查看: 1531|回復(fù): 4
單片機獨立按鍵控制8位共陰極數(shù)碼管程序疑問
ID:1047504 發(fā)表于 2022-10-14 23:40 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
剛剛接觸單片機,才學(xué)到獨立按鍵,剛剛寫了一個用不同按鍵控制8位共陰極數(shù)碼管顯示不同數(shù)值的小程序,代碼沒有報錯,但是用proteus仿真時卻達(dá)不到想要的效果,請求論壇各位大神幫我看看是代碼寫的有問題還是proteus電路圖畫的有問題,萬分感謝。!
代碼如下:
#include <reg51.h>
uchar code duan1[]={0x31,0x7c,0x77,0x5b,0x3f,0x06,0x01,0x01};
uchar code duan2[]={0x31,0x7c,0x77,0x5b,0x3f,0x06,0x01,0x02};
uchar code duan3[]={0x31,0x7c,0x77,0x5b,0x3f,0x06,0x01,0x03};
uchar code duan4[]={0x31,0x7c,0x77,0x5b,0x3f,0x06,0x01,0x04};
uchar code duan5[]={0x31,0x7c,0x77,0x5b,0x3f,0x06,0x01,0x05};
uchar code wei[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=114;y>0;y--);
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
uchar keyval;
void key_scan(void)
        P1=0xff;
        if((P1&0x0f)!=0x0f)
                delay(10);
                if(K1==0)
                        keyval=1;
                if(K2==0)
                        keyval=2;
                if(K3==0)
                        keyval=3;
                if(K4==0)
                        keyval=4;
                if(K5==0)
                        keyval=5;
void main(void)
        uint i;
        keyval=0;
                key_scan();
                if(keyval==1)
                        for(i=0;i<8;i++)
                                P0=duan1[ i];
                                P2=wei[ i];
                else if(keyval==2)
                        for(i=0;i<8;i++)
                                P0=duan2[ i];
                                P2=wei[ i];
                else if(keyval==3)
                        for(i=0;i<8;i++)
                                P0=duan3[ i];
                                P2=wei[ i];
                else if(keyval==4)
                        for(i=0;i<8;i++)
                                P0=duan4[ i];
                                P2=wei[ i];
                else if(keyval==5)
                        for(i=0;i<8;i++)
                                P0=duan5[ i];
                                P2=wei[ i];
只有點第四個按鍵的時候數(shù)碼管才會亮,但是八位全顯示8
ID:213173 發(fā)表于 2022-10-15 06:37 | 只看該作者
用樓主能夠理解的方式改寫一下。
  1. #include <reg51.h>
  3. #define uint unsigned int
  4. uchar code table[]={//共陰數(shù)碼管段碼"0~f-."
  5.                 0x3f,0x06,0x5b,0x4f,
  6.                 0x66,0x6d,0x7d,0x07,
  7.                 0x7f,0x6f,0x77,0x7c,
  8.                 0x39,0x5e,0x79,0x71,0x40,0x80};
  9. uchar code duan1[]={0,1,2,3,4,5,6,7};
  10. uchar code duan2[]={2,3,4,5,6,7,8,9};
  11. uchar code duan3[]={4,5,6,7,8,9,10,11};
  12. uchar code duan4[]={6,7,8,9,10,11,12,13};
  13. uchar code duan5[]={8,9,10,11,12,13,14,15};
  14. uchar code wei[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  15. void delay(uint z)
  16. {
  17.         uint x,y;
  18.         for(x=z;x>0;x--)
  19.         for(y=114;y>0;y--);
  20. }
  21. sbit K1=P1^0;
  22. sbit K2=P1^1;
  23. sbit K3=P1^2;
  24. sbit K4=P1^3;
  25. sbit K5=P1^4;
  26. uchar keyval;
  27. void key_scan(void)
  28. {
  29.         P1=0xff;
  30.         if((P1&0x1f)!=0x1f)
  31.         {
  32.                 delay(10);
  33.                 if(K1==0)
  34.                 keyval=1;
  35.                 if(K2==0)
  36.                 keyval=2;
  37.                 if(K3==0)
  38.                 keyval=3;
  39.                 if(K4==0)
  40.                 keyval=4;
  41.                 if(K5==0)
  42.                 keyval=5;
  43.         }
  44. }
  45. void main(void)
  46. {
  47.         uint i;
  48.         keyval=0;
  49.         while(1)
  50.         {
  51.                 key_scan();
  52.                 if(keyval==0)
  53.                 {
  54.                         for(i=0;i<8;i++)
  55.                         {
  56.                                 P0=0x00;
  57.                                 P2=~wei[ i];
  58.                                 P0=0x3f;
  59.                                 delay(1);
  60.                         }
  61.                 }
  62.                 if(keyval==1)
  63.                 {
  64.                         for(i=0;i<8;i++)
  65.                         {
  66.                                 P0=0x00;
  67.                                 P2=~wei[ i];
  68.                                 P0=table[duan1[ i]];
  69.                                 delay(1);
  70.                         }
  71.                 }
  72.                 else if(keyval==2)
  73.                 {
  74.                         for(i=0;i<8;i++)
  75.                         {
  76.                                 P0=0x00;
  77.                                 P2=~wei[ i];
  78.                                 P0=table[duan2[ i]];
  79.                                 delay(1);
  80.                         }
  81.                 }
  82.                 else if(keyval==3)
  83.                 {
  84.                         for(i=0;i<8;i++)
  85.                         {
  86.                                 P0=0x00;
  87.                                 P2=~wei[ i];
  88.                                 P0=table[duan3[ i]];
  89.                                 delay(1);
  90.                         }
  91.                 }
  92.                 else if(keyval==4)
  93.                 {
  94.                         for(i=0;i<8;i++)
  95.                         {
  96.                                 P0=0x00;
  97.                                 P2=~wei[ i];
  98.                                 P0=table[duan4[ i]];
  99.                                 delay(1);
  100.                         }
  101.                 }
  102.                 else if(keyval==5)
  103.                 {
  104.                         for(i=0;i<8;i++)
  105.                         {
  106.                                 P0=0x00;
  107.                                 P2=~wei[ i];
  108.                                 P0=table[duan5[ i]];
  109.                                 delay(1);
  110.                         }
  111.                 }
  112.         }
  113. }
ID:94031 發(fā)表于 2022-10-15 07:31 | 只看該作者
位掃描應(yīng)該一直循環(huán),鍵值決定段值。
void main(void)
        uint i;
        keyval=0;
                                        key_scan();
                                        if(keyval==1)
                                                P0=duan1[1];
                                        if(keyval==2)
                                                P0=duan1[2];
                                        if(keyval==3)
                                                P0=duan1[3];
                                        if(keyval==4)
                                                P0=duan1[4];
                                        if(keyval==5)
                                                P0=duan1[5];
                                        for(i=0;i<8;i++)
                                                P2=wei[ i];
ID:123289 發(fā)表于 2022-10-15 09:26 | 只看該作者
主要是你不知道8位LED的內(nèi)部分段是如何連接的,又是在何種情況下,某個段才能亮滅的。
即LED的顯示原理,要補課。
ID:1047504 發(fā)表于 2022-10-15 10:54 | 只看該作者
本帖最后由 251438796 于 2022-10-15 11:16 編輯
wulin 發(fā)表于 2022-10-15 06:37
用樓主能夠理解的方式改寫一下。
哇,謝謝大神,我搞懂了,問題已經(jīng)解決了
