查看: 1623|回復(fù): 3
51單片機(jī)進(jìn)行位移運(yùn)算,為什么數(shù)據(jù)會異常?
回帖獎勵 10 黑幣 回復(fù)本帖可獲得 10 黑幣獎勵! 每人限 1 次
ID:1043477 發(fā)表于 2022-10-13 16:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序如下
#include "RX8F103.h"
#include "intrins.h"
#include <stdio.h>
#define BSWAP_16(x) \
    (uint16_t)((((uint16_t)(x) & 0x00ff) << 8) | \
                  (((uint16_t)(x) & 0xff00) >> 8) \
#define BSWAP_32(x) \
    (uint32_t)((((uint32_t)(x) & 0xff000000) >> 24) | \
                  (((uint32_t)(x) & 0x00ff0000) >> 8) | \
                          (((uint32_t)(x) & 0x0000ff00) << 8) | \
                          (((uint32_t)(x) & 0x000000ff) << 24) \
//從串口發(fā)送一個字符
void EUart0_SendOneChar(char c)
        ES0=0;                                //發(fā)送數(shù)據(jù)時關(guān)串口中斷
        TI0=0;                                //清TI位
        S0BUF = c;                //將待發(fā)送字符放入串口數(shù)據(jù)緩沖寄存器,并開始傳輸。
        while(!TI0);        //等待傳送結(jié)束。當(dāng)字符發(fā)送結(jié)束后由硬件置位請求中斷,
        //此時while循環(huán)結(jié)束,而串口中斷處理函數(shù)需等到ES重新置1后才可能響應(yīng)。
        TI0=0;                                //軟件清TI位,亦可在中斷處理函數(shù)中清0
        ES0 = 1;                        //開串口中斷
void EUart0_SendString(char *st)
        while(*st)
                EUart0_SendOneChar(*st++);
unsigned char x[50] ={0x1e,0x00,0x00,0x00,0xca,0xfb,0x5f,0xf8,0x8f,0x00,0x1a,0x00,0x02,0xcf,0x81,
                      0xdb,0xff,0xe7,0xc8,0x00,0x20,0x00,0x01,0x5e,0x46,0xf5,0x71,0xd1,0x50,0x00,
                      0x21,0x00,0x01,0xa9,0xe1,0xfc,0xdf,0xc0,0x85,0x00,0x23,0x00,0x02,0xc8,0x44,
                      0xd7,0xf5,0xe9,0x47,0x00};
void main(void)
{         long a1=8;
          long a2=0x8f;
        int a3;
  int i = 48;
  int* p = &i;
  char c = 0;
        unsigned char* iKeyP = x;
        CLKCON |= 0x1F;                                //默認(rèn)所有時鐘打開
        RSTPORTEN = 1;                                //使能復(fù)位功能
        UART0PORTEN = 1;                        //串口端口使能
        S0CON = 0x50;                                        //SCON: Mode 1, 8-bit UART, Enable Rcvr
        S0RELH = 0x03;                                //S0RELH + S0RELL  構(gòu)成波特率設(shè)置S0REL[9:0]
        S0RELL = 0xF7;                                //Baud rate  = SYSCK/(16×(1024-S0REL))  SYSCK跟CLKDIV寄存器有關(guān)  波特率為115200
        ES0 = 1;                                                        //允許串口中斷位
//        EUart0_SendString("RX8F103 IIC Slave Init! V2.0\r\n");
        printf("a1==0x%x\r\n",a1);
        a1 = ((a1) << (9));
        a2 = (a2)+(128);
        a3 = *((short*)(iKeyP + (8)));
        a3=BSWAP_16(a3);
                printf("Hello RX8F103 UART0\r\n");
                printf("a2==0x%x\r\n",a2);
                printf("a3==0x%x\r\n",a3);
char putchar (char c)
        EUart0_SendOneChar(c);
        return c;
第一個問題問題在于這個語句a1 = ((a1)) << (9);printf("a1==0x%x\r\n",a1);
long型數(shù)據(jù)是四位的,定義a1=8,按照二進(jìn)制就是0000 0000 0000 0000 0000 0000 0000 1000
左移九位就是0000 0000 0000 0000 0001 0000 0000 0000
輸出的數(shù)不應(yīng)該是0x1000么,為什么輸出的是0x0
第二個問題,是a2 = (a2)+(128);已經(jīng)定義a2=0x8f,進(jìn)行運(yùn)算a2應(yīng)該等于0x10f,但是打印出來是90
以下是打印結(jié)果
Hello RX8F103 UART0
a1==0x0
a2==0x90
a3==0x8f
ID:526108 發(fā)表于 2022-10-13 17:31 | 只看該作者
printf("a1==0x%lx\r\n",a1);
ID:1043477 發(fā)表于 2022-10-13 17:44 | 只看該作者
好的,這樣打印就對了,大佬再請教一下,現(xiàn)在我做加法運(yùn)算為什么會出錯 a2 = (a2)+(128);,之前已經(jīng)讀出來a2=0x8f,如果進(jìn)行a2=a2+128的運(yùn)算,應(yīng)該是a2=0x10f,但是現(xiàn)在打印出來的是a2=0x90
ID:384109 發(fā)表于 2022-10-13 20:35 | 只看該作者
第二個問題的答案同第一個問題
