查看: 2120|回復(fù): 1
基于單片機(jī)的16×32點(diǎn)陣屏字幕顯示程序仿真原理圖設(shè)計
ID:1045859 發(fā)表于 2022-9-25 23:03 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
用了一個星期的時間,經(jīng)過長時間打磨
有工程文件和仿真文件
原創(chuàng)加二次改編的
具體問題留帖
電路原理圖如下:
  1. //宏定義
  3. #define uint unsigned int
  4. //頭函數(shù)
  5. #include <reg51.h>
  6. #include <intrins.h>
  7. //管腳定義
  8. //154
  9. sbit A_=P0^0;
  10. sbit B_=P0^1;
  11. sbit C_=P0^2;
  12. sbit D_=P0^3;
  13. sbit G2=P0^7;//低電平使能
  14. //595
  15. sbit SI=P0^6;//數(shù)據(jù)腳
  16. sbit SCK=P0^5;
  17. sbit RCK=P0^4;
  18. //管腳定義
  19. //154
  20. sbit A_1=P2^0;
  21. sbit B_1=P2^1;
  22. sbit C_1=P2^2;
  23. sbit D_1=P2^3;
  24. sbit G2_1=P2^7;//低電平使能
  25. //595
  26. sbit SI_1=P2^6;//數(shù)據(jù)腳
  27. sbit SCK_1=P2^5;
  28. sbit RCK_1=P2^4;
  29. sbit K1=P1^0;
  30. sbit K2=P1^1;
  31. sbit K3=P1^2;
  32. uchar flag1,flag2,X,Y;
  33. uchar zishu=10;                                //字?jǐn)?shù)
  34. uint num;
  35. bit ssflag;
  36. uchar sscount;
  37. //函數(shù)聲明
  38. void Init595();
  39. void Init595_1();
  40. void Write_byte595(uchar temp);
  41. void Write_byte595_1(uchar temp);
  42. void WriteS(uchar data1,uchar data2);
  43. void WriteS_1(uchar data1,uchar data2);
  44. void Wei_154(uchar W);
  45. void Wei_154_1(uchar W);
  46. void delay(uint z);
  47. void scan();
  48. //漢字?jǐn)?shù)組
  49. uchar code HanZi[]=
  50. {
  51. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  52. 省略
  53. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",18*/
  54. };
  55. void scan()
  56. {
  57.   if(K1==0)
  58.     {
  59.           delay(70);
  60.           if(K1==0)
  61.           {
  62.                   WriteS(0xff,0xff);//消影
  63.             while(K1==0);
  64.                         ssflag=0;
  65.             flag1++;
  66.                 if(flag1==2)
  67.                  flag1=0;
  68.                  Y=num;
  69.                  X=0;
  70.
  71.           }
  72.         }
  73.    if(K2==0)
  74.    {
  75.      delay(70);
  76.          {
  77.            if(K2==0)
  78.            {
  79.                    WriteS(0xff,0xff);//消影
  80.              while(K2==0);
  81.                          ssflag=0;
  82.                 // Y=num;
  83.                 // X=0;
  84.              flag2++;
  85.                  if(flag2==2)
  86.          flag2=0;
  87.            }
  88.          }
  89.    }
  90.          if(K3==0)
  91.          {
  92.                  delay(70);
  93.                  if(K3==0)
  94.                  {
  95.                                 WriteS(0xff,0xff);//消影
  96.                                 while(!K3);
  97.                                 ssflag = ~ssflag;
  98.                                  flag1=0;
  99.                                  flag2=0;
  100.                                  Y=num;
  101.                                         X=0;
  102.                  }
  103.          }
  104. }
  105. //主函數(shù)
  106. void main()
  107. {
  108.         uchar i=1,j=0;
  109.
  110.         flag1=0;
  111.         num=16*(zishu+3);
  112.
  113.         //595c初始化
  114.         Init595();
  115.         Init595_1();
  116.         //循環(huán)演示
  117.         while(1)
  118.         {
  119.
  120.                 if(flag1==0)
  121.                 {
  122.                         if(ssflag==0){
  123.                                         for(j=0;j<4;j++)
  124.                                         {        scan();
  125.                                                         for(i=1;i<17;i++)
  126.                                                         {
  127.
  128.        WriteS(0xff,0xff);//消影
  129.        Wei_154(i);
  130.
  131.        {WriteS(HanZi[i*2-2+2*X],HanZi[i*2-1+2*X]);}//顯示內(nèi)容
  132.
  133.
  134.
  135.
  136.        delay(1);//顯示
  137.        G2=0;//關(guān)閉
  138.        WriteS_1(0xff,0xff);//消影
  139.
  140.        Wei_154_1(i);
  141.        WriteS_1(HanZi[i*2-2+2*X+32],HanZi[i*2-1+2*X+32]);//顯示內(nèi)容
  142.
  143.        delay(1);//顯示
  144.        G2_1=0;//關(guān)閉
  145.
  146.
  147.                                                         }
  148.                                                 }
  149.                                                 if(flag2==0)
  150.                                                 {
  151.        X++;
  152.        if(X>=num)        //16*字?jǐn)?shù)+2
  153.        {
  154.        X=0;
  155.        }
  156.                                                 }
  157.                                 }else{
  158.                                         scan();
  159.                                                         sscount++;
  160.                                                         if(sscount>=50){
  161.        sscount=0;
  162.        X=X+2*16;
  163.        if(X>=num-16)        //16*字?jǐn)?shù)+2
  164.        {
  165.        X=32;
  166.        }
  167.                                                         }
  168.                                                         if(sscount<20){
  169.        for(i=1;i<17;i++)
  170.        {
  171.        WriteS(0xff,0xff);//消影
  172.        Wei_154(i);
  173.
  174.        {WriteS(HanZi[i*2-2+2*X],HanZi[i*2-1+2*X]);}//顯示內(nèi)容
  175.
  176.
  177.
  178.
  179.        delay(1);//顯示
  180.        G2=0;//關(guān)閉
  181.        WriteS_1(0xff,0xff);//消影
  182.
  183.        Wei_154_1(i);
  184.        WriteS_1(HanZi[i*2-2+2*X+32],HanZi[i*2-1+2*X+32]);//顯示內(nèi)容
  185.
  186.        delay(1);//顯示
  187.        G2_1=0;//關(guān)閉
  188.
  189.
  190.        }
  191.                                                         }else{
  192.        for(i=1;i<17;i++)
  193.        {
  194.        WriteS(0xff,0xff);//消影
  195.        Wei_154(i);
  196.
  197.        {WriteS(HanZi[i*2-2+2*0],HanZi[i*2-1+2*0]);}//顯示內(nèi)容
  198.
  199.
  200.
  201.
  202.        delay(1);//顯示
  203.        G2=0;//關(guān)閉
  204.        WriteS_1(0xff,0xff);//消影
  205.
  206.        Wei_154_1(i);
  207.        WriteS_1(HanZi[i*2-2+2*0+32],HanZi[i*2-1+2*0+32]);//顯示內(nèi)容
  208.
  209.        delay(1);//顯示
  210.        G2_1=0;//關(guān)閉
  211.
  212.
  213.        }
  214.                                                         }
  215.                                 }
  216.                         }
  217.         if(flag1==1)
  218.                 {
  219.
  220.                         for(j=0;j<4;j++)
  221.                         {        scan();
  222.                                 for(i=1;i<17;i++)
  223.                                 {
  224.
  225.                                         WriteS(0xff,0xff);//消影
  226.                                         Wei_154(i);
  227.
  228.
  229.                                         WriteS(HanZi1[i*2-2+2*Y-32],HanZi1[i*2-1+2*Y-32]);//顯示內(nèi)容
  230.
  231.
  232.
  233.
  234.                                         delay(1);//顯示
  235.                                         G2=0;//關(guān)閉
  236.                                         WriteS_1(0xff,0xff);//消影
  237.
  238.                                      Wei_154_1(i);
  239.                                                 WriteS_1(HanZi1[i*2-2+2*Y],HanZi1[i*2-1+2*Y]);//顯示內(nèi)容
  240.
  241.
  242.                                                 delay(1);//顯示
  243.                                                 G2_1=0;//關(guān)閉
  244.
  245.
  246.                                 }
  247.                         }
  248.                         if(flag2==0)
  249.                         {
  250.                                         Y--;
  251.                                         if(Y<=0)
  252.                                         Y=num;
  253.                         }
  254.                 }
  255.         }
  256. }
  257. //初始化
  258. void Init595()
  259. {
  260.         SI=1;
  261.         SCK=0;
  262.         RCK=0;
  263. }
  264. void Init595_1()
  265. {
  266.         SI_1=1;
  267.         SCK_1=0;
  268.         RCK_1=0;
  269. }
  270. void Write_byte595(uchar temp)
  271. {
  272.         uchar i,data_=temp;
  273.         G2=1;
  274.         for(i=0;i<8;i++)//傳值8位
  275.         {
  276.                 if(data_&0x01==0x01)//低位為1
  277.                 {
  278.                         SI=1;
  279.                 }
  280.                 else                                         //低位為0
  281.                 {
  282.                         SI=0;
  283.                 }
  284.                 //產(chǎn)生一個上升沿
  285. ……………………
  286. …………限于本文篇幅 余下代碼請從51黑下載附件…………
Proteus8.10版本的仿真圖(只支持此版本打開)與程序:
仿真程序.7z (11.22 MB, 下載次數(shù): 51)
admin + 50 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂 踩
ID:204529 發(fā)表于 2023-3-1 20:43 | 只看該作者
非常齊全的資料,感謝分享!
