查看: 2017|回復(fù): 0
十六進制數(shù)據(jù)改寫為C語言數(shù)組形式
ID:998802 發(fā)表于 2022-10-13 10:58 | 顯示全部樓層 |閱讀模式
如:
0111
022222
03333333
生成:
{0x01,0x11},
{0x02,0x22,0x22},
{0x03,0x33,0x33,0x33},
如果第一個數(shù)為數(shù)據(jù)長度信息,第二個數(shù)為地址,其他為數(shù)據(jù)
如:
0111
022222
03333333
生成:
{0x01,0x01,0x11},
{0x02,0x02,0x22,0x22},
{0x03,0x03,0x33,0x33,0x33},
#include <stdio.h>
#include <string.h>
int main(void)
        FILE *fp = NULL;
        int count = 0;
        int num = 0;
        int num2 = 0;
        int num3 = 0;
        int num4 = 0;
        char buf[16000] = {}; //存儲原來的數(shù)據(jù)
        char buf2[16000] = {}; //原來的數(shù)據(jù)加上每行的數(shù)據(jù)個數(shù)
        char result[16000] = {}; //改寫為C語言數(shù)組形式。
        fp = fopen("str.txt", "r");
        if  (fp == NULL) {
                printf("open str.txt err!\n");
                return -1;
        count = fread(buf, sizeof(char), sizeof(buf), fp);
        printf("read %d bytes\n", count);
        if (count < 0) {
                printf("read err!\n");
                return -1;
        fclose(fp);
/* 每行前面兩個數(shù)據(jù)為該行有效16進制數(shù)據(jù)的長度,不需要長度信息,可以把下面這段屏蔽掉 */
#if 1
        num2 += 2;
        num3 = 0;
        while(num < count) {
                while(buf[num] != '\n') {
                        buf2[num2] = buf[num];
                        num2++;
                        num++;
                if (buf[num] == '\n') {
                        num4 = (num2 - num3 - 1) / 2 - 1;
                        if (num4 / 16 >= 10)
                                buf2[num3] = num4 / 16 % 10 + 'A';
                                buf2[num3] = num4 / 16 + '0';
                        if (num4 % 16 >= 10)
                                buf2[num3+1] = num4 % 16 % 10 + 'A';
                                buf2[num3+1] = num4 % 16 + '0';
                        printf("num=%d, num2=%d, num3=%d, num4=%d\n", num, num2, num3, num4);
                        num3 = num2 + 1;
                        num2 += 3;
                        num++;
        memset(buf, 0, sizeof(buf));
        memcpy(buf, buf2, sizeof(buf));
        printf("buf = %s\n", buf);
        count = num2;
        num = 0;
        num2 = 0;
        num3 = 0;
        num4 = 0;
#endif
        result[0] = '{';
        result[1] = '0';
        result[2] = 'x';
        num2 = 3;
        while (num < count) {
                num3++;
                        num3 = 0;
                        result[num2++] = '}';
                        result[num2++] = ',';
                        result[num2++] = buf[num];
                        result[num2++] = '{';
                        result[num2++] = '0';
                        result[num2++] = 'x';
                        num++;
                        continue;
                if (num3 <= 2) {
                if (num3 == 2) {
                        if (buf[num+1] != '\n') {
                        num3 = 0;
                num++;
        fp = fopen("result.txt", "w+");
        if  (fp == NULL) {
                printf("open result.txt err!\n");
                return -1;
        count = fwrite(result, 1, num2+1, fp);
        printf("write %d bytes\n", count);
        if (count < 0) {
                printf("write result.txt err!\n");
                return -1;
        fclose(fp);
        return 0;
參與人數(shù) 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
