_SCL=0
#define OLED_SCLK_Set() OLED_SCL=1
#define OLED_SDIN_Clr() OLED_SDIN=0
#define OLED_SDIN_Set() OLED_SDIN=1
//OLED模式設(shè)置
//0:4線串行模式
//1:并行8080模式
#define SIZE 16
#define XLevelL                0x02
#define XLevelH                0x10
#define Max_Column        128
#define Max_Row                64
#define        Brightness        0xFF
#define X_WIDTH         128
#define Y_WIDTH         64
//-----------------OLED端口定義----------------
void delay_ms(unsigned int ms);
//OLED控制用函數(shù)
void OLED_WR_Byte(unsigned dat,unsigned cmd);
void OLED_Display_On(void);
void OLED_Display_Off(void);
void OLED_Init(void);
void OLED_Clear(void);
void OLED_DrawPoint(u8 x,u8 y,u8 t);
void OLED_Fill(u8 x1,u8 y1,u8 x2,u8 y2,u8 dot);
void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size);
void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size);
void OLED_ShowString(u8 x,u8 y, u8 *p,u8 Char_Size);
void OLED_Set_Pos(unsigned char x, unsigned char y);
void OLED_ShowCHinese(u8 x,u8 y,u8 no);
void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[]);
void Delay_50ms(unsigned int Del_50ms);
void Delay_1ms(unsigned int Del_1ms);
void fill_picture(unsigned char fill_Data);
void Picture();
void IIC_Start();
void IIC_Stop();
void Write_IIC_Command(unsigned char IIC_Command);
void Write_IIC_Data(unsigned char IIC_Data);
void Write_IIC_Byte(unsigned char IIC_Byte);
void IIC_Wait_Ack();
#endif
#include "oled.h"
#include "oledfont.h"
//#include "delay.h"
//OLED的顯存
//存放格式如下.
//[0]0 1 2 3 ... 127
//[1]0 1 2 3 ... 127
//[2]0 1 2 3 ... 127
//[3]0 1 2 3 ... 127
//[4]0 1 2 3 ... 127
//[5]0 1 2 3 ... 127
//[6]0 1 2 3 ... 127
//[7]0 1 2 3 ... 127
        unsigned int a;
        while(ms)
                a=1800;
                while(a--);
                ms--;
        return;
//IIC Start
void IIC_Start()
        OLED_SCLK_Set() ;
        OLED_SDIN_Set();
        OLED_SDIN_Clr();
        OLED_SCLK_Clr();
//IIC Stop
void IIC_Stop()
OLED_SCLK_Set() ;
//        OLED_SCLK_Clr();
        OLED_SDIN_Clr();
        OLED_SDIN_Set();
void IIC_Wait_Ack()
        //GPIOB->CRH &= 0XFFF0FFFF;        //設(shè)置PB12為上拉輸入模式
        //GPIOB->CRH |= 0x00080000;
//        OLED_SDA = 1;
//        delay_us(1);
        //OLED_SCL = 1;
        //delay_us(50000);
/*        while(1)
                if(!OLED_SDA)                                //判斷是否接收到OLED 應(yīng)答信號(hào)
                        //GPIOB->CRH &= 0XFFF0FFFF;        //設(shè)置PB12為通用推免輸出模式
                        //GPIOB->CRH |= 0x00030000;
                        return;
        OLED_SCLK_Set() ;
        OLED_SCLK_Clr();
// IIC Write byte
        unsigned char i;
        unsigned char m,da;
        da=IIC_Byte;
        OLED_SCLK_Clr();
        for(i=0;i<8;i++)
                        m=da;
                //        OLED_SCLK_Clr();
                m=m&0x80;
                if(m==0x80)
                {OLED_SDIN_Set();}
                else OLED_SDIN_Clr();
                        da=da<<1;
                OLED_SCLK_Set();
                OLED_SCLK_Clr();
// IIC Write Command
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
        IIC_Wait_Ack();
   Write_IIC_Byte(0x00);                        //write command
        IIC_Wait_Ack();
   Write_IIC_Byte(IIC_Command);
        IIC_Wait_Ack();
   IIC_Stop();
// IIC Write Data
   IIC_Start();
   Write_IIC_Byte(0x78);                        //D/C#=0; R/W#=0
        IIC_Wait_Ack();
   Write_IIC_Byte(0x40);                        //write data
        IIC_Wait_Ack();
   Write_IIC_Byte(IIC_Data);
        IIC_Wait_Ack();
   IIC_Stop();
        if(cmd)
   Write_IIC_Data(dat);
        else {
   Write_IIC_Command(dat);
// fill_Picture
        unsigned char m,n;
        for(m=0;m<8;m++)
                OLED_WR_Byte(0xb0+m,0);                //page0-page1
                OLED_WR_Byte(0x00,0);                //low column start address
                OLED_WR_Byte(0x10,0);                //high column start address
                for(n=0;n<128;n++)
                                OLED_WR_Byte(fill_Data,1);
/***********************Delay****************************************/
        unsigned int m;
        for(;Del_50ms>0;Del_50ms--)
                for(m=6245;m>0;m--);
        unsigned char j;
        while(Del_1ms--)
                for(j=0;j<123;j++);
//坐標(biāo)設(shè)置
{         OLED_WR_Byte(0xb0+y,OLED_CMD);
        OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
        OLED_WR_Byte((x&0x0f),OLED_CMD);
//開啟OLED顯示
        OLED_WR_Byte(0X8D,OLED_CMD);  //SET DCDC命令
        OLED_WR_Byte(0X14,OLED_CMD);  //DCDC ON
        OLED_WR_Byte(0XAF,OLED_CMD);  //DISPLAY ON
//關(guān)閉OLED顯示
        OLED_WR_Byte(0X10,OLED_CMD);  //DCDC OFF
        OLED_WR_Byte(0XAE,OLED_CMD);  //DISPLAY OFF
//清屏函數(shù),清完屏,整個(gè)屏幕是黑色的!和沒點(diǎn)亮一樣!!!
        u8 i,n;
        for(i=0;i<8;i++)
                OLED_WR_Byte (0xb0+i,OLED_CMD);    //設(shè)置頁地址(0~7)
                OLED_WR_Byte (0x00,OLED_CMD);      //設(shè)置顯示位置—列低地址
                OLED_WR_Byte (0x10,OLED_CMD);      //設(shè)置顯示位置—列高地址
                for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
        } //更新顯示
void OLED_On(void)
        u8 i,n;
        for(i=0;i<8;i++)
                for(n=0;n<128;n++)OLED_WR_Byte(1,OLED_DATA);
        } //更新顯示
//在指定位置顯示一個(gè)字符,包括部分字符
//x:0~127
//y:0~63
//mode:0,反白顯示;1,正常顯示
//size:選擇字體 16/12
        unsigned char c=0,i=0;
                c=chr-' ';//得到偏移后的值
                if(x>Max_Column-1){x=0;y=y+2;}
                if(Char_Size ==16)
                        OLED_Set_Pos(x,y);
                        for(i=0;i<8;i++)
                        OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
                        OLED_Set_Pos(x,y+1);
                        for(i=0;i<8;i++)
                        OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
                        else {
                                OLED_Set_Pos(x,y);
                                for(i=0;i<6;i++)
                                OLED_WR_Byte(F6x8[c][ i],OLED_DATA);
//m^n函數(shù)
u32 oled_pow(u8 m,u8 n)
        u32 result=1;
        while(n--)result*=m;
        return result;
//顯示2個(gè)數(shù)字
//x,y :起點(diǎn)坐標(biāo)
//len :數(shù)字的位數(shù)
//size:字體大小
//mode:模式        0,填充模式;1,疊加模式
//num:數(shù)值(0~4294967295);
void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2)
        u8 t,temp;
        u8 enshow=0;
        for(t=0;t<len;t++)
                temp=(num/oled_pow(10,len-t-1))%10;
                if(enshow==0&&t<(len-1))
                        if(temp==0)
                                OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
                                continue;
                        }else enshow=1;
                 OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
//顯示一個(gè)字符號(hào)串
void OLED_ShowString(u8 x,u8 y,u8 *chr,u8 Char_Size)
        unsigned char j=0;
        while (chr[j]!='\0')
        {                OLED_ShowChar(x,y,chr[j],Char_Size);
                        x+=8;
                if(x>120){x=0;y+=2;}
                        j++;
//顯示漢字
        u8 t,adder=0;
        OLED_Set_Pos(x,y);
    for(t=0;t<16;t++)
                                OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
                                adder+=1;
    for(t=0;t<16;t++)
                                OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
                                adder+=1;
/***********功能描述:顯示顯示BMP圖片128×64起始點(diǎn)坐標(biāo)(x,y),x的范圍0~127,y為頁的范圍0~7*****************/
unsigned int j=0;
unsigned char x,y;
  if(y1%8==0) y=y1/8;
  else y=y1/8+1;
        for(y=y0;y<y1;y++)
                OLED_Set_Pos(x0,y);
    for(x=x0;x<x1;x++)
                    OLED_WR_Byte(BMP[j++],OLED_DATA);
//初始化SSD1306
OLED_WR_Byte(0xAE,OLED_CMD);//--display off
        OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
        OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
        OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
        OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
        OLED_WR_Byte(0x81,OLED_CMD); // contract control
        OLED_WR_Byte(0xFF,OLED_CMD);//--128
        OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
        OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
        OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
        OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
        OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
        OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
        OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
        OLED_WR_Byte(0x80,OLED_CMD);//
        OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
        OLED_WR_Byte(0x05,OLED_CMD);//
        OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
        OLED_WR_Byte(0xF1,OLED_CMD);//
        OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
        OLED_WR_Byte(0x12,OLED_CMD);//
        OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
        OLED_WR_Byte(0x30,OLED_CMD);//
        OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
        OLED_WR_Byte(0x14,OLED_CMD);//
        OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
#include "REG51.h"
#include "oled.h"
#include "bmp.h"
int main(void)
{        u8 t;
                        OLED_Init();                        //初始化OLED
                OLED_Clear()          ;
                t=' ';
                OLED_ShowCHinese(0,0,0);//中
                                OLED_ShowCHinese(18,0,1);//景
                OLED_ShowCHinese(36,0,2);//園
                OLED_ShowCHinese(54,0,3);//電
                OLED_ShowCHinese(72,0,4);//子
                OLED_ShowCHinese(90,0,5);//科
                OLED_ShowCHinese(108,0,6);//技
                OLED_Clear();
                OLED_ShowString(6,3,"0.96' OLED TEST",16);
                //OLED_ShowString(8,2,"ZHONGJINGYUAN");
         //        OLED_ShowString(20,4,"2014/05/01");
                OLED_ShowString(0,6,"ASCII:",16);
                OLED_ShowString(63,6,"CODE:",16);
                OLED_ShowChar(48,6,t,16);//顯示ASCII字符
                t++;
                if(t>'~')t=' ';
                OLED_ShowNum(103,6,t,3,16);//顯示ASCII字符的碼值
                        delay_ms(8000);
                delay_ms(8000);
                                        delay_ms(8000);
                delay_ms(8000);
                delay_ms(8000);
                OLED_DrawBMP(0,0,128,8,BMP1);  //圖片顯示(圖片顯示慎用,生成的字表較大,會(huì)占用較多空間,F(xiàn)LASH空間8K以下慎用)
                delay_ms(8000);
                                        delay_ms(8000);
                delay_ms(8000);
                delay_ms(8000);
                delay_ms(8000);
                                        delay_ms(8000);
                delay_ms(8000);
                delay_ms(8000);
ID:1034262 發(fā)表于 2022-9-17 20:51 | 顯示全部樓層
一般賣家的的51例程都可以直接運(yùn)行。
ID:748788 發(fā)表于 2022-9-17 21:21 | 顯示全部樓層
如果沒改之前可以正常顯示,那就看看接線有沒有問題
ID:190577 發(fā)表于 2022-9-17 22:20 | 顯示全部樓層
這個(gè)程序賣家提供的測(cè)試程序是沒問題。我用過的,估計(jì)是你的硬件問題,單片機(jī)與OLED的接口不對(duì)吧
ID:1007932 發(fā)表于 2022-9-18 23:02 | 顯示全部樓層
也可能是電壓的問題
ID:390416 發(fā)表于 2022-9-20 22:25 | 顯示全部樓層
http://www.torrancerestoration.com/bbs/dpj-204281-1.html
OLED12864源代碼分享 IIC協(xié)議
ID:384109 發(fā)表于 2022-9-24 21:46 | 顯示全部樓層
你這個(gè)應(yīng)該是7針接口的屏,可以在網(wǎng)上或店鋪找對(duì)應(yīng)的例程,看你的例程像是從STM32改過來的,找找新的例程,這個(gè)例程是4針屏的,沒有CS,DC等引腳的控制
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎(jiǎng)勵(lì)!
