2022-10-15 18:28 上傳
2022-10-15 18:28 上傳
2022 10 15編譯保存.png (201.82 KB, 下載次數(shù): 54)
2022-10-15 18:28 上傳
單片機源程序如下:- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "timer.h"
- #include "lcd.h"
- #include "key.h"
- #include "exti.h"
- #include "FreeRTOS.h"
- #include "task.h"
- STM32F103RCT6 木子小板測試 2022 4 24
- Program Size: Code=21412 RO-data=1856 RW-data=504 ZI-data=23160
- //任務優(yōu)先級
- #define START_TASK_PRIO 1 //操作系統(tǒng)主任務
- //任務堆棧大小
- #define START_STK_SIZE 128
- //任務句柄
- TaskHandle_t StartTask_Handler;
- //任務函數(shù)
- void start_task(void *pvParameters);
- //任務優(yōu)先級
- #define KEY_TASK_PRIO 2 //按鍵任務
- //任務堆棧大小
- #define KEY_STK_SIZE 128
- //任務句柄
- TaskHandle_t KeyTask_Handler;
- //任務函數(shù)
- void key_task(void *pvParameters);
- //任務優(yōu)先級
- #define TASK1_TASK_PRIO 3 //任務1
- //任務堆棧大小
- #define TASK1_STK_SIZE 128
- //任務句柄
- TaskHandle_t Task1Task_Handler;
- //任務函數(shù)
- void task1_task(void *pvParameters);
- //任務優(yōu)先級
- #define TASK2_TASK_PRIO 4 //任務2
- //任務堆棧大小
- #define TASK2_STK_SIZE 128
- //任務句柄
- TaskHandle_t Task2Task_Handler; //TaskHandle_t Task2Task_Handler KEY_0外中斷恢復任務2
- //任務函數(shù)
- void task2_task(void *pvParameters);
- #include "stm32f10x.h"
- /*************LCD刷屏時使用的顏色*****************/
- int lcd_discolor[14]={WHITE,BLACK,BLUE,BRED,
- GRED,GBLUE,RED,MAGENTA,
- GREEN,CYAN,YELLOW,BROWN,
- BRRED,GRAY
- int main(void)
- // u8 ss;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//設置系統(tǒng)中斷優(yōu)先級分組4
- delay_init(); //延時函數(shù)初始化
- uart_init(38400); //初始化串口
- LED_Init(); //初始化LED
- KEY_Init(); //初始化按鍵
- EXTIX_Init(); //初始化外部中斷
- Lcd_Init(); //初始化LCD
- POINT_COLOR = RED;
- LCD_ShowString(30,90,"2022/4/25");
- //創(chuàng)建開始任務
- xTaskCreate((TaskFunction_t )start_task, //任務函數(shù)
- (const char* )"start_task", //任務名稱
- (uint16_t )START_STK_SIZE, //任務堆棧大小
- (void* )NULL, //傳遞給任務函數(shù)的參數(shù)
- (UBaseType_t )START_TASK_PRIO, //任務優(yōu)先級
- (TaskHandle_t* )&StartTask_Handler); //任務句柄
- vTaskStartScheduler(); //開啟任務調度
- /******************開始任務任務函數(shù)**********************/
- taskENTER_CRITICAL(); //進入臨界區(qū)
- //創(chuàng)建KEY任務
- xTaskCreate((TaskFunction_t )key_task, //void key_task(void *pvParameters) key任務函數(shù)
- (const char* )"key_task",
- (uint16_t )KEY_STK_SIZE, //任務堆棧大小任務堆棧大小#define KEY_STK_SIZE 128
- (void* )NULL, //
- (UBaseType_t )KEY_TASK_PRIO, //任務優(yōu)先級 2
- (TaskHandle_t* )&KeyTask_Handler); //任務句柄
- //創(chuàng)建TASK1任務
- xTaskCreate((TaskFunction_t )task1_task, //void task1_task(void *pvParameters) task1任務函數(shù)
- (const char* )"task1_task",
- (uint16_t )TASK1_STK_SIZE, //任務堆棧大小#define TASK1_STK_SIZE 128
- (void* )NULL, //
- (UBaseType_t )TASK1_TASK_PRIO, //任務優(yōu)先級 3
- (TaskHandle_t* )&Task1Task_Handler); //任務句柄
- //創(chuàng)建TASK2任務
- xTaskCreate((TaskFunction_t )task2_task, //void task2_task(void *pvParameters) task2任務函數(shù)
- (const char* )"task2_task",
- (uint16_t )TASK2_STK_SIZE, //任務堆棧大小 #define TASK2_STK_SIZE 128
- (void* )NULL, //
- (UBaseType_t )TASK2_TASK_PRIO, //任務優(yōu)先級 4
- (TaskHandle_t* )&Task2Task_Handler); //任務句柄
- vTaskDelete(StartTask_Handler); //刪除開始任務
- taskEXIT_CRITICAL(); //退出臨界區(qū)
- /****************key任務函數(shù)************************/
- u8 key,statflag=0;
- while(1)
- key=KEY_Scan(0);
- switch(key)
- case WKUP_PRES:
- statflag=!statflag;
- if(statflag==1)
- vTaskSuspend(Task1Task_Handler); //掛起任務
- //LCD_ShowString(30,10,200,16,16," \r\n");
- LCD_ShowString(30,60,"Task1 Run\r\n");
- //LCD_ShowString(30,10,"Susp Task1 \r\n");
- else if(statflag==0)
- vTaskResume(Task1Task_Handler); //恢復任務1
- //LCD_ShowString(30,10,200,16,16,"Resum Task1\r\n");
- break;
- case KEY1_PRES:
- vTaskSuspend(Task2Task_Handler); //掛起任務2
- //LCD_ShowString(30,40,200,16,16," \r\n");
- //LCD_ShowString(30,40,200,16,16,"Susp Task2 \r\n");
- break;
- vTaskDelay(10); //延時10ms
- /***************task1任務函數(shù)***********************/
- u8 task1_num=0;
- POINT_COLOR = BLACK;
- LCD_DrawRectangle(5,110,115,314); //畫一個矩形
- LCD_DrawLine(5,130,115,130); //畫線
- POINT_COLOR = BLUE;
- LCD_ShowString(6,111,"Task1 Run:000");
- while(1)
- task1_num++; //任務執(zhí)1行次數(shù)加1 注意task1_num1加到255的時候會清零��!
- LED2=!LED2;
- vTaskDelay(2000); //延時2s,也就是2000個時鐘節(jié)拍
- /***************task2任務函數(shù)***********************/
- u8 task2_num=0;
- LCD_DrawRectangle(125,110,234,314); //畫一個矩形
- LCD_DrawLine(125,130,234,130); //畫線
- LCD_ShowString(126,111,"Task2 Run:000");
- while(1)
- task2_num++; //任務2執(zhí)行次數(shù)加1 注意task1_num2加到255的時候會清零��!
- LED3=!LED3;
- printf("任務2已經(jīng)執(zhí)行:%d次\r\n",task2_num);
- POINT_COLOR =RED;
- LCD_ShowString(30,60,"Task2 Run\r\n,");
- LCD_Fill(126,131,233,313,lcd_discolor[13-task2_num%14]); //填充區(qū)域
- //(u16 x,u16 y,u32 num,u8 len)
- LCD_ShowNum(198,111,task2_num,4); //顯示任務執(zhí)行次數(shù)
復制代碼
Keil代碼下載:
FreeRTOS編譯通過保存.7z
(1.58 MB, 下載次數(shù): 19)
2022-10-15 18:30 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
